- To: roux cody <cody.roux AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Non standard natural numbers
- Date: Fri, 4 Jun 2021 17:18:37 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
- Ironport-hdrordr: A9a23:ROwgoahTOyhQ7SJPLlbFvI14nXBQXg4ji2hC6mlwRA09TyVXra6TdYcgpGbJYVEqKQkdcLG7Sc+9qBbnnqKdjrNhX4tKMDOHhILsFvAE0WKA+UyFJ8SdzJ8/6U4IScEXYrDN5BpB7PoSizPVLz9P+ra6GeyT9ILj5kYodjtSQ4VMqzx0EwCBDyRNNXN7LKt8L6Ckzu5r4wCrf28aB/7LfUU4Yw==
- Ironport-phdr: A9a23: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
Hi Cody,
A very reasonable question! Here is the "standard" answer, which I *think* I subscribe to?
You're allowed to write/accept Ack 5 5, or indeed Ack 10 10, or any number you like, *as long as* you define it using only EFA (https://en.wikipedia.org/wiki/Elementary_function_arithmetic <https://en.wikipedia.org/wiki/Elementary_function_arithmetic>). You don't get to "meta define" it, using the assumption that PA is consistent, for example: you have to actually write down the definition in full.
I see, so you are essentially not accepting (in general) the use of well-founded recursion, such as in your definition of "Ack"? I am now trying to imagine which part of maths is even expressible in this subset, and it seems to be tiny, but I assume there's tricks one can play.
I'd personally rather take MLTT or pCuIC or some similar calculus as the foundation and *define* addition and other parts of elementary arithmetic using well-founded recursion, but it seems we have different taste here. ;)
Kind regards,
Ralf
Anything beyond that is forbidden. I'd add, even the totality of the exponential function seems a bit fishy to an extremist like myself, but that's perhaps another story. Of course you may postulate it's existence, just as you may postulate the existence of non-trivial zeros of the Zeta function.
Strict adherence to this principle would make it impossible for me to use and enjoy Coq or Isabelle though. That said, people don't always become mennonites when some universe inconsistency is discovered, so maybe there's some room for compromise.
Hope this somewhat explains my view.
Best,
Cody
On Fri, Jun 4, 2021 at 10:10 AM Ralf Jung <jung AT mpi-sws.org <mailto:jung AT mpi-sws.org>> wrote:
Hi Cody,
Forgive the possibly naive question, but what I am wondering here is:
where do
you draw the line? With intuitionism, there is a very clear and formal
boundary
for what we consider 'acceptable' and what not. Say, pCuIC. People might
disagree about which calculus/logic is the "right" one, but each calculus
is
very clearly delineating terms/theorems we accept from those we do not.
On the other hand, you seem to draw a line somewhere between "Ack 1 1" and
"Ack
5 5". I assume you will not want to pin down this line *precisely*, since
any
choice is by necessity arbitrary, but that is exactly my point, and it is
why I
do not agree with your arguments. Put differently: if we lived in a
*shrinking*
universe where more matter comes into the "observable universe" over time,
would
"Ack 5 5" suddenly be an acceptable statement to you once the number of
atoms in
the observable universe has grown enough?
Kind regards,
Ralf
On 03.06.21 23:04, roux cody wrote:
> Not sure how kosher it is to talk about foundational issues on the
Club,
since
> it seems to tend to inspire a lot of opinionated debate...
> However... :)
> I stand by my analogy!
> I can certainly imagine an oracle that decides the Truth of an
arbitrary
> arithmetic statement, and communicate the idea to other humans (I just
did!).
> I can also imagine wanting evidence that, in addition to an explanation
being
> constructive, that the answer to a question might fit on a computer
composed of
> all the atoms in the universe, or (if I'm feeling demanding) on my own
computer.
> A reasonable objection to the above: we can always prove a concrete
bound
on a
> number using intuitionistic logic.
> My rejoinder: the same can be said about constructive results and
classical
> logic: we can always just exhibit a Turing machine and classically
prove
that it
> terminates.
> At any rate: In Coq, we may assume that every term has some
hypothetical
> ghost-like normal form, and maybe even that is a theorem in ZFC+some
> inaccessible, and that's that.
> Personally, I treat Ack 5 5 the same way one might treat Hypercompact
cardinals:
> fun to do math at, but I don't feel it "really" exists. I'll assume it
if
I need
> it to prove something though.
