Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] setting the clBuildProgram() option parameter
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] setting the clBuildProgram() option parameter
  • Date: Tue, 05 Apr 2011 01:39:08 +1000
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
clBuildProgram() is called within starpu_opencl_load_opencl_from_string() with a hard-coded options parameter of "-Werror -cl-mad-enable". I would like to be able to set different options, such as include paths and macro definitions for the opencl kernels I am using with starpu.
If I were to add support for different option strings, what would be an appropriate/preferred way to do so? Options I can see are:
- extra parameter passed to the function (which needs to be added to other functions, too)
- extra const char* field in struct starpu_opencl_program (one option for all opencl programs)
- array of const char* fields in struct starpu_opencl_program, one for each program
- environment variable
Thanks
Jonathan.
Haut de le page
