- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proving transitiviy of simple type system
- Date: Tue, 3 Oct 2023 00:51:02 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=lasse AT blaauwbroek.eu; spf=Pass smtp.mailfrom=lasse AT blaauwbroek.eu; spf=None smtp.helo=postmaster AT mail.blaauwbroek.eu
- Ironport-data: A9a23:DNVYhayEeHlHn04muNx6t+eIwCrEfRIJ4+MujC+fZmUNrF6WrkUCx zNKDGrVbvnbZWakcopxOYnl/E8FuZGHn9VqGQdqpVhgHilAwSbnLYTAfx2oZ0t+DeWaERk5t 51GAjXkBJppJpMJjk71atANlVEliefSAOCU5NfsYkhZXRVjRDoqlSVtkus4hp8AqdWiCmthg /uryyHkEAHjg2Uc3l48sfrZ80o35K6q4lv0g3RnDRx1lA+G/5UqJMlHTU2BByOQapVZGOe8W 9HCwNmRlo8O10pF5nuNy94XQ2VSKlLgFVDmZkl+B8BOtiN/Shkaic7XAhazhXB/0F1ll/gpo DlEWAfZpQ0BZsUgk8xFO/VU/r0X0QSrN9YrLFDm2fF/wXEqfFPRhN5zDn0GEbYC1eZHA3100 s4pciECO0Xra+KemNpXS8Fpj8UnasPvNYoCpXt6yjzaS/s7KXzBa/yauJkCgHFq3JgIQq+2i 8kxMVKDaDzEagZUN38dDJs3gfiinH7ycHtVtTp5oIJuuTmLnFMhi+GF3Nz9RYyJGOJIh12h/ jiYoG34DAo9D5+k1m/Qmp6rrqqV9c/hY6oZE6T9/fp3inWI12kLAVsXU0G6qL+3kCaDt8l3L kUV/mwkqaE76VOhVN7wXFu1vRZooyIhZjaZKMVigCnl90Yey1/x6rEsHm4fOu81/tQ7XyIr3 VKvltbkT24n+r6MRH7Xsv/eoTquMGJHZSUPdA0VfzsjutPDmYAUig6Qb9BBFKXusMb5Nwuty B+3rQ8/pY4ps+g164uB82r63g2c/qryclZt5yH8fH6U0QdiVYv0O62q8Qf66NhDHqa4T36An nkOtOae4NACDJqIxSiEUbgJEIqI/NeACiXX2nR0Lqki9hOs2n+tRp9R6zdAP3VUMt4IVDvqQ U3LsyZT2cNjB2SrZqpJfI6BMcQm4qz+H9DDVPqPTN5xTrVuVQ2ApgdCWFWx2j3zrU0Sjq0PA 5eXXsKyB3I8C6487j6XRf8Y4IA71BIF2mLfapDq/SuJiYPESiaudo4EF1+SYsQSzqCO+lzV+ ukCEfq68UxUVemmbxTH9YIWE0sxEkE6IpLI+uh3be+IJzR0FF4xU8HxxawTQK07vqB3uNqRw FSDdB558mfvvVzGNgSAVV57YpzNQ5tUjCw2LA4sD3mSylkhZoel04kHfbBqfLMI2uxv/fJ1R PxUf8yRX/BDcRXc2jEndZKmhpdTRBeqogOvPiSefzk0eaB7dTHJ4tPJegjO9jEEKzie7O8Sg uSH+FvAYJwhQw9CMp7nWMi3xQnsgUlHyfNAYUTYB/JyJmPuydFOAA7shKYVJ8osF03y9gGC3 VzLPSZC9Pj/mK5rwtznnqvekpyIFdF5FU9kH2X2y7a6GC3Z32i7y797T+e6UmHBZVzw5ZmdS 71Z/9PkPN0DuWR6gY52PrJo7KA5vtXUt+B7yCZgFy71dFiFMO5rDUSH+shtjZdz4IFllzG4Y W+1wekCC461YJvkNHUzODsaav+y0KBIuzvKstUwDkbIxA5227ulUE99ERmAuCBcJ74kNIo0n OMtg+8NygmFkhFxGM23viNV0GWtL3I7TKQssK8BMrLrkgYGzlJjY4TWLy3LvKG0dNRHN3c1L g+uhKbtg6pWwmzAeSEREUfh8PV8h5NUnjx3134Hekq0n+Tais8N3BF+9So9SiJXxE5l18NxI m1aCF1nF56R/jtHhNlxYE70IltvXCamw03Wz0cFsEb7TEPyD2zEEzAbCNa3pUsc9zpRQyhf8 LSm013aaDfNfv+g7htqDAQh47bmQMdq/wLPpNG/Eo7XV9MmaD7imem1aXBOtxLjBtgriVbao fVxutx9crD/KTVatphT51N2DljMYEvsyK1+rfBdEGchGGjdfHe43TGHNl+7YMRAJLrH7CdUz iCoyt1nD3yDOOSm91j3xpLg55d+mPcg+cUIYLTmJigLrtNzaxJ35YnI+HGWaHADGr1TfAVUF m8VXziGG2WNmnFOnGLO6sRZUoZ9jR/oeyWktN2IHC41+17vfQ2inYzeEld5gplNDDZawg==
