Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Jonathan Adamczewski <jadamcze@utas.edu.au>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] setting the clBuildProgram() option parameter
- Date: Mon, 04 Apr 2011 23:27:21 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
All,
I updated the OpenCL kernel to provide an extra parameter build_options to the appropriate functions. A NULL value will fall back on the default value"-Werror -cl-mad-enable".
Best,
Nathalie
On 04/04/2011 19:01, Cédric Augonnet wrote:
On 04/04/2011 17:39, Jonathan Adamczewski wrote:
clBuildProgram() is called within starpu_opencl_load_opencl_from_string() with a hard-coded options parameter of "-Werror -cl-mad-enable". I would like to be able to set different options, such as include paths and macro definitions for the opencl kernels I am using with starpu.Hi Jonathan,
If I were to add support for different option strings, what would be an appropriate/preferred way to do so? Options I can see are:
- extra parameter passed to the function (which needs to be added to other functions, too)
- extra const char* field in struct starpu_opencl_program (one option for all opencl programs)
- array of const char* fields in struct starpu_opencl_program, one for each program
- environment variable
Thanks
Jonathan.
Thanks again for your valuable feedback! Would not an extra "const char *" parameter to both starpu_opencl_load_opencl_from_file and starpu_opencl_load_opencl_from_string be sufficient ? This seems to be the most natural and also the cleanest solution.
Best,
Cédric
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] setting the clBuildProgram() option parameter, Jonathan Adamczewski, 04/04/2011
- Re: [Starpu-devel] setting the clBuildProgram() option parameter, Cédric Augonnet, 04/04/2011
- Re: [Starpu-devel] setting the clBuildProgram() option parameter, Nathalie Furmento, 04/04/2011
- Re: [Starpu-devel] setting the clBuildProgram() option parameter, Jonathan Adamczewski, 05/04/2011
- Re: [Starpu-devel] setting the clBuildProgram() option parameter, Cédric Augonnet, 05/04/2011
