Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Compiling starpu on Mac OS
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: tog <guillaume.alleon@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr, Raymond Namyst <Raymond.Namyst@labri.fr>
  • Subject: Re: [Starpu-devel] Compiling starpu on Mac OS
  • Date: Fri, 01 Apr 2011 15:31:42 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Looks like the new variable STARPU_CUDA_LDFLAGS has not been added when calling the linker. I might have forgotten to update some commands.
I supposed you called again "autogen.sh" and "configure" ? Running make distclean might also help. Are you getting the error when calling make ? Could you please send its whole output ?
Thanks,
Nathalie
On 01/04/2011 15:21, tog wrote:
Hi,
I did the update but still got a similar problem
Is there something I can do in order to help you ?
Best Regards
Guillaume
oggy:starpu alleon$ svn update
U mpi/Makefile.am
U src/Makefile.am
U src/datawizard/write_back.c
U src/datawizard/coherency.c
U tools/Makefile.am
D tests/datawizard/wt_broadcast.c
D tests/datawizard/wt_host.c
A tests/opt
A tests/opt/Makefile.am
A tests/opt/datawizard
A tests/opt/datawizard/wt_host.c
A tests/opt/datawizard/wt_broadcast.c
U tests/Makefile.am
U configure.ac
U Makefile.am
U examples/stencil/Makefile.am
U examples/Makefile.am
U examples/starpufft/Makefile.am
Updated to revision 3436.
libtool: link: gcc -dynamiclib -o .libs/libstarpu.0.dylib
.libs/libstarpu_la-barrier.o .libs/libstarpu_la-hash.o
.libs/libstarpu_la-htable32.o .libs/libstarpu_la-rwlock.o
.libs/libstarpu_la-starpu_spinlock.o .libs/libstarpu_la-timing.o
.libs/libstarpu_la-fxt.o .libs/libstarpu_la-utils.o
.libs/libstarpu_la-jobs.o .libs/libstarpu_la-task.o
.libs/libstarpu_la-task_bundle.o .libs/libstarpu_la-workers.o
.libs/libstarpu_la-combined_workers.o .libs/libstarpu_la-topology.o
.libs/libstarpu_la-debug.o .libs/libstarpu_la-errorcheck.o
.libs/libstarpu_la-progress_hook.o .libs/libstarpu_la-cg.o
.libs/libstarpu_la-dependencies.o
.libs/libstarpu_la-implicit_data_deps.o .libs/libstarpu_la-tags.o
.libs/libstarpu_la-task_deps.o .libs/libstarpu_la-htable.o
.libs/libstarpu_la-data_concurrency.o
.libs/libstarpu_la-perfmodel_history.o
.libs/libstarpu_la-perfmodel_bus.o .libs/libstarpu_la-perfmodel.o
.libs/libstarpu_la-regression.o .libs/libstarpu_la-sched_policy.o
.libs/libstarpu_la-priorities.o .libs/libstarpu_la-parallel_task.o
.libs/libstarpu_la-eager_central_policy.o
.libs/libstarpu_la-eager_central_priority_policy.o
.libs/libstarpu_la-work_stealing_policy.o
.libs/libstarpu_la-deque_modeling_policy_data_aware.o
.libs/libstarpu_la-heft.o .libs/libstarpu_la-random_policy.o
.libs/libstarpu_la-stack_queues.o .libs/libstarpu_la-deque_queues.o
.libs/libstarpu_la-fifo_queues.o
.libs/libstarpu_la-detect_combined_workers.o
.libs/libstarpu_la-parallel_heft.o
.libs/libstarpu_la-parallel_greedy.o
.libs/libstarpu_la-driver_common.o .libs/libstarpu_la-memory_nodes.o
.libs/libstarpu_la-write_back.o .libs/libstarpu_la-coherency.o
.libs/libstarpu_la-data_request.o .libs/libstarpu_la-progress.o
.libs/libstarpu_la-copy_driver.o .libs/libstarpu_la-filters.o
.libs/libstarpu_la-sort_data_handles.o .libs/libstarpu_la-memalloc.o
.libs/libstarpu_la-footprint.o .libs/libstarpu_la-datastats.o
.libs/libstarpu_la-user_interactions.o .libs/libstarpu_la-reduction.o
.libs/libstarpu_la-data_interface.o
.libs/libstarpu_la-bcsr_interface.o .libs/libstarpu_la-csr_interface.o
.libs/libstarpu_la-matrix_filters.o
.libs/libstarpu_la-matrix_interface.o
.libs/libstarpu_la-block_filters.o
.libs/libstarpu_la-block_interface.o
.libs/libstarpu_la-vector_interface.o
.libs/libstarpu_la-bcsr_filters.o .libs/libstarpu_la-csr_filters.o
.libs/libstarpu_la-vector_filters.o
.libs/libstarpu_la-variable_interface.o
.libs/libstarpu_la-void_interface.o .libs/libstarpu_la-malloc.o
.libs/libstarpu_la-execute_on_all.o
.libs/libstarpu_la-starpu_create_sync_task.o
.libs/libstarpu_la-starpu_cublas.o .libs/libstarpu_la-file.o
.libs/libstarpu_la-starpu_data_cpy.o
.libs/libstarpu_la-starpu_insert_task.o
.libs/libstarpu_la-starpu_insert_task_utils.o
