Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Error while building StarpU library
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, ASD D <ajitsdeshpande@gmail.com>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Error while building StarpU library
  • Date: Thu, 27 Oct 2011 17:48:22 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
  Hope attachments are allowed to this list. Please find attached the config.log (with opencl), the full make log attached(makeerrorlog.txt is make 2> makeerrorlog.txt and makelog.txt is make 1>makelog.txt) .
 Please let know if anything amiss there.
Will try w/o opencl and check and let know its status.
thanks,
-AD.
On Thu, Oct 27, 2011 at 5:29 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
ASD D, le Thu 27 Oct 2011 18:22:30 +0200, a écrit :
> /usr/bin/ld: .libs/starpu_calibrate_bus: hidden symbol `stat' in /usr/lib/
> libc_nonshared.a(stat.oS) is referenced by DSO
> /usr/bin/ld: final link failed: Nonrepresentable section on output
Uh, how odd error... There's not even a reason why it should try to link
libc_nonshared.a in, and the stat symbol is not supposed to be hidden...
> Steps I follow are as below :
> 1] svn co svn://scm.gforge.inria.fr/svn/starpu/trunk
> 2] ./autogen.sh
> 3] ./configure --with-opencl-include-dir=openCLPath --with-opencl-lib-dir=
> openCLLibPath--enable-debug --enable-verbose
> where openCLPath & openCLLibPath is correct path on my system
> 4] make . This step generates the linker error shown above
> Any pointers about what I am doing wrong and solution to fix it would help.
There is nothing wrong in what you did, all this work just fine on our
machines.  Please post the full log of the output, config.log, and also
try without opencl, in case that could be the trigger.
Samuel
core/perfmodel/perfmodel_history.c: In function 'parse_arch':
core/perfmodel/perfmodel_history.c:221: warning: comparison between signed
and unsigned integer expressions
core/perfmodel/perfmodel_history.c:225: warning: comparison between signed
core/perfmodel/perfmodel_history.c:237: warning: comparison between signed
core/perfmodel/perfmodel_history.c:238: warning: comparison between signed
core/perfmodel/perfmodel_history.c:242: warning: comparison between signed
sched_policies/work_stealing_policy.c:122: warning: 'select_workerq' defined
but not used
datawizard/coherency.c: In function 'link_supports_direct_transfers':
datawizard/coherency.c:178: warning: unused parameter 'handle'
profiling/profiling_helpers.c: In function
'starpu_worker_profiling_helper_display_summary':
profiling/profiling_helpers.c:80: warning: format '%lu' expects type 'long
unsigned int', but argument 3 has type 'uint64_t'
unsigned int', but argument 4 has type 'uint64_t'
drivers/opencl/driver_opencl.c: In function 'limit_gpu_mem_if_needed':
drivers/opencl/driver_opencl.c:64: warning: format '%ld' expects type 'long
int', but argument 5 has type 'size_t'
int', but argument 6 has type 'unsigned int'
int', but argument 7 has type 'unsigned int'
int', but argument 8 has type 'unsigned int'
/usr/bin/ld: warning: libOpenCL.so, needed by ../src/.libs/libstarpu.so, not
found (try using -rpath or -rpath-link)
/usr/lib/libc_nonshared.a(stat.oS) is referenced by DSO
collect2: ld returned 1 exit status
make[2]: *** [starpu_calibrate_bus] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
Attachment: config.log
Description: Binary data
Making all in src
make[1]: Entering directory `/home/movidius/code/moviSimStarPU/trunk/src'
make[2]: Entering directory `/home/movidius/code/moviSimStarPU/trunk/src'
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I.
-I../src/common -I../include -I../gcc-plugin/src -I../include/ -D_GNU_SOURCE
-W -Wall -Wextra -I/home/movidius/code/moviSimStarPU/trunk/moviSim
-DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl -g -O2 -O0 -gdwarf-2
-g3 -MT libstarpu_la-barrier.lo -MD -MP -MF .deps/libstarpu_la-barrier.Tpo
-c -o libstarpu_la-barrier.lo `test -f 'common/barrier.c' || echo
'./'`common/barrier.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I../src/common -I../include
-I../gcc-plugin/src -I../include/ -D_GNU_SOURCE -W -Wall -Wextra
-g3 -MT libstarpu_la-barrier.lo -MD -MP -MF .deps/libstarpu_la-barrier.Tpo -c
common/barrier.c -fPIC -DPIC -o .libs/libstarpu_la-barrier.o
