coq-club - Re: [Coq-Club] Proving transitiviy of simple type system
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Proving transitiviy of simple type system
  • Date: Tue, 3 Oct 2023 00:15:40 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lasse AT blaauwbroek.eu; spf=Pass smtp.mailfrom=lasse AT blaauwbroek.eu; spf=None smtp.helo=postmaster AT mail.blaauwbroek.eu
  • Ironport-data: A9a23:jZeCwqsfL0H8plLh4GWoRJnFEefnVOlYMUV32f8akzHdYApBsoF/q tZmKWzXbKnZNmX9ctsiPYSy8EJSvpSEnd9nSVNoqSE8QyhGgMeUXt7xwmXYb3rDdJWbJK5Ex 5xDMYeYdJhcolv0/ErF3m3J9CEkvU2wbuOgTrSCYEidfCc8IA85kxVvhuUltYBhhNm9Emult Mj7yyHlEAbNNwVcbCRMsMpvlDs15K6p4WtA5ARkDRx2lAa2e0c9XMp3yZ6ZdCOQrrl8RoaSW +vFxbelyWLVlz9F5gSNz94X2mVTKlLjFVDmZkh+A8BOsTAezsAG6ZvXAdJHAathZ5plqPgqo DlFncTYpQ7EpcQgksxFO/VTO3kW0aGrZNYriJVw2CCe5xSuTpfi/xlhJG4ZPKED9sBQO2dt9 9oWCy8NLTOY3f3jldpXSsE07igiBMziPYdZsHVpxCzGB+whTJOFTriiCd1whWdtwJoSW6yEP 4xGMFKDbzyYC/FLElMeE4kztO2sj3DibDdCr1+W46cqi4TW5FUrgeC9bIuKJbRmQ+13uXajl F7W21/hDzchd4aU1Dra92Cz07qncSTTHdh6+KeD3vVtmRiYwnEZIAYHUEOy5/i/kE+3HdxFQ 3H44QIrpKk2skavR9DgQBeip3OH+BMBMzZNL9AHBMi24vK8y26k6qIsF1atsfR25JFkdi9gz VKTgdLiCBpmtbDfGzrX9a6ZoXn2cWIZJHMLL31MBwYUwcjRkKdqhDL2T/FnDPGUiP/xEmrO2 DyklnU1qIgSqs8p7J+F2277rQiinbXzdT5t1D7rBjqkyihbeL+aY5eZ7AmHzPRYc6ecYFqzn FkFvMm87eohI5GBpCCMS+BcGLi4uvKJCxzHoFtVB5J63S+cy32iWoFx4T9FO0ZiNPgfSwLpe EP+vQBw5odZGXmXMZ9MfIO6Dvo1wZjaFdjKUu7eavxMaMNTcDCr0T5PZ0nK+UzQi2kpzL8CP KmEffaWDXo1DbptyBy0Tbw/1Z4p3iUP+nPBd6vkzhiI0ausW1DNcO0raGCxV+Ee6L+IhC738 NwFbsuD9Eh5Yd3EOyLS9dYeEEAOIX0FHqvJks1wdNDSBip9GWokNe3d/qN5RaxhgJZut7np+ lOTZxZm7WTR1Fz9FBWyS3F8abnQc451glAlMAcNY1u5+XgRTry+zaUYdpEIU6Et37Fix9FaT /U1d8SLB6VLQyWa/zgmTILcqbZ6f0+BnjO+PCuCYRk+caV/RgfPxMTWQwv3+AQKDQu1rcEbs ZT58i/6GL0tHx9DCuTSY9KRl2KBh2AXwr9ObhGZM+ttd1XJ26k0DS7I19scAdwGcDfHzRukj zemOw8S/7TxktVk4evypP62qqmyGLFDBWtcJW7Q6Ii2OQT8/maOxYxhUv6CTQvCVVHbqbmTW uFI887SaPE3vk5Gk45ZIYZZyagT49jOpbgDwD90Q1TNTVCgUY17Lle8gMJgi6xqx51igzWQZ H6hwNdgBOi2CJvXK2JJfAsBRcaf5M4QgQjXvKgUIl2lxSpZ/4incER1PjuNggNzLLdFPIIux LYlsd9L7wCEqwELN+yehXt+7FW8LX0nUoQmuKoFAYTttBEZ91FabbHYCQ70+JuqaegQAnI1I zSRurXOt45cymXGbXA3M3rHhshZurgjpzFIywUkC2mSu9+YmMIy4gJdwQ43QitR0B9D9eB5Y UpvFk9tIJSx7yVav9dCU0+sCjN+KkWgoGKp8GQwlUrdU0WMfU7OJjdkOe+yoWYow1gFdT1fp Lyl2GLpVAjxR/7I3wwwZx9Vm6S2B5g5vAjPg9uuEMm5DoE3K2ityLOnYW0T7QDrG4UtjUnAv vNn5/t0dba9DyMLvqknEMOP4Nz8kvxfyLBqGpmNPZ/lHF0wvBm30DmKbUq1c8pQOPbQ9kK7T cFzTi6Ku9JSyw7Wxg33x4ZVS1O3oBLtzNAGc7r2OmQctLac6Dd02H4V3jarn3clGr2Cju5kQ r48tFu+/qi4j39dknLSptNDN2n+bMRsiMgQGgyq2L1hKq/ve92Ava3/PnVYcplV3MZaE8qog T7+
  • Ironport-hdrordr: A9a23:fbIQj63cPYdchEXE8k+3fwqjBL8kLtp133Aq2lEZdPUnSK2lfq eV7ZMmPH7P+VIssR4b9OxoVJPwI080sKQFhLX5Xo3PYOCFggGVxehZhOOI/9SjIVycygc378 ldmsZFaOEYQWIUsfrH
