- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] option to disable partially qualified Require Imports
- Date: Fri, 18 Sep 2020 14:44:23 +0200
Le 18/09/2020 à 14:18, Gaëtan Gilbert a écrit :
> We perhaps could add a syntax with leading dot, so in
> Require .Foo.Bar Baz.
> Foo.Bar is fully qualified, Baz isn't.
> (kind of like internet domain names with trailing dot)
Another possibility would be to relax some requirements of From-Require.
Currently, "From A.B.C Require D.E.F" means that not only the path
should start with A.B.C and finish with D.E.F, but also that there
should be no overlap between A.B.C and D.E.F. If the second constraint
was removed, then Require would become non-ambiguous for people who have
to use messy libraries.
Best regards,
Guillaume
- [Coq-Club] option to disable partially qualified Require Imports, Abhishek Anand, 09/17/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Théo Zimmermann, 09/17/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Guillaume Melquiond, 09/17/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Ralf Jung, 09/17/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Gregory Malecha, 09/17/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Théo Zimmermann, 09/18/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Ralf Jung, 09/18/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Gaëtan Gilbert, 09/18/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Guillaume Melquiond, 09/18/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Abhishek Anand, 09/18/2020
- Re: [Coq-Club] option to disable partially qualified Require Imports, Andrew Appel, 09/18/2020