common/barrier.c -o libstarpu_la-barrier.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-barrier.Tpo .deps/libstarpu_la-barrier.Plo
-g3 -MT libstarpu_la-hash.lo -MD -MP -MF .deps/libstarpu_la-hash.Tpo -c -o
libstarpu_la-hash.lo `test -f 'common/hash.c' || echo './'`common/hash.c
common/hash.c -fPIC -DPIC -o .libs/libstarpu_la-hash.o
common/hash.c -o libstarpu_la-hash.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-hash.Tpo .deps/libstarpu_la-hash.Plo
-g3 -MT libstarpu_la-htable32.lo -MD -MP -MF .deps/libstarpu_la-htable32.Tpo
-c -o libstarpu_la-htable32.lo `test -f 'common/htable32.c' || echo
'./'`common/htable32.c
-c common/htable32.c -fPIC -DPIC -o .libs/libstarpu_la-htable32.o
-c common/htable32.c -o libstarpu_la-htable32.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-htable32.Tpo .deps/libstarpu_la-htable32.Plo
-g3 -MT libstarpu_la-rwlock.lo -MD -MP -MF .deps/libstarpu_la-rwlock.Tpo -c
-o libstarpu_la-rwlock.lo `test -f 'common/rwlock.c' || echo
'./'`common/rwlock.c
common/rwlock.c -fPIC -DPIC -o .libs/libstarpu_la-rwlock.o
common/rwlock.c -o libstarpu_la-rwlock.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-rwlock.Tpo .deps/libstarpu_la-rwlock.Plo
-g3 -MT libstarpu_la-starpu_spinlock.lo -MD -MP -MF
.deps/libstarpu_la-starpu_spinlock.Tpo -c -o libstarpu_la-starpu_spinlock.lo
`test -f 'common/starpu_spinlock.c' || echo './'`common/starpu_spinlock.c
.deps/libstarpu_la-starpu_spinlock.Tpo -c common/starpu_spinlock.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_spinlock.o
.deps/libstarpu_la-starpu_spinlock.Tpo -c common/starpu_spinlock.c -o
libstarpu_la-starpu_spinlock.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_spinlock.Tpo
.deps/libstarpu_la-starpu_spinlock.Plo
-g3 -MT libstarpu_la-timing.lo -MD -MP -MF .deps/libstarpu_la-timing.Tpo -c
-o libstarpu_la-timing.lo `test -f 'common/timing.c' || echo
'./'`common/timing.c
common/timing.c -fPIC -DPIC -o .libs/libstarpu_la-timing.o
common/timing.c -o libstarpu_la-timing.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-timing.Tpo .deps/libstarpu_la-timing.Plo
-g3 -MT libstarpu_la-fxt.lo -MD -MP -MF .deps/libstarpu_la-fxt.Tpo -c -o
libstarpu_la-fxt.lo `test -f 'common/fxt.c' || echo './'`common/fxt.c
common/fxt.c -fPIC -DPIC -o .libs/libstarpu_la-fxt.o
common/fxt.c -o libstarpu_la-fxt.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-fxt.Tpo .deps/libstarpu_la-fxt.Plo
-g3 -MT libstarpu_la-utils.lo -MD -MP -MF .deps/libstarpu_la-utils.Tpo -c -o
libstarpu_la-utils.lo `test -f 'common/utils.c' || echo './'`common/utils.c
common/utils.c -fPIC -DPIC -o .libs/libstarpu_la-utils.o
common/utils.c -o libstarpu_la-utils.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-utils.Tpo .deps/libstarpu_la-utils.Plo
-g3 -MT libstarpu_la-jobs.lo -MD -MP -MF .deps/libstarpu_la-jobs.Tpo -c -o
libstarpu_la-jobs.lo `test -f 'core/jobs.c' || echo './'`core/jobs.c
core/jobs.c -fPIC -DPIC -o .libs/libstarpu_la-jobs.o
core/jobs.c -o libstarpu_la-jobs.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-jobs.Tpo .deps/libstarpu_la-jobs.Plo
-g3 -MT libstarpu_la-task.lo -MD -MP -MF .deps/libstarpu_la-task.Tpo -c -o
libstarpu_la-task.lo `test -f 'core/task.c' || echo './'`core/task.c
core/task.c -fPIC -DPIC -o .libs/libstarpu_la-task.o
core/task.c -o libstarpu_la-task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-task.Tpo .deps/libstarpu_la-task.Plo
-g3 -MT libstarpu_la-task_bundle.lo -MD -MP -MF
.deps/libstarpu_la-task_bundle.Tpo -c -o libstarpu_la-task_bundle.lo `test -f
'core/task_bundle.c' || echo './'`core/task_bundle.c
.deps/libstarpu_la-task_bundle.Tpo -c core/task_bundle.c -fPIC -DPIC -o
.libs/libstarpu_la-task_bundle.o
.deps/libstarpu_la-task_bundle.Tpo -c core/task_bundle.c -o
libstarpu_la-task_bundle.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-task_bundle.Tpo .deps/libstarpu_la-task_bundle.Plo
-g3 -MT libstarpu_la-workers.lo -MD -MP -MF .deps/libstarpu_la-workers.Tpo
-c -o libstarpu_la-workers.lo `test -f 'core/workers.c' || echo
'./'`core/workers.c
-g3 -MT libstarpu_la-workers.lo -MD -MP -MF .deps/libstarpu_la-workers.Tpo -c
core/workers.c -fPIC -DPIC -o .libs/libstarpu_la-workers.o
core/workers.c -o libstarpu_la-workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-workers.Tpo .deps/libstarpu_la-workers.Plo
