coq-club - Re: [Coq-Club] Proving transitiviy of simple type system
  • From: Jean-Marie Madiot <jean-marie.madiot AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proving transitiviy of simple type system
  • Date: Mon, 2 Oct 2023 23:43:37 +0200
  • Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=jean-marie.madiot AT inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hello Frédéric,
One standard "Coq trick" that you may already know is to generalize the statement before performing the induction, typically by doing something like "revert t3 HSubR; induction HSubL"  or "revert t1 HSubL; induction HSubR" in your example.
However typeSub is contravariant in one of its argument, which makes things more interesting: only generalizing for all "HSubL" or for all "HSubR" won't be enough, you need to be able to switch sides.
Suppose that you have a coarser (hence non trivial) subtyping relation such as
Inductive typeSub : type -> type -> Prop :=
| SubTUnit : typeSub TUnit TUnit
| SubTFunUnit : forall ti to, typeSub (TFun ti to) TUnit
| SubTFun : forall ti1 to1 ti2 to2, typeSub ti2 ti1 -> typeSub to1 to2 -> typeSub (TFun ti1 to1) (TFun ti2 to2).
Infix "<" := typeSub.
Then you can generalize on both sides in this way:
Lemma trans_aux t1 t2 : t1 < t2 -> (forall x, x < t1 -> x < t2) /\ (forall x, t2 < x -> t1 < x).
Proof.
  intros HSub; induction HSub; split; intros x Hx; inversion Hx; subst; constructor; firstorder.
Qed.
Lemma trans: forall t1 t2 t3, t1 < t2 -> t2 < t3 -> t1 < t3.
Proof.
  intros t1 t2 t3 HSubL.
  apply trans_aux, HSubL.
Qed.
Regards,
Jean-Marie
Le 02/10/2023 à 19:53, Frederic Fort a écrit :
Hello,
I am trying to prove the some facts about the type system of a simple Lambda calculus. However, I struggle to prove the transitivity of the subtype relation.
I have seen in papers that certain people simply "axiomatize" properties like transitivity and reflexivity by defining specific rules for these properties.
However, I find this inelegant as this makes proofs in other places more "cluttered" due to the additional constructors.
I have a few proofs that work fine. For transitivity however, I am stuck.
I have tried all kinds of (dependent) induction approaches, but I am generally stuck either because Coq requires me to prove that the unit type is a subtype of a function type or because the induction hypothesis doesn't take into account that subtyping of function input types is in the "opposite direction".
I suppose that there is some "Coq trick" that I am unfamiliar with (maybe I have to define a custom induction scheme ?).
Or maybe it is actually impossible to prove transitivity like that.
If somebody could show me what I am missing, I'd be grateful.
Yours sincerely,
Frédéric Fort
Here are my definitions:
Inductive expr :=
| Unt
| Var (n : nat)
| Lam (v : nat) (e : expr)
| App (f : expr) (arg : expr)
Inductive type :=
| TUnit
| TFun (tin tout : type)
Lemma refl:
forall t, typeSub t t.
Proof.
intros.
induction t; constructor; auto.
Qed.
Lemma sub_is_eq:
forall t1 t2, typeSub t1 t2 -> t1 = t2.
Proof.
intros.
induction H.
- reflexivity.
- rewrite IHtypeSub1. rewrite IHtypeSub2. reflexivity.
Qed.
Lemma trans:
forall t1 t2 t3,
typeSub t1 t2 -> typeSub t2 t3 -> typeSub t1 t3.
Proof.
intros t1 t2 t3 HSubL HSubR.
Admitted.
