Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] setting the clBuildProgram() option parameter
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] setting the clBuildProgram() option parameter
  • Date: Tue, 05 Apr 2011 15:20:19 +1000
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thank you - that works well.
j.
On 05/04/11 07:27, Nathalie Furmento wrote:
All,
I updated the OpenCL kernel to provide an extra parameter
build_options to the appropriate functions. A NULL value will fall
back on the default value"-Werror -cl-mad-enable".
Best,
Nathalie
On 04/04/2011 19:01, Cédric Augonnet wrote:
On 04/04/2011 17:39, Jonathan Adamczewski wrote:
clBuildProgram() is called within
starpu_opencl_load_opencl_from_string() with a hard-coded
options parameter of "-Werror -cl-mad-enable". I would like to
be able to set different options, such as include paths and
macro definitions for the opencl kernels I am using with starpu.
If I were to add support for different option strings, what
would be an appropriate/preferred way to do so? Options I can
see are:
- extra parameter passed to the function (which needs to be
added to other functions, too)
- extra const char* field in struct starpu_opencl_program (one
option for all opencl programs)
- array of const char* fields in struct starpu_opencl_program,
one for each program
- environment variable
Thanks
Jonathan.
Hi Jonathan,
Thanks again for your valuable feedback! Would not an extra
"const char *" parameter to both
starpu_opencl_load_opencl_from_file and
starpu_opencl_load_opencl_from_string be sufficient ? This seems
to be the most natural and also the cleanest solution.
Best,
Cédric
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