-g3 -MT libstarpu_la-combined_workers.lo -MD -MP -MF
.deps/libstarpu_la-combined_workers.Tpo -c -o
libstarpu_la-combined_workers.lo `test -f 'core/combined_workers.c' || echo
'./'`core/combined_workers.c
.deps/libstarpu_la-combined_workers.Tpo -c core/combined_workers.c -fPIC
-DPIC -o .libs/libstarpu_la-combined_workers.o
.deps/libstarpu_la-combined_workers.Tpo -c core/combined_workers.c -o
libstarpu_la-combined_workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-combined_workers.Tpo
.deps/libstarpu_la-combined_workers.Plo
-g3 -MT libstarpu_la-topology.lo -MD -MP -MF .deps/libstarpu_la-topology.Tpo
-c -o libstarpu_la-topology.lo `test -f 'core/topology.c' || echo
'./'`core/topology.c
-c core/topology.c -fPIC -DPIC -o .libs/libstarpu_la-topology.o
-c core/topology.c -o libstarpu_la-topology.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-topology.Tpo .deps/libstarpu_la-topology.Plo
-g3 -MT libstarpu_la-debug.lo -MD -MP -MF .deps/libstarpu_la-debug.Tpo -c -o
libstarpu_la-debug.lo `test -f 'core/debug.c' || echo './'`core/debug.c
core/debug.c -fPIC -DPIC -o .libs/libstarpu_la-debug.o
core/debug.c -o libstarpu_la-debug.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-debug.Tpo .deps/libstarpu_la-debug.Plo
-g3 -MT libstarpu_la-errorcheck.lo -MD -MP -MF
.deps/libstarpu_la-errorcheck.Tpo -c -o libstarpu_la-errorcheck.lo `test -f
'core/errorcheck.c' || echo './'`core/errorcheck.c
.deps/libstarpu_la-errorcheck.Tpo -c core/errorcheck.c -fPIC -DPIC -o
.libs/libstarpu_la-errorcheck.o
.deps/libstarpu_la-errorcheck.Tpo -c core/errorcheck.c -o
libstarpu_la-errorcheck.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-errorcheck.Tpo .deps/libstarpu_la-errorcheck.Plo
-g3 -MT libstarpu_la-progress_hook.lo -MD -MP -MF
.deps/libstarpu_la-progress_hook.Tpo -c -o libstarpu_la-progress_hook.lo
`test -f 'core/progress_hook.c' || echo './'`core/progress_hook.c
.deps/libstarpu_la-progress_hook.Tpo -c core/progress_hook.c -fPIC -DPIC -o
.libs/libstarpu_la-progress_hook.o
.deps/libstarpu_la-progress_hook.Tpo -c core/progress_hook.c -o
libstarpu_la-progress_hook.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-progress_hook.Tpo
.deps/libstarpu_la-progress_hook.Plo
-g3 -MT libstarpu_la-cg.lo -MD -MP -MF .deps/libstarpu_la-cg.Tpo -c -o
libstarpu_la-cg.lo `test -f 'core/dependencies/cg.c' || echo
'./'`core/dependencies/cg.c
core/dependencies/cg.c -fPIC -DPIC -o .libs/libstarpu_la-cg.o
core/dependencies/cg.c -o libstarpu_la-cg.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-cg.Tpo .deps/libstarpu_la-cg.Plo
-g3 -MT libstarpu_la-dependencies.lo -MD -MP -MF
.deps/libstarpu_la-dependencies.Tpo -c -o libstarpu_la-dependencies.lo `test
-f 'core/dependencies/dependencies.c' || echo
'./'`core/dependencies/dependencies.c
.deps/libstarpu_la-dependencies.Tpo -c core/dependencies/dependencies.c
-fPIC -DPIC -o .libs/libstarpu_la-dependencies.o
.deps/libstarpu_la-dependencies.Tpo -c core/dependencies/dependencies.c -o
libstarpu_la-dependencies.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-dependencies.Tpo .deps/libstarpu_la-dependencies.Plo
-g3 -MT libstarpu_la-implicit_data_deps.lo -MD -MP -MF
.deps/libstarpu_la-implicit_data_deps.Tpo -c -o
libstarpu_la-implicit_data_deps.lo `test -f
'core/dependencies/implicit_data_deps.c' || echo
'./'`core/dependencies/implicit_data_deps.c
core/dependencies/implicit_data_deps.c -fPIC -DPIC -o
.libs/libstarpu_la-implicit_data_deps.o
core/dependencies/implicit_data_deps.c -o libstarpu_la-implicit_data_deps.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-implicit_data_deps.Tpo
.deps/libstarpu_la-implicit_data_deps.Plo
-g3 -MT libstarpu_la-tags.lo -MD -MP -MF .deps/libstarpu_la-tags.Tpo -c -o
libstarpu_la-tags.lo `test -f 'core/dependencies/tags.c' || echo
'./'`core/dependencies/tags.c
core/dependencies/tags.c -fPIC -DPIC -o .libs/libstarpu_la-tags.o
core/dependencies/tags.c -o libstarpu_la-tags.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-tags.Tpo .deps/libstarpu_la-tags.Plo
-g3 -MT libstarpu_la-task_deps.lo -MD -MP -MF
.deps/libstarpu_la-task_deps.Tpo -c -o libstarpu_la-task_deps.lo `test -f
'core/dependencies/task_deps.c' || echo './'`core/dependencies/task_deps.c
.deps/libstarpu_la-task_deps.Tpo -c core/dependencies/task_deps.c -fPIC
