Archives de la liste
- To: Jonathan Adamczewski <jadamcze@utas.edu.au>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] setting the clBuildProgram() option parameter
- Date: Tue, 05 Apr 2011 08:21:20 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi, Nathalie, I see that according to the doc: -cl-mad-enable "Allow a * b + c
to be replaced by a mad. The mad computes a * b + c
with reduced accuracy". I guess we don't want that in the general
case either... Otherwise this all looks good, thanks a lot! Just
being picky: if we really want to enforce -Werror, can't we append
the user-provided string with -Werror for instance?Best, Cédric On 05/04/2011 07:20, Jonathan Adamczewski wrote: 4D9AA693.8040900@utas.edu.au">Thank you - that works well. |
- [Starpu-devel] setting the clBuildProgram() option parameter, Jonathan Adamczewski, 04/04/2011
- Re: [Starpu-devel] setting the clBuildProgram() option parameter, Cédric Augonnet, 04/04/2011
- Re: [Starpu-devel] setting the clBuildProgram() option parameter, Nathalie Furmento, 04/04/2011
- Re: [Starpu-devel] setting the clBuildProgram() option parameter, Jonathan Adamczewski, 05/04/2011
- Re: [Starpu-devel] setting the clBuildProgram() option parameter, Cédric Augonnet, 05/04/2011