- Ironport-hdrordr: A9a23:32IohaDwl8xFd2zlHem755DYdb4zR+YMi2TDpHoQdfU1SKalfq +V8MjzuSWE7Qr5HUtQ/exoW5PufZq/z/NICOAqVN/IYOClghrLEGgI1+rfKlPbak7DH6Jmu5 tdTw==
- Ironport-phdr: A9a23:Xq2g+BSeA8Z8/Z/UJYtLjaRQhNpsoseZAWYlg6HP6ppLe6WnpdH5O VDHoO9qhxnPVJna7PRNj6zXtbrhUCoO+8XJq2gMJbpLURJNksAKh0o4GsfQDUTgN/PCZSgzF dldXkVi8nL9PFUGUN3maQjqq2appSUXBg25MAN0IurvHYuHi82szO2a8ZnaahhXjiC6bLA0I Qjl5R7JuJwwho1vYr001gOPonZMfLFOwnh0IFuIgxvmzsK5/Zol+SBZsu8+/dRHXKa8crlQo aVwKjMgPih14cTqsUOGVg6T/j4GVW5QlBNUAg/D5RW8X5HrsyK8uPAvkC+dddb7S7w5Q1HAp +9iVQPohSEbNjU47HCfi8p+i7heqQ6goBo3ypDdYYWcPv5zNq3HetZSSW1EV8dXHytPZ+H0J 48GFPEMFexcpoDguFEUqha9QwSxRavuxjJOmn7qzPgiye1yWQrC3QEmA5cPqCGN/IizbvtUC 7rtivaRnlChJ7tM1Dzw6ZbFaEUkqPCIB/drdNbJjFMoHEXDh0mRrorsO3WU0P4Mui6V9bkFN 6rnhmg5pgV2ujXqyN0rj9yDgosO0V3s/yFwyZsqL8e/RU09bMPuQ/4y/2mKcpB7RM8vWTQiv C8h0bAus5qydTUVwo4gyh2ZZuHNIO3qqlrzEe2WJzl/nndsfrmy0g2z/UaXwer5TsCo0VxOo 0Kpi/H0v2sWn1zW48mDEL5m+1u5nCyI3EbV4/1FJkY9kezaLYQgy/g+jMhbvUPGFy7w0EL46 c3ePkEt4fOlw+7ja7z7uZWGMIJ3zAzjeqgjgc2wB+0kPxNGBjjGv77gkue5pQumGf1DlbUun 7PcsYzGKMh+xObxGAJT3os5ql6+AzqgzNUEjCwCJVNBdgiAituhMFXPLfbkSPan1g38zXExm 7acZOWnXcyeSxqL2K3sdrt89UNGnQ86zNQFoolRFqlEOvX4HEn4qN3fCBY9dQ2y2efuTttnh eZ8ESqCBLGUNKTKvBqG/OUqdqOIbZQOtR73L/Es+uHkl3g0mhkQYOP6uPlfIGD9BflgL0iDN DDoi8waHE8AugM3UfPgklqPUnheejzhOsB0riF+A4WgA4DZQ4mri7HUxya3EKpdYWVeA0yNG 3PlJM2UHu0BYyWILop9gyQJAPK/HpQ520jk52qYg/J3a/DZ8SoCudf/2chpsqfNwAoq+2U8C tTV2imbRmVw1AvkXhcQ26Zy6Qx4w1aHi+1jhuBAUMZU7LVPWxs7MpjVy6p7DcrzU0TPZIXBT lHuWdigDTwrK7B5i9YTf0ZwHcmjhRHfzmKrBbESjbmCGJ0z9OrVwXHwI893z3uO2rMmihEqR c5GNGvugaAalUCbH4nSj0CQjLqnb4wZ1S/Jsm2HxGOTo0tCVwNzF6jYHDgeakbQsdXl9xbCQ rupWtFFekNKzc+PLLcPa8W81AUbAq2/fo6EOyTuwjTVZ17A3L6HYYv0dn9I2SzcDBJBiAUP5 TOcMgN4AC69omXYBTgoFFT1Ykqq//MtzRHzBkIy0QyOaFVskrSv/RtAz/iVUOge9rgAsS48t D9uG1u+md/LQYnlxUIpbOBHbNUx7U0Sn3rerBB4N4e8IrpKg1cfd0J9u0rnygp9EIJNko4ns Tl5qWg6YbLd21RHeTSC2Jn2MbCCMWj+8iekbKvO003f2tKbkk/uwPExqlGltgWgH1c9+W9g3 toT3mbOvv0i4yIYVZv4T1k97R93pPfXf3tkj2sx/XdoOKCprTXY3N8qQuY4mE7IQg==