-DPIC -o .libs/libstarpu_la-task_deps.o
.deps/libstarpu_la-task_deps.Tpo -c core/dependencies/task_deps.c -o
libstarpu_la-task_deps.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-task_deps.Tpo .deps/libstarpu_la-task_deps.Plo
-g3 -MT libstarpu_la-htable.lo -MD -MP -MF .deps/libstarpu_la-htable.Tpo -c
-o libstarpu_la-htable.lo `test -f 'core/dependencies/htable.c' || echo
'./'`core/dependencies/htable.c
core/dependencies/htable.c -fPIC -DPIC -o .libs/libstarpu_la-htable.o
core/dependencies/htable.c -o libstarpu_la-htable.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-htable.Tpo .deps/libstarpu_la-htable.Plo
-g3 -MT libstarpu_la-data_concurrency.lo -MD -MP -MF
.deps/libstarpu_la-data_concurrency.Tpo -c -o
libstarpu_la-data_concurrency.lo `test -f
'core/dependencies/data_concurrency.c' || echo
'./'`core/dependencies/data_concurrency.c
core/dependencies/data_concurrency.c -fPIC -DPIC -o
.libs/libstarpu_la-data_concurrency.o
core/dependencies/data_concurrency.c -o libstarpu_la-data_concurrency.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-data_concurrency.Tpo
.deps/libstarpu_la-data_concurrency.Plo
-g3 -MT libstarpu_la-perfmodel_history.lo -MD -MP -MF
.deps/libstarpu_la-perfmodel_history.Tpo -c -o
libstarpu_la-perfmodel_history.lo `test -f
'core/perfmodel/perfmodel_history.c' || echo
'./'`core/perfmodel/perfmodel_history.c
core/perfmodel/perfmodel_history.c -fPIC -DPIC -o
.libs/libstarpu_la-perfmodel_history.o
core/perfmodel/perfmodel_history.c -o libstarpu_la-perfmodel_history.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel_history.Tpo
.deps/libstarpu_la-perfmodel_history.Plo
-g3 -MT libstarpu_la-perfmodel_bus.lo -MD -MP -MF
.deps/libstarpu_la-perfmodel_bus.Tpo -c -o libstarpu_la-perfmodel_bus.lo
`test -f 'core/perfmodel/perfmodel_bus.c' || echo
'./'`core/perfmodel/perfmodel_bus.c
.deps/libstarpu_la-perfmodel_bus.Tpo -c core/perfmodel/perfmodel_bus.c -fPIC
-DPIC -o .libs/libstarpu_la-perfmodel_bus.o
.deps/libstarpu_la-perfmodel_bus.Tpo -c core/perfmodel/perfmodel_bus.c -o
libstarpu_la-perfmodel_bus.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel_bus.Tpo
.deps/libstarpu_la-perfmodel_bus.Plo
-g3 -MT libstarpu_la-perfmodel.lo -MD -MP -MF
.deps/libstarpu_la-perfmodel.Tpo -c -o libstarpu_la-perfmodel.lo `test -f
'core/perfmodel/perfmodel.c' || echo './'`core/perfmodel/perfmodel.c
.deps/libstarpu_la-perfmodel.Tpo -c core/perfmodel/perfmodel.c -fPIC -DPIC
-o .libs/libstarpu_la-perfmodel.o
.deps/libstarpu_la-perfmodel.Tpo -c core/perfmodel/perfmodel.c -o
libstarpu_la-perfmodel.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-perfmodel.Tpo .deps/libstarpu_la-perfmodel.Plo
-g3 -MT libstarpu_la-regression.lo -MD -MP -MF
.deps/libstarpu_la-regression.Tpo -c -o libstarpu_la-regression.lo `test -f
'core/perfmodel/regression.c' || echo './'`core/perfmodel/regression.c
.deps/libstarpu_la-regression.Tpo -c core/perfmodel/regression.c -fPIC -DPIC
-o .libs/libstarpu_la-regression.o
.deps/libstarpu_la-regression.Tpo -c core/perfmodel/regression.c -o
libstarpu_la-regression.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-regression.Tpo .deps/libstarpu_la-regression.Plo
-g3 -MT libstarpu_la-sched_policy.lo -MD -MP -MF
.deps/libstarpu_la-sched_policy.Tpo -c -o libstarpu_la-sched_policy.lo `test
-f 'core/sched_policy.c' || echo './'`core/sched_policy.c
.deps/libstarpu_la-sched_policy.Tpo -c core/sched_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-sched_policy.o
.deps/libstarpu_la-sched_policy.Tpo -c core/sched_policy.c -o
libstarpu_la-sched_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-sched_policy.Tpo .deps/libstarpu_la-sched_policy.Plo
-g3 -MT libstarpu_la-priorities.lo -MD -MP -MF
.deps/libstarpu_la-priorities.Tpo -c -o libstarpu_la-priorities.lo `test -f
'core/priorities.c' || echo './'`core/priorities.c
.deps/libstarpu_la-priorities.Tpo -c core/priorities.c -fPIC -DPIC -o
.libs/libstarpu_la-priorities.o
.deps/libstarpu_la-priorities.Tpo -c core/priorities.c -o
libstarpu_la-priorities.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-priorities.Tpo .deps/libstarpu_la-priorities.Plo
-g3 -MT libstarpu_la-parallel_task.lo -MD -MP -MF
.deps/libstarpu_la-parallel_task.Tpo -c -o libstarpu_la-parallel_task.lo
`test -f 'core/parallel_task.c' || echo './'`core/parallel_task.c
