- To: coq-club AT inria.fr, roux cody <cody.roux AT gmail.com>
- Subject: Re: [Coq-Club] Non standard natural numbers
- Date: Thu, 3 Jun 2021 18:21:17 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
- Ironport-hdrordr: A9a23:kSIxMaFTZNZw5gUppLqE68eALOsnbusQ8zAXPidKOHtom62j5qSTdZEgviMc5wxxZJhNo7290dC7IU80l6QFg7X5VI3KNDUO3lHHEGhM1+TfKlbbcREWmNQw6U92G5IOa+EZ0zNB/KPH3DU=
- Ironport-phdr: A9a23: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
Hi,
Sadly, it is possible to compute non-standard numbers in Coq without axioms. Here is an example:
Fixpoint Ack m := fix A_m n :=
match m with
| 0 => n + 1
| S pm =>
match n with
| 0 => Ack pm 1
| S pn => Ack pm (A_m pn)
end
end.
Definition c : nat := Ack 5 5.
This will be a (very) big number, but in which sense is it "non-standard"? Seems like a completely well-behaved number to me?
Kind regards,
Ralf
Indeed adding axioms like c_gt0, c_gtS0, ... (as many as you like!) will all be consistent.
In practice, though, you can pretend that such numbers do not exist, and things will go on relatively undisturbed.
Best,
Cody
On Thu, Jun 3, 2021 at 10:16 AM Vincent Semeria <vincent.semeria AT gmail.com <mailto:vincent.semeria AT gmail.com>> wrote:
Hi Eddy,
On the contrary, I would like to avoid non standard numbers, so that the
normalization property of Coq does mean that every computation of a nat
term
terminates.
But since we established that Coq cannot refute non standard nat terms, I
am
trying to measure the risk that I accidentally try to compute a non
standard
nat (without any axioms posed).
On Thu, Jun 3, 2021, 16:06 Eddy Westbrook <westbrook AT galois.com
<mailto:westbrook AT galois.com>> wrote:
Vincent,
There are certainly non-standard models of Coq (Gödel ensures us of
that), but they are bound to be a lot more complicated than
non-standard
models of Peano arithmetic, which is where the notion of non-standard
naturals comes from. The reason for this is that Coq can express a
general notion of well-foundedness and induction in the logic (this is
in fact the heart of Evan’s answer, that you can use induction in
Coq),
whereas Peano arithmetic cannot.
If what you really want is non-standard models of Peano arithmetic,
then
you will probably have to formalize Peano arithmetic, or at least a
simpler form of it. I would guess that there are formalizations of it
in
Coq out there, but am not sure. A simpler form of Peano arithmetic
might
just be to define a signature (or, better, a type class) of types that
have a 0 and successor but not necessarily induction.
If what you want is just infinite natural numbers, maybe you should
look
at Coq’s coinductive types? These let you define a Coq type that can
contain infinite sequences of successors.
Hope this helps,
-Eddy
On Jun 3, 2021, at 6:53 AM, Vincent Semeria <vincent.semeria AT gmail.com
How do these non standard integers cope with the normalization
property of Coq? A non standard integer would compute to an infinite
sequence of successors, so it does not terminate.
Is it a property of Coq that all definable nat terms are standard? If
so, how is "standard" defined?
On Wed, Jun 2, 2021, 22:25 roux cody <cody.roux AT gmail.com
<mailto:cody.roux AT gmail.com>> wrote:
Sure, I mean your notional proof that the axiom schema is
consistent.
On Wed, Jun 2, 2021 at 4:10 PM Evan Marzion <emarzion AT gmail.com
<mailto:emarzion AT gmail.com>> wrote:
By induction, c is greater than n for all n. Thus, c > c, a
contradiction.
On Wed, Jun 2, 2021 at 2:53 PM Vincent Semeria
wrote:
Dear Coq club,
Is it possible to axiomatize a term c : nat, such as c is
greater than all standard natural numbers ? The first 2
lines are easy,
Axiom c : nat.
Axiom c_gt0 : 0 < c.
But then, could we consistently add this axiom ?
Axiom c_non_standard : forall n:nat, n < c -> S n < c.
If the last axiom is not consistent, we could modify Coq's
type checker to interpret all names of the form
c_gtSSSS...S0 as closed terms of the corresponding types
SSSS...S0 < c. I am pretty sure that these terms are
consistent, because if they introduced a proof of False,
that proof would be a finite lambda-term with only a
finite number of these c_gt terms. Then c could be
replaced by the greatest of these terms, and we would
obtain a proof of False in basic Coq.
Website: https://people.mpi-sws.org/~jung/
- [Coq-Club] Non standard natural numbers, Vincent Semeria, 06/02/2021
- Re: [Coq-Club] Non standard natural numbers, roux cody, 06/02/2021
- Re: [Coq-Club] Non standard natural numbers, Evan Marzion, 06/02/2021
- Re: [Coq-Club] Non standard natural numbers, Vincent Semeria, 06/02/2021
- Re: [Coq-Club] Non standard natural numbers, Vincent Semeria, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, Eddy Westbrook, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, roux cody, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, Ralf Jung, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, Thorsten Altenkirch, 06/03/2021
- Re: [Coq-Club] Non standard natural numbers, Ralf Jung, 06/04/2021
- Message not available
- Re: [Coq-Club] Non standard natural numbers, Tadeusz Litak, 06/04/2021