- Ironport-sdr: 651b495f_y73N49near1iAyoIl1qqLNZglDs8fjAX9ZC2DAKEsyCJAJi aGBWeKFMiJuB4iagXTcZY/IxUnyuog31UymV3ig==
Well, I feel that this is a bit subtle. If you look at the
original F-sub paper [1], they do have a transitivity axiom. As
far as I know, transitivity is not provable in that system when
you remove the axiom. The POPLMark challenge [2], on the other
hand, contains an "algorithmic" version of the "declarative"
version in [1]. There, the "scope" of the transitive axiom is
reduced to variables, and then one can indeed prove the more
general transitivity rules. Same goes for reflexivity. (If you are
not willing to have a full reflexivity axiom, you will have to add
separate axioms for all "base" types in your language.)
Which presentation version to prefer probably depends mostly on your preferences and use-case. The declarative version is certainly more standard. But indeed, Frédéric is probably exclusively interested in algorithmic presentations here.
Regards,
Lasse
Sent: Monday, October 2, 2023 6:15:40 PM
To: coq-club AT inria.fr <coq-club AT inria.fr>
believe that the crucial point is still that this subtyping relation is
trivial. As far as I know, for most sufficiently "interesting" subtyping
relations, transitivity and reflexivity are not provable without
axiomatizing them. That is, you have to add reflexivity and transitivity
constructors (unless you modify all other constructors such that
transitivity is "built-in", but that amounts to the same thing). For
example, as soon as you have type variables you will not be able to
prove "\alpha < \alpha" without the axiom.
I'd be curious to know what kind of type-system you have in mind where
this is not needed?
On 02-10-2023 23:43, Jean-Marie Madiot wrote:
> Hello Frédéric,
> One standard "Coq trick" that you may already know is to generalize
> the statement before performing the induction, typically by doing
> something like "revert t3 HSubR; induction HSubL" or "revert t1
> HSubL; induction HSubR" in your example.
> However typeSub is contravariant in one of its argument, which makes
> things more interesting: only generalizing for all "HSubL" or for all
> "HSubR" won't be enough, you need to be able to switch sides.