.deps/libstarpu_la-parallel_task.Tpo -c core/parallel_task.c -fPIC -DPIC -o
.libs/libstarpu_la-parallel_task.o
.deps/libstarpu_la-parallel_task.Tpo -c core/parallel_task.c -o
libstarpu_la-parallel_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_task.Tpo
.deps/libstarpu_la-parallel_task.Plo
-g3 -MT libstarpu_la-eager_central_policy.lo -MD -MP -MF
.deps/libstarpu_la-eager_central_policy.Tpo -c -o
libstarpu_la-eager_central_policy.lo `test -f
'sched_policies/eager_central_policy.c' || echo
'./'`sched_policies/eager_central_policy.c
sched_policies/eager_central_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-eager_central_policy.o
sched_policies/eager_central_policy.c -o libstarpu_la-eager_central_policy.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-eager_central_policy.Tpo
.deps/libstarpu_la-eager_central_policy.Plo
-g3 -MT libstarpu_la-eager_central_priority_policy.lo -MD -MP -MF
.deps/libstarpu_la-eager_central_priority_policy.Tpo -c -o
libstarpu_la-eager_central_priority_policy.lo `test -f
'sched_policies/eager_central_priority_policy.c' || echo
'./'`sched_policies/eager_central_priority_policy.c
sched_policies/eager_central_priority_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-eager_central_priority_policy.o
sched_policies/eager_central_priority_policy.c -o
libstarpu_la-eager_central_priority_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-eager_central_priority_policy.Tpo
.deps/libstarpu_la-eager_central_priority_policy.Plo
-g3 -MT libstarpu_la-work_stealing_policy.lo -MD -MP -MF
.deps/libstarpu_la-work_stealing_policy.Tpo -c -o
libstarpu_la-work_stealing_policy.lo `test -f
'sched_policies/work_stealing_policy.c' || echo
'./'`sched_policies/work_stealing_policy.c
sched_policies/work_stealing_policy.c -fPIC -DPIC -o
.libs/libstarpu_la-work_stealing_policy.o
sched_policies/work_stealing_policy.c -o libstarpu_la-work_stealing_policy.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-work_stealing_policy.Tpo
.deps/libstarpu_la-work_stealing_policy.Plo
-g3 -MT libstarpu_la-deque_modeling_policy_data_aware.lo -MD -MP -MF
.deps/libstarpu_la-deque_modeling_policy_data_aware.Tpo -c -o
libstarpu_la-deque_modeling_policy_data_aware.lo `test -f
'sched_policies/deque_modeling_policy_data_aware.c' || echo
'./'`sched_policies/deque_modeling_policy_data_aware.c
sched_policies/deque_modeling_policy_data_aware.c -fPIC -DPIC -o
.libs/libstarpu_la-deque_modeling_policy_data_aware.o
sched_policies/deque_modeling_policy_data_aware.c -o
libstarpu_la-deque_modeling_policy_data_aware.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-deque_modeling_policy_data_aware.Tpo
.deps/libstarpu_la-deque_modeling_policy_data_aware.Plo
-g3 -MT libstarpu_la-heft.lo -MD -MP -MF .deps/libstarpu_la-heft.Tpo -c -o
libstarpu_la-heft.lo `test -f 'sched_policies/heft.c' || echo
'./'`sched_policies/heft.c
sched_policies/heft.c -fPIC -DPIC -o .libs/libstarpu_la-heft.o
sched_policies/heft.c -o libstarpu_la-heft.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-heft.Tpo .deps/libstarpu_la-heft.Plo
-g3 -MT libstarpu_la-random_policy.lo -MD -MP -MF
.deps/libstarpu_la-random_policy.Tpo -c -o libstarpu_la-random_policy.lo
`test -f 'sched_policies/random_policy.c' || echo
'./'`sched_policies/random_policy.c
.deps/libstarpu_la-random_policy.Tpo -c sched_policies/random_policy.c -fPIC
-DPIC -o .libs/libstarpu_la-random_policy.o
.deps/libstarpu_la-random_policy.Tpo -c sched_policies/random_policy.c -o
libstarpu_la-random_policy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-random_policy.Tpo
.deps/libstarpu_la-random_policy.Plo
-g3 -MT libstarpu_la-stack_queues.lo -MD -MP -MF
.deps/libstarpu_la-stack_queues.Tpo -c -o libstarpu_la-stack_queues.lo `test
-f 'sched_policies/stack_queues.c' || echo './'`sched_policies/stack_queues.c
.deps/libstarpu_la-stack_queues.Tpo -c sched_policies/stack_queues.c -fPIC
-DPIC -o .libs/libstarpu_la-stack_queues.o
.deps/libstarpu_la-stack_queues.Tpo -c sched_policies/stack_queues.c -o
libstarpu_la-stack_queues.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-stack_queues.Tpo .deps/libstarpu_la-stack_queues.Plo
-g3 -MT libstarpu_la-deque_queues.lo -MD -MP -MF
.deps/libstarpu_la-deque_queues.Tpo -c -o libstarpu_la-deque_queues.lo `test