  • Ironport-phdr: A9a23:1BVUaB9RX3ITxf9uWVm6ngc9DxPP2p3xNw8RsN88jq5WN76k9NLkN VDe4vNkiBnIW5/a4rRKkbmeqLjuDEoH55vJq3UeaNpUTRZQjcwNhAEICsqMAFDkJuTtYi98E dkRHER98SSDOFNOUN37e0WUp3Sz6TAIHRCqMQNuPendEIrbhtmo3fq19p6VbhgbzCGlb+ZUK xO75R7UqtFQgYZmLfMpzQDVp3JTZ+lM7WZhJFbVlRL179qv9oRk/icWtu9JG9dod6L8cux4S LVZCG5jKGUp/IjxshKFSwKT53waW2FQkxxSAgGD4guoFpH2+jD3sOZwwkz4dYX/UKw0VDK+7 qxqVA6giSEJMCQ8+X3Wjco4hbxSoRaorRhyi4DOZ4TdOP17d6LbNdQUIAgJFsJYTDdMKom4Z oISEOAbOutb6YTg5hMPoRa4GQiwFbb30DYbznTy3KA8z6EgCVSfjFFmRY5I6i6M6oqsZ8JwG aivwaLFzCvOdaZT0Db5ss3Tdww55OuLVvR2eNbQzk8mE0XEiE+RoMrrJWDwtKxFvm6F4u5nT e/qhXQgrlQ7pjG03coEgI3Aj58KwErD+CY/zZt/drjaAAZrJMWpFpddrXTQM4JtWc4KSWVhs TslwKcBtJ39cTVAm/FFj1bPLveAdYaP+BfqUu2cdCx5iHxSc7W6nx+u8EKkx4UQT+GM2U1R5 mpAm9jI7DUW0gDLr9KAQb1791ug3jCG00bS7PtFKAY6j/iTJ5kky7823p0d1CaLViv/g177p KWSf0w55eKy7OnkJLj77pORLI57jAjiP79mw5ziR75kdFJUBy7EoKy1z/X78Ff8QalWg/FT8 OGRq53cKckB5+a4DwJTzoc/+kO6Bjai3s4fmCpPJ1ZEdRSbyonxbgiefbaiUbHl2Qzqz244o pKOdqfsCZjMMHXZxbLofLInrlVZ1BJ219dUoZRdFrAGJvv3HE73rt3RSBEjYGnWi67qDstw0 oQGVCeBGKicZenWuEST68olJ+CFeZAfojHwKL4o+rS96B1x0U9YZqSv0ZYNPTq8F+99Lm2TZ XPln8gLC2AHvUwzUaa57T/KGS4WbHG0UaUm4zg9A4/zFobPSLemh7mZ1Tu6FJlbNShWT0qBG nDye8CYSu8BPWiMd9R5nGVOBt3DA8cxkAujvwjgx/97I/rIr2cG4In72oE94v2bnFkk/DhwR axxykmrSGd51iMNTj4yhuVkpFBlj02E2u5+iuBZEtpa47VIVB07PNjS1b4yDde6QQ/HctqTL TTuCty7HTE8SM4wyN4Scg58HdullBXKwyutBfccibWKAJU+9q+U0WL2Io5xzHPP1a9piFdDI IMHLWq9mqt27BTeHabMmkSd0ayufK0BwyTX82qAi2eT/QlZXAN2TaTZTCUfa0/R/rGbrgvJS 76jD6hiMxMUkJ7fbPEWLIez1RMZHaSGWpyWeW+6lmauCAzdw7qNaNCvYGABxGDHD0NClQkP/ HGAPAx4ByG7omuYAiY9cDCnK07q7+R6r2u2C0EuyATfJUlozKG40hQRjPWBVPkJ2b8H/io84 WYRfh71z5fNBtyMqhA0Nr1bes846Uxb2HjxsgV8OtqqK6lrm0EUaQN6vAXjyl8kb+cI2dhvp 3Qswg1oLKue214UbDKU06f7PbjPI3Xz9hSiA0Yz8lva2d+L5a0V7/k77Vj+7lnB/qsK9nxm1 59f13KV+4rAFg0fUtT8TxRvn/CVj7veayAg+InO0nBvd6Sp4Gaq5g==
  • Ironport-sdr: 651b4115_ykPJEh3hJCiDxVMqIrzqVEVVIctjDdaqZGRdmP7FjtBfanW +i9erz1MJllp4GdvnU60L9pmSIFNb31f4kY2jaA==
Although Jean-Marie's and Jason's generalizations both work here, I believe that the crucial point is still that this subtyping relation is trivial. As far as I know, for most sufficiently "interesting" subtyping relations, transitivity and reflexivity are not provable without axiomatizing them. That is, you have to add reflexivity and transitivity constructors (unless you modify all other constructors such that transitivity is "built-in", but that amounts to the same thing). For example, as soon as you have type variables you will not be able to prove "\alpha < \alpha" without the axiom.