.libs/libstarpu_la-starpu_task_list.o .libs/libstarpu_la-starpu_fxt.o
.libs/libstarpu_la-starpu_fxt_mpi.o
.libs/libstarpu_la-starpu_fxt_dag.o .libs/libstarpu_la-starpu_paje.o
.libs/libstarpu_la-latency.o .libs/libstarpu_la-structures_size.o
.libs/libstarpu_la-profiling.o .libs/libstarpu_la-bound.o
.libs/libstarpu_la-profiling_helpers.o .libs/libstarpu_la-driver_cpu.o
.libs/libstarpu_la-driver_cuda.o -L/usr/local/cuda/lib -lm -lblas
-lpthread -install_name /usr/local/lib/libstarpu.0.dylib
-compatibility_version 1 -current_version 1.0 -Wl,-single_module
Undefined symbols:
"_cudaThreadExit", referenced from:
_benchmark_all_gpu_devices in libstarpu_la-perfmodel_bus.o
__starpu_cuda_worker in libstarpu_la-driver_cuda.o
"_cudaMemcpy2D", referenced from:
_copy_ram_to_cuda_async in libstarpu_la-matrix_interface.o
_copy_cuda_to_ram_async in libstarpu_la-matrix_interface.o
_copy_cuda_to_ram in libstarpu_la-matrix_interface.o
_copy_cuda_to_cuda in libstarpu_la-matrix_interface.o
_copy_ram_to_cuda in libstarpu_la-matrix_interface.o
_copy_cuda_async_common in libstarpu_la-block_interface.o
_copy_cuda_common in libstarpu_la-block_interface.o
"_cudaMemcpy2DAsync", referenced from:
"_cudaFree", referenced from:
_free_bcsr_buffer_on_node in libstarpu_la-bcsr_interface.o
_allocate_bcsr_buffer_on_node in libstarpu_la-bcsr_interface.o
_free_csr_buffer_on_node in libstarpu_la-csr_interface.o
_allocate_csr_buffer_on_node in libstarpu_la-csr_interface.o
_free_matrix_buffer_on_node in libstarpu_la-matrix_interface.o
_free_block_buffer_on_node in libstarpu_la-block_interface.o
_free_vector_buffer_on_node in libstarpu_la-vector_interface.o
_free_variable_buffer_on_node in libstarpu_la-variable_interface.o
"_cudaHostAlloc", referenced from:
_malloc_pinned_cuda_codelet in libstarpu_la-malloc.o
"_cudaEventCreate", referenced from:
__starpu_driver_copy_data_1_to_1 in libstarpu_la-copy_driver.o
"_cublasShutdown", referenced from:
_shutdown_cublas_func in libstarpu_la-starpu_cublas.o
"_cudaMemcpy", referenced from:
_copy_cuda_common in libstarpu_la-bcsr_interface.o
_copy_cuda_common in libstarpu_la-csr_interface.o
_copy_cuda_async_common in libstarpu_la-vector_interface.o
_copy_cuda_to_ram in libstarpu_la-vector_interface.o
_copy_cuda_to_cuda in libstarpu_la-vector_interface.o
_copy_ram_to_cuda in libstarpu_la-vector_interface.o
_copy_cuda_to_ram_async in libstarpu_la-variable_interface.o
_copy_cuda_to_ram in libstarpu_la-variable_interface.o
_copy_ram_to_cuda_async in libstarpu_la-variable_interface.o
_copy_cuda_to_cuda in libstarpu_la-variable_interface.o
_copy_ram_to_cuda in libstarpu_la-variable_interface.o
"_cudaEventSynchronize", referenced from:
__starpu_driver_wait_request_completion in libstarpu_la-copy_driver.o
"_cudaThreadSynchronize", referenced from:
"_cudaEventRecord", referenced from:
"_cudaMemcpyAsync", referenced from:
"_cudaGetErrorString", referenced from:
_allocate_matrix_buffer_on_node in libstarpu_la-matrix_interface.o
_allocate_block_buffer_on_node in libstarpu_la-block_interface.o
_allocate_vector_buffer_on_node in libstarpu_la-vector_interface.o
_allocate_variable_buffer_on_node in libstarpu_la-variable_interface.o
_free_pinned_cuda_codelet in libstarpu_la-malloc.o
"_cudaEventDestroy", referenced from:
__starpu_driver_test_request_completion in libstarpu_la-copy_driver.o
"_cudaMemset", referenced from:
"_cudaEventQuery", referenced from:
"_cudaGetDeviceCount", referenced from:
__starpu_load_bus_performance_files in libstarpu_la-perfmodel_bus.o
__starpu_get_cuda_device_count in libstarpu_la-driver_cuda.o
__starpu_init_cuda in libstarpu_la-driver_cuda.o
"_cudaFreeHost", referenced from:
"_cudaGetDeviceProperties", referenced from:
"_cudaMalloc", referenced from:
"_cudaStreamDestroy", referenced from:
"_cublasSetKernelStream", referenced from:
_init_cublas_func in libstarpu_la-starpu_cublas.o
"_cudaStreamSynchronize", referenced from:
"_cublasInit", referenced from:
"_cudaSetDevice", referenced from:
"_cudaStreamCreate", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[2]: *** [libstarpu.la] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
Haut de le page