-f 'sched_policies/deque_queues.c' || echo './'`sched_policies/deque_queues.c
.deps/libstarpu_la-deque_queues.Tpo -c sched_policies/deque_queues.c -fPIC
-DPIC -o .libs/libstarpu_la-deque_queues.o
.deps/libstarpu_la-deque_queues.Tpo -c sched_policies/deque_queues.c -o
libstarpu_la-deque_queues.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-deque_queues.Tpo .deps/libstarpu_la-deque_queues.Plo
-g3 -MT libstarpu_la-fifo_queues.lo -MD -MP -MF
.deps/libstarpu_la-fifo_queues.Tpo -c -o libstarpu_la-fifo_queues.lo `test -f
'sched_policies/fifo_queues.c' || echo './'`sched_policies/fifo_queues.c
.deps/libstarpu_la-fifo_queues.Tpo -c sched_policies/fifo_queues.c -fPIC
-DPIC -o .libs/libstarpu_la-fifo_queues.o
.deps/libstarpu_la-fifo_queues.Tpo -c sched_policies/fifo_queues.c -o
libstarpu_la-fifo_queues.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-fifo_queues.Tpo .deps/libstarpu_la-fifo_queues.Plo
-g3 -MT libstarpu_la-detect_combined_workers.lo -MD -MP -MF
.deps/libstarpu_la-detect_combined_workers.Tpo -c -o
libstarpu_la-detect_combined_workers.lo `test -f
'sched_policies/detect_combined_workers.c' || echo
'./'`sched_policies/detect_combined_workers.c
sched_policies/detect_combined_workers.c -fPIC -DPIC -o
.libs/libstarpu_la-detect_combined_workers.o
sched_policies/detect_combined_workers.c -o
libstarpu_la-detect_combined_workers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-detect_combined_workers.Tpo
.deps/libstarpu_la-detect_combined_workers.Plo
-g3 -MT libstarpu_la-parallel_heft.lo -MD -MP -MF
.deps/libstarpu_la-parallel_heft.Tpo -c -o libstarpu_la-parallel_heft.lo
`test -f 'sched_policies/parallel_heft.c' || echo
'./'`sched_policies/parallel_heft.c
.deps/libstarpu_la-parallel_heft.Tpo -c sched_policies/parallel_heft.c -fPIC
-DPIC -o .libs/libstarpu_la-parallel_heft.o
.deps/libstarpu_la-parallel_heft.Tpo -c sched_policies/parallel_heft.c -o
libstarpu_la-parallel_heft.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_heft.Tpo
.deps/libstarpu_la-parallel_heft.Plo
-g3 -MT libstarpu_la-parallel_greedy.lo -MD -MP -MF
.deps/libstarpu_la-parallel_greedy.Tpo -c -o libstarpu_la-parallel_greedy.lo
`test -f 'sched_policies/parallel_greedy.c' || echo
'./'`sched_policies/parallel_greedy.c
.deps/libstarpu_la-parallel_greedy.Tpo -c sched_policies/parallel_greedy.c
-fPIC -DPIC -o .libs/libstarpu_la-parallel_greedy.o
.deps/libstarpu_la-parallel_greedy.Tpo -c sched_policies/parallel_greedy.c -o
libstarpu_la-parallel_greedy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-parallel_greedy.Tpo
.deps/libstarpu_la-parallel_greedy.Plo
-g3 -MT libstarpu_la-driver_common.lo -MD -MP -MF
.deps/libstarpu_la-driver_common.Tpo -c -o libstarpu_la-driver_common.lo
`test -f 'drivers/driver_common/driver_common.c' || echo
'./'`drivers/driver_common/driver_common.c
.deps/libstarpu_la-driver_common.Tpo -c drivers/driver_common/driver_common.c
-fPIC -DPIC -o .libs/libstarpu_la-driver_common.o
-o libstarpu_la-driver_common.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_common.Tpo
.deps/libstarpu_la-driver_common.Plo
-g3 -MT libstarpu_la-memory_nodes.lo -MD -MP -MF
.deps/libstarpu_la-memory_nodes.Tpo -c -o libstarpu_la-memory_nodes.lo `test
-f 'datawizard/memory_nodes.c' || echo './'`datawizard/memory_nodes.c
.deps/libstarpu_la-memory_nodes.Tpo -c datawizard/memory_nodes.c -fPIC -DPIC
-o .libs/libstarpu_la-memory_nodes.o
.deps/libstarpu_la-memory_nodes.Tpo -c datawizard/memory_nodes.c -o
libstarpu_la-memory_nodes.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-memory_nodes.Tpo .deps/libstarpu_la-memory_nodes.Plo
-g3 -MT libstarpu_la-write_back.lo -MD -MP -MF
.deps/libstarpu_la-write_back.Tpo -c -o libstarpu_la-write_back.lo `test -f
'datawizard/write_back.c' || echo './'`datawizard/write_back.c
.deps/libstarpu_la-write_back.Tpo -c datawizard/write_back.c -fPIC -DPIC -o
.libs/libstarpu_la-write_back.o
.deps/libstarpu_la-write_back.Tpo -c datawizard/write_back.c -o
libstarpu_la-write_back.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-write_back.Tpo .deps/libstarpu_la-write_back.Plo
-g3 -MT libstarpu_la-coherency.lo -MD -MP -MF
.deps/libstarpu_la-coherency.Tpo -c -o libstarpu_la-coherency.lo `test -f
'datawizard/coherency.c' || echo './'`datawizard/coherency.c
.deps/libstarpu_la-coherency.Tpo -c datawizard/coherency.c -fPIC -DPIC -o