I'd be curious to know what kind of type-system you have in mind where this is not needed?
On 02-10-2023 23:43, Jean-Marie Madiot wrote:
Hello Frédéric,
One standard "Coq trick" that you may already know is to generalize the statement before performing the induction, typically by doing something like "revert t3 HSubR; induction HSubL"  or "revert t1 HSubL; induction HSubR" in your example.
However typeSub is contravariant in one of its argument, which makes things more interesting: only generalizing for all "HSubL" or for all "HSubR" won't be enough, you need to be able to switch sides.
Suppose that you have a coarser (hence non trivial) subtyping relation such as
Inductive typeSub : type -> type -> Prop :=
| SubTUnit : typeSub TUnit TUnit
| SubTFunUnit : forall ti to, typeSub (TFun ti to) TUnit
| SubTFun : forall ti1 to1 ti2 to2, typeSub ti2 ti1 -> typeSub to1 to2 -> typeSub (TFun ti1 to1) (TFun ti2 to2).
Infix "<" := typeSub.
Then you can generalize on both sides in this way:
Lemma trans_aux t1 t2 : t1 < t2 -> (forall x, x < t1 -> x < t2) /\ (forall x, t2 < x -> t1 < x).
Proof.
  intros HSub; induction HSub; split; intros x Hx; inversion Hx; subst; constructor; firstorder.
Qed.
Lemma trans: forall t1 t2 t3, t1 < t2 -> t2 < t3 -> t1 < t3.
Proof.
  intros t1 t2 t3 HSubL.
  apply trans_aux, HSubL.
Qed.
Regards,
Jean-Marie
Le 02/10/2023 à 19:53, Frederic Fort a écrit :
Hello,
I am trying to prove the some facts about the type system of a simple Lambda calculus. However, I struggle to prove the transitivity of the subtype relation.
I have seen in papers that certain people simply "axiomatize" properties like transitivity and reflexivity by defining specific rules for these properties.
However, I find this inelegant as this makes proofs in other places more "cluttered" due to the additional constructors.
I have a few proofs that work fine. For transitivity however, I am stuck.
I have tried all kinds of (dependent) induction approaches, but I am generally stuck either because Coq requires me to prove that the unit type is a subtype of a function type or because the induction hypothesis doesn't take into account that subtyping of function input types is in the "opposite direction".
I suppose that there is some "Coq trick" that I am unfamiliar with (maybe I have to define a custom induction scheme ?).
Or maybe it is actually impossible to prove transitivity like that.
If somebody could show me what I am missing, I'd be grateful.
Yours sincerely,
Frédéric Fort
Here are my definitions:
Inductive expr :=
| Unt
| Var (n : nat)
| Lam (v : nat) (e : expr)
| App (f : expr) (arg : expr)
Inductive type :=
| TUnit
| TFun (tin tout : type)
Lemma refl:
forall t, typeSub t t.
Proof.
intros.
induction t; constructor; auto.
Qed.
Lemma sub_is_eq:
forall t1 t2, typeSub t1 t2 -> t1 = t2.
Proof.
intros.
induction H.
- reflexivity.
- rewrite IHtypeSub1. rewrite IHtypeSub2. reflexivity.
Qed.
Lemma trans:
forall t1 t2 t3,
typeSub t1 t2 -> typeSub t2 t3 -> typeSub t1 t3.
Proof.
intros t1 t2 t3 HSubL HSubR.
Admitted.