> Suppose that you have a coarser (hence non trivial) subtyping relation
> such as
> Inductive typeSub : type -> type -> Prop :=
> | SubTUnit : typeSub TUnit TUnit
> | SubTFunUnit : forall ti to, typeSub (TFun ti to) TUnit
> | SubTFun : forall ti1 to1 ti2 to2, typeSub ti2 ti1 -> typeSub to1 to2
> -> typeSub (TFun ti1 to1) (TFun ti2 to2).
> Infix "<" := typeSub.
> Then you can generalize on both sides in this way:
> Lemma trans_aux t1 t2 : t1 < t2 -> (forall x, x < t1 -> x < t2) /\
> (forall x, t2 < x -> t1 < x).
> Proof.
> intros HSub; induction HSub; split; intros x Hx; inversion Hx;
> subst; constructor; firstorder.
> Qed.
> Lemma trans: forall t1 t2 t3, t1 < t2 -> t2 < t3 -> t1 < t3.
> Proof.
> intros t1 t2 t3 HSubL.
> apply trans_aux, HSubL.
> Qed.
> Regards,
> Jean-Marie
> Le 02/10/2023 à 19:53, Frederic Fort a écrit :
>> Hello,
>> I am trying to prove the some facts about the type system of a simple
>> Lambda calculus. However, I struggle to prove the transitivity of the
>> subtype relation.
>> I have seen in papers that certain people simply "axiomatize"
>> properties like transitivity and reflexivity by defining specific
>> rules for these properties.
>> However, I find this inelegant as this makes proofs in other places
>> more "cluttered" due to the additional constructors.
>> I have a few proofs that work fine. For transitivity however, I am
>> stuck.
>> I have tried all kinds of (dependent) induction approaches, but I am
>> generally stuck either because Coq requires me to prove that the unit
>> type is a subtype of a function type or because the induction
>> hypothesis doesn't take into account that subtyping of function input
>> types is in the "opposite direction".
>> I suppose that there is some "Coq trick" that I am unfamiliar with
>> (maybe I have to define a custom induction scheme ?).
>> Or maybe it is actually impossible to prove transitivity like that.
>> If somebody could show me what I am missing, I'd be grateful.
>> Yours sincerely,
>> Frédéric Fort
>> Here are my definitions:
>> Inductive expr :=
>> | Unt
>> | Var (n : nat)
>> | Lam (v : nat) (e : expr)
>> | App (f : expr) (arg : expr)
>> Inductive type :=
>> | TUnit
>> | TFun (tin tout : type)
>> to2 -> typeSub (TFun ti1 to1) (TFun ti2 to2)
>> Lemma refl:
>> forall t, typeSub t t.
>> Proof.
>> intros.
>> induction t; constructor; auto.
>> Qed.
>> Lemma sub_is_eq:
>> forall t1 t2, typeSub t1 t2 -> t1 = t2.
>> Proof.
>> intros.
>> induction H.
>> - reflexivity.
>> - rewrite IHtypeSub1. rewrite IHtypeSub2. reflexivity.
>> Qed.
>> Lemma trans:
>> forall t1 t2 t3,
>> typeSub t1 t2 -> typeSub t2 t3 -> typeSub t1 t3.
>> Proof.
>> intros t1 t2 t3 HSubL HSubR.
>> Admitted.
- [Coq-Club] Proving transitiviy of simple type system, Frederic Fort, 10/02/2023
- Re: [Coq-Club] Proving transitiviy of simple type system, Jason Hu, 10/02/2023
- Re: [Coq-Club] Proving transitiviy of simple type system, Lasse Blaauwbroek, 10/02/2023
- Re: [Coq-Club] Proving transitiviy of simple type system, Frederic Fort, 10/02/2023
- Re: [Coq-Club] Proving transitiviy of simple type system, Jean-Marie Madiot, 10/02/2023
- Re: [Coq-Club] Proving transitiviy of simple type system, Lasse Blaauwbroek, 10/03/2023
- Re: [Coq-Club] Proving transitiviy of simple type system, Jason Hu, 10/03/2023
- Re: [Coq-Club] Proving transitiviy of simple type system, Thorsten Altenkirch, 10/03/2023
- Re: [Coq-Club] Proving transitiviy of simple type system, Xavier Leroy, 10/03/2023