.libs/libstarpu_la-coherency.o
.deps/libstarpu_la-coherency.Tpo -c datawizard/coherency.c -o
libstarpu_la-coherency.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-coherency.Tpo .deps/libstarpu_la-coherency.Plo
-g3 -MT libstarpu_la-data_request.lo -MD -MP -MF
.deps/libstarpu_la-data_request.Tpo -c -o libstarpu_la-data_request.lo `test
-f 'datawizard/data_request.c' || echo './'`datawizard/data_request.c
.deps/libstarpu_la-data_request.Tpo -c datawizard/data_request.c -fPIC -DPIC
-o .libs/libstarpu_la-data_request.o
.deps/libstarpu_la-data_request.Tpo -c datawizard/data_request.c -o
libstarpu_la-data_request.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-data_request.Tpo .deps/libstarpu_la-data_request.Plo
-g3 -MT libstarpu_la-progress.lo -MD -MP -MF .deps/libstarpu_la-progress.Tpo
-c -o libstarpu_la-progress.lo `test -f 'datawizard/progress.c' || echo
'./'`datawizard/progress.c
-c datawizard/progress.c -fPIC -DPIC -o .libs/libstarpu_la-progress.o
-c datawizard/progress.c -o libstarpu_la-progress.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-progress.Tpo .deps/libstarpu_la-progress.Plo
-g3 -MT libstarpu_la-copy_driver.lo -MD -MP -MF
.deps/libstarpu_la-copy_driver.Tpo -c -o libstarpu_la-copy_driver.lo `test -f
'datawizard/copy_driver.c' || echo './'`datawizard/copy_driver.c
.deps/libstarpu_la-copy_driver.Tpo -c datawizard/copy_driver.c -fPIC -DPIC
-o .libs/libstarpu_la-copy_driver.o
.deps/libstarpu_la-copy_driver.Tpo -c datawizard/copy_driver.c -o
libstarpu_la-copy_driver.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-copy_driver.Tpo .deps/libstarpu_la-copy_driver.Plo
-g3 -MT libstarpu_la-filters.lo -MD -MP -MF .deps/libstarpu_la-filters.Tpo
-c -o libstarpu_la-filters.lo `test -f 'datawizard/filters.c' || echo
'./'`datawizard/filters.c
-g3 -MT libstarpu_la-filters.lo -MD -MP -MF .deps/libstarpu_la-filters.Tpo -c
datawizard/filters.c -fPIC -DPIC -o .libs/libstarpu_la-filters.o
datawizard/filters.c -o libstarpu_la-filters.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-filters.Tpo .deps/libstarpu_la-filters.Plo
-g3 -MT libstarpu_la-sort_data_handles.lo -MD -MP -MF
.deps/libstarpu_la-sort_data_handles.Tpo -c -o
libstarpu_la-sort_data_handles.lo `test -f 'datawizard/sort_data_handles.c'
|| echo './'`datawizard/sort_data_handles.c
.deps/libstarpu_la-sort_data_handles.Tpo -c datawizard/sort_data_handles.c
-fPIC -DPIC -o .libs/libstarpu_la-sort_data_handles.o
.deps/libstarpu_la-sort_data_handles.Tpo -c datawizard/sort_data_handles.c -o
libstarpu_la-sort_data_handles.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-sort_data_handles.Tpo
.deps/libstarpu_la-sort_data_handles.Plo
-g3 -MT libstarpu_la-memalloc.lo -MD -MP -MF .deps/libstarpu_la-memalloc.Tpo
-c -o libstarpu_la-memalloc.lo `test -f 'datawizard/memalloc.c' || echo
'./'`datawizard/memalloc.c
-c datawizard/memalloc.c -fPIC -DPIC -o .libs/libstarpu_la-memalloc.o
-c datawizard/memalloc.c -o libstarpu_la-memalloc.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-memalloc.Tpo .deps/libstarpu_la-memalloc.Plo
-g3 -MT libstarpu_la-footprint.lo -MD -MP -MF
.deps/libstarpu_la-footprint.Tpo -c -o libstarpu_la-footprint.lo `test -f
'datawizard/footprint.c' || echo './'`datawizard/footprint.c
.deps/libstarpu_la-footprint.Tpo -c datawizard/footprint.c -fPIC -DPIC -o
.libs/libstarpu_la-footprint.o
.deps/libstarpu_la-footprint.Tpo -c datawizard/footprint.c -o
libstarpu_la-footprint.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-footprint.Tpo .deps/libstarpu_la-footprint.Plo
-g3 -MT libstarpu_la-datastats.lo -MD -MP -MF
.deps/libstarpu_la-datastats.Tpo -c -o libstarpu_la-datastats.lo `test -f
'datawizard/datastats.c' || echo './'`datawizard/datastats.c
.deps/libstarpu_la-datastats.Tpo -c datawizard/datastats.c -fPIC -DPIC -o
.libs/libstarpu_la-datastats.o
.deps/libstarpu_la-datastats.Tpo -c datawizard/datastats.c -o
libstarpu_la-datastats.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-datastats.Tpo .deps/libstarpu_la-datastats.Plo
-g3 -MT libstarpu_la-user_interactions.lo -MD -MP -MF
.deps/libstarpu_la-user_interactions.Tpo -c -o
libstarpu_la-user_interactions.lo `test -f 'datawizard/user_interactions.c'
|| echo './'`datawizard/user_interactions.c
.deps/libstarpu_la-user_interactions.Tpo -c datawizard/user_interactions.c
