coq-club - Re: [Coq-Club] Non standard natural numbers
  • From: Vincent Semeria <vincent.semeria AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Non standard natural numbers
  • Date: Thu, 3 Jun 2021 15:53:43 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vincent.semeria AT gmail.com; spf=Pass smtp.mailfrom=vincent.semeria AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi1-f179.google.com
  • Ironport-hdrordr: A9a23:wh2KjKNV4elFs8BcTvijsMiBIKoaSvp037BL7TEJdfUxSKalfq+V7ZEmPHPP+VQssTQb6LO90cq7IE80l6QFhbX5VI3KNGLbUSmTTL2KhrGSpAEIdReOkNK1Fp0NT0G9MrDN5JRB4voSKTPXL+od
  • Ironport-phdr: A9a23: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
How do these non standard integers cope with the normalization property of Coq? A non standard integer would compute to an infinite sequence of successors, so it does not terminate.
Is it a property of Coq that all definable nat terms are standard? If so, how is "standard" defined?
On Wed, Jun 2, 2021, 22:25 roux cody <cody.roux AT gmail.com> wrote:
Sure, I mean your notional proof that the axiom schema is consistent.
On Wed, Jun 2, 2021 at 4:10 PM Evan Marzion <emarzion AT gmail.com> wrote:
By induction, c is greater than n for all n.  Thus, c > c, a contradiction.
On Wed, Jun 2, 2021 at 2:53 PM Vincent Semeria <vincent.semeria AT gmail.com> wrote:
Dear Coq club,
Is it possible to axiomatize a term c : nat, such as c is greater than all standard natural numbers ? The first 2 lines are easy,
Axiom c : nat.
Axiom c_gt0 : 0 < c.
But then, could we consistently add this axiom ?
Axiom c_non_standard : forall n:nat, n < c -> S n < c.
If the last axiom is not consistent, we could modify Coq's type checker to interpret all names of the form c_gtSSSS...S0 as closed terms of the corresponding types SSSS...S0 < c. I am pretty sure that these terms are consistent, because if they introduced a proof of False, that proof would be a finite lambda-term with only a finite number of these c_gt terms. Then c could be replaced by the greatest of these terms, and we would obtain a proof of False in basic Coq.