> Best,
> On Thu, Jun 3, 2021 at 3:10 PM Thorsten Altenkirch
> <Thorsten.Altenkirch AT nottingham.ac.uk
<mailto:Thorsten.Altenkirch AT nottingham.ac.uk>
<mailto:Thorsten.Altenkirch AT nottingham.ac.uk>>> wrote:
> No it’s not the same. The idea that some computation will
terminate
> eventually even if we are not able to perform it in practice is
clearly
> understandable and communicable among humans. It is different to
ignoring
> the need for constructive explanations altogether.
> Sent from my iPhone
>> On 3 Jun 2021, at 18:34, roux cody <cody.roux AT gmail.com
<mailto:cody.roux AT gmail.com>
>> <mailto:cody.roux AT gmail.com <mailto:cody.roux AT gmail.com>>> wrote:
>> It certainly feels very hard to distinguish between Very Large
Numbers and
>> Non Standard ones, and the distinction does seem very closely
related to
>> normalization.
>> But I'd advocate a slightly more subtle position than "There are
>> absolutely less than 10^74 integers", but rather, "Gee, it sure
gets
hard
>> to name (most) numbers bigger than 2^10^74..."
>> The same way intuitionism doesn't say: "This specific machine, M,
neither
>> terminates nor runs forever" but says "Maybe we shouldn't make the
blanket
>> assumption that *all* machines either terminate or run forever".
>> I suspect this agnosticism is what I'm really advocating (but one
can't
>> really be too sure...)
>> Best,
>> Cody
>> Best,
>> Cody
>> On Thu, Jun 3, 2021 at 12:26 PM Eddy Westbrook
<westbrook AT galois.com
<mailto:westbrook AT galois.com>
>> <mailto:westbrook AT galois.com <mailto:westbrook AT galois.com>>>
wrote:
>> Cody,
>> My initial reaction was that Ack 5 5 will eventually compute
to a
>> specific finite natural number, so at some point c_gtN will be
>> inconsistent.
>> But I think your argument has an interesting twist: you are
basically
>> arguing using a version of Ultrafinitism, that there are
finite
>> numbers that are just too big to represent in the 10^74 atoms
in the
>> universe. What you are saying is that it is not possible to
actually
>> write down a counterexample.
>> A counter-argument, then: if we are starting from
ultrafinitism,
then
>> there are definitely no infinitary natural numbers, because
there are
>> in fact only finitely many elements of any type.
>> -Eddy
>>> On Jun 3, 2021, at 9:13 AM, roux cody <cody.roux AT gmail.com
wrote:
>>> Sadly, it is possible to compute non-standard numbers in Coq
without
>>> axioms. Here is an example:
>>> Fixpoint Ack m := fix A_m n :=
>>> match m with
>>> | 0 => n + 1
>>> | S pm =>
>>> match n with
>>> | 0 => Ack pm 1
>>> | S pn => Ack pm (A_m pn)
>>> end
>>> end.
>>> Definition c : nat := Ack 5 5.
>>> Indeed adding axioms like c_gt0, c_gtS0, ... (as many as you
like!)
>>> will all be consistent.
>>> In practice, though, you can pretend that such numbers do not
exist,
>>> and things will go on relatively undisturbed.
>>> Best,
>>> Cody
>>> On Thu, Jun 3, 2021 at 10:16 AM Vincent Semeria
>>> <vincent.semeria AT gmail.com <mailto:vincent.semeria AT gmail.com>
<mailto:vincent.semeria AT gmail.com <mailto:vincent.semeria AT gmail.com>>>
wrote:
>>> Hi Eddy,
>>> On the contrary, I would like to avoid non standard
numbers, so
>>> that the normalization property of Coq does mean that
every
>>> computation of a nat term terminates.
>>> But since we established that Coq cannot refute non
standard nat
>>> terms, I am trying to measure the risk that I
accidentally
try to
>>> compute a non standard nat (without any axioms posed).
>>> On Thu, Jun 3, 2021, 16:06 Eddy Westbrook
<westbrook AT galois.com <mailto:westbrook AT galois.com>
<mailto:westbrook AT galois.com>>> wrote:
>>> Vincent,
>>> There are certainly non-standard models of Coq (Gödel
ensures
>>> us of that), but they are bound to be a lot more
complicated
>>> than non-standard models of Peano arithmetic, which
is
where
>>> the notion of non-standard naturals comes from. The
reason
>>> for this is that Coq can express a general notion of
>>> well-foundedness and induction in the logic (this is
in
fact
>>> the heart of Evan’s answer, that you can use
induction in
>>> Coq), whereas Peano arithmetic cannot.
