Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Error while building StarpU library
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: ASD D <ajitsdeshpande@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Error while building StarpU library
  • Date: Thu, 27 Oct 2011 18:29:48 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
ASD D, le Thu 27 Oct 2011 18:22:30 +0200, a écrit :
> /usr/bin/ld: .libs/starpu_calibrate_bus: hidden symbol `stat' in /usr/lib/
> libc_nonshared.a(stat.oS) is referenced by DSO
> /usr/bin/ld: final link failed: Nonrepresentable section on output
Uh, how odd error... There's not even a reason why it should try to link
libc_nonshared.a in, and the stat symbol is not supposed to be hidden...
> Steps I follow are as below :
> 1] svn co svn://scm.gforge.inria.fr/svn/starpu/trunk
> 2] ./autogen.sh
> 3] ./configure --with-opencl-include-dir=openCLPath --with-opencl-lib-dir=
> openCLLibPath--enable-debug --enable-verbose
> where openCLPath & openCLLibPath is correct path on my system
> 4] make . This step generates the linker error shown above
> Any pointers about what I am doing wrong and solution to fix it would help.
There is nothing wrong in what you did, all this work just fine on our
machines. Please post the full log of the output, config.log, and also
try without opencl, in case that could be the trigger.
Samuel
Haut de le page
