Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Compiling starpu on Mac OS
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr, Raymond Namyst <Raymond.Namyst@labri.fr>
  • Subject: Re: [Starpu-devel] Compiling starpu on Mac OS
  • Date: Fri, 1 Apr 2011 19:59:56 +0530
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=YDgeAveMBEY/A0KkS/tF5alPen1Ev0NI4MGkcQAGdLqzfuiRafe91GMLVnsdluUrht IE3/BJpK/rABApFXnlvLaReiwu6PHPnawyfTxD+cVUvmtbzeQNVLREqEkMHwjTLhHZNI QMRCz/QvnNe1fKajrJ0vFtOQgZodYgmHs7w1s=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Looks better. the library seems to be generated. Got a problem in the
examples.
What can be done to test the framework ?
Best Regards
Guillaume
On Fri, Apr 1, 2011 at 7:47 PM, Nathalie Furmento
<nathalie.furmento@labri.fr> wrote:
> Thanks. Could you please try with the following patch?
> Regards,
> Nathalie
> On 01/04/2011 15:57, tog wrote:
>> Yes, I restarted everything from the very beginning.
>> Here are both logs
>> Regards
>> Guillaume
>> On Fri, Apr 1, 2011 at 7:01 PM, Nathalie Furmento
>>> Looks like the new variable STARPU_CUDA_LDFLAGS has not been added when
>>> calling the linker. I might have forgotten to update some commands.
>>> I supposed you called again "autogen.sh" and "configure" ? Running make
>>> distclean might also help. Are you getting the error when calling make ?
>>> Could you please send its whole output ?
>>> Thanks,
>>> Nathalie
>>> On 01/04/2011 15:21, tog wrote:
>>>> Hi,
>>>> I did the update but still got a similar problem
>>>> Is there something I can do in order to help you ?
>>>> Best Regards
>>>> Guillaume
PGP KeyID: 2048R/EA31CFC9  subkeys.pgp.net
Attachment: all.log.gz
Description: GNU Zip compressed data
Haut de le page