>>> If what you really want is non-standard models of
Peano
>>> arithmetic, then you will probably have to formalize
Peano
>>> arithmetic, or at least a simpler form of it. I
would guess
>>> that there are formalizations of it in Coq out there,
but am
>>> not sure. A simpler form of Peano arithmetic might
just
be to
>>> define a signature (or, better, a type class) of
types that
>>> have a 0 and successor but not necessarily induction.
>>> If what you want is just infinite natural numbers,
maybe you
>>> should look at Coq’s coinductive types? These let you
define
>>> a Coq type that can contain infinite sequences of
successors.
>>> Hope this helps,
>>> -Eddy
>>>> On Jun 3, 2021, at 6:53 AM, Vincent Semeria
<mailto:vincent.semeria AT gmail.com>>> wrote:
>>>> How do these non standard integers cope with the
>>>> normalization property of Coq? A non standard
integer
would
>>>> compute to an infinite sequence of successors, so
it does
>>>> not terminate.
>>>> Is it a property of Coq that all definable nat
terms are
>>>> standard? If so, how is "standard" defined?
>>>> On Wed, Jun 2, 2021, 22:25 roux cody
<cody.roux AT gmail.com <mailto:cody.roux AT gmail.com>
>>>> Sure, I mean your notional proof that the axiom
schema
>>>> is consistent.
>>>> On Wed, Jun 2, 2021 at 4:10 PM Evan Marzion
>>>> <emarzion AT gmail.com <mailto:emarzion AT gmail.com>
<mailto:emarzion AT gmail.com <mailto:emarzion AT gmail.com>>> wrote:
>>>> By induction, c is greater than n for all n. Thus,
>>>> c > c, a contradiction.
>>>> On Wed, Jun 2, 2021 at 2:53 PM Vincent
Semeria
>>>> Dear Coq club,
>>>> Is it possible to axiomatize a term c :
nat,
>>>> such as c is greater than all standard
natural
>>>> numbers ? The first 2 lines are easy,
>>>> Axiom c : nat.
>>>> Axiom c_gt0 : 0 < c.
>>>> But then, could we consistently add this
axiom ?
>>>> Axiom c_non_standard : forall n:nat, n
< c
-> S
>>>> n < c.
>>>> If the last axiom is not consistent, we
could
>>>> modify Coq's type checker to interpret
all
names
>>>> of the form c_gtSSSS...S0 as closed
terms
of the
>>>> corresponding types SSSS...S0 < c. I am
pretty
>>>> sure that these terms are consistent,
because if
>>>> they introduced a proof of False, that
proof
>>>> would be a finite lambda-term with only
a
finite
>>>> number of these c_gt terms. Then c
could be
>>>> replaced by the greatest of these terms,
and we
>>>> would obtain a proof of False in basic
Coq.
> This message and any attachment are intended solely for the
addressee
> and may contain confidential information. If you have received this
> message in error, please contact the sender and delete the email
and
> attachment.
> Any views or opinions expressed by the author of this email do not
> necessarily reflect the views of the University of Nottingham.
> communications with the University of Nottingham may be monitored
> where permitted by law.
-- Website: https://people.mpi-sws.org/~jung/ <https://people.mpi-sws.org/~jung/>
- Re: [Coq-Club] Non standard natural numbers, (continued)
- Re: [Coq-Club] Non standard natural numbers, Vincent Semeria, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, Eddy Westbrook, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, roux cody, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, Ralf Jung, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, Thorsten Altenkirch, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, Ralf Jung, 06/04/2021
- Message not available
- Re: [Coq-Club] Non standard natural numbers, Tadeusz Litak, 06/04/2021
- Re: [Coq-Club] Non standard natural numbers, Dominik Kirst, 06/04/2021
- Re: [Coq-Club] Non standard natural numbers, Thorsten Altenkirch, 06/05/2021
- Re: [Coq-Club] Non standard natural numbers, Vincent Semeria, 06/04/2021
- Re: [Coq-Club] Non standard natural numbers, Vincent Semeria, 06/07/2021