-fPIC -DPIC -o .libs/libstarpu_la-user_interactions.o
.deps/libstarpu_la-user_interactions.Tpo -c datawizard/user_interactions.c -o
libstarpu_la-user_interactions.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-user_interactions.Tpo
.deps/libstarpu_la-user_interactions.Plo
-g3 -MT libstarpu_la-reduction.lo -MD -MP -MF
.deps/libstarpu_la-reduction.Tpo -c -o libstarpu_la-reduction.lo `test -f
'datawizard/reduction.c' || echo './'`datawizard/reduction.c
.deps/libstarpu_la-reduction.Tpo -c datawizard/reduction.c -fPIC -DPIC -o
.libs/libstarpu_la-reduction.o
.deps/libstarpu_la-reduction.Tpo -c datawizard/reduction.c -o
libstarpu_la-reduction.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-reduction.Tpo .deps/libstarpu_la-reduction.Plo
-g3 -MT libstarpu_la-data_interface.lo -MD -MP -MF
.deps/libstarpu_la-data_interface.Tpo -c -o libstarpu_la-data_interface.lo
`test -f 'datawizard/interfaces/data_interface.c' || echo
'./'`datawizard/interfaces/data_interface.c
datawizard/interfaces/data_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-data_interface.o
datawizard/interfaces/data_interface.c -o libstarpu_la-data_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-data_interface.Tpo
.deps/libstarpu_la-data_interface.Plo
-g3 -MT libstarpu_la-bcsr_interface.lo -MD -MP -MF
.deps/libstarpu_la-bcsr_interface.Tpo -c -o libstarpu_la-bcsr_interface.lo
`test -f 'datawizard/interfaces/bcsr_interface.c' || echo
'./'`datawizard/interfaces/bcsr_interface.c
datawizard/interfaces/bcsr_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-bcsr_interface.o
datawizard/interfaces/bcsr_interface.c -o libstarpu_la-bcsr_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-bcsr_interface.Tpo
.deps/libstarpu_la-bcsr_interface.Plo
-g3 -MT libstarpu_la-csr_interface.lo -MD -MP -MF
.deps/libstarpu_la-csr_interface.Tpo -c -o libstarpu_la-csr_interface.lo
`test -f 'datawizard/interfaces/csr_interface.c' || echo
'./'`datawizard/interfaces/csr_interface.c
.deps/libstarpu_la-csr_interface.Tpo -c datawizard/interfaces/csr_interface.c
-fPIC -DPIC -o .libs/libstarpu_la-csr_interface.o
-o libstarpu_la-csr_interface.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-csr_interface.Tpo
.deps/libstarpu_la-csr_interface.Plo
-g3 -MT libstarpu_la-matrix_filters.lo -MD -MP -MF
.deps/libstarpu_la-matrix_filters.Tpo -c -o libstarpu_la-matrix_filters.lo
`test -f 'datawizard/interfaces/matrix_filters.c' || echo
'./'`datawizard/interfaces/matrix_filters.c
datawizard/interfaces/matrix_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-matrix_filters.o
datawizard/interfaces/matrix_filters.c -o libstarpu_la-matrix_filters.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-matrix_filters.Tpo
.deps/libstarpu_la-matrix_filters.Plo
-g3 -MT libstarpu_la-matrix_interface.lo -MD -MP -MF
.deps/libstarpu_la-matrix_interface.Tpo -c -o
libstarpu_la-matrix_interface.lo `test -f
'datawizard/interfaces/matrix_interface.c' || echo
'./'`datawizard/interfaces/matrix_interface.c
datawizard/interfaces/matrix_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-matrix_interface.o
datawizard/interfaces/matrix_interface.c -o libstarpu_la-matrix_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-matrix_interface.Tpo
.deps/libstarpu_la-matrix_interface.Plo
-g3 -MT libstarpu_la-block_filters.lo -MD -MP -MF
.deps/libstarpu_la-block_filters.Tpo -c -o libstarpu_la-block_filters.lo
`test -f 'datawizard/interfaces/block_filters.c' || echo
'./'`datawizard/interfaces/block_filters.c
.deps/libstarpu_la-block_filters.Tpo -c datawizard/interfaces/block_filters.c
-fPIC -DPIC -o .libs/libstarpu_la-block_filters.o
-o libstarpu_la-block_filters.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-block_filters.Tpo
.deps/libstarpu_la-block_filters.Plo
-g3 -MT libstarpu_la-block_interface.lo -MD -MP -MF
.deps/libstarpu_la-block_interface.Tpo -c -o libstarpu_la-block_interface.lo
`test -f 'datawizard/interfaces/block_interface.c' || echo
'./'`datawizard/interfaces/block_interface.c
datawizard/interfaces/block_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-block_interface.o
datawizard/interfaces/block_interface.c -o libstarpu_la-block_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-block_interface.Tpo
.deps/libstarpu_la-block_interface.Plo
-g3 -MT libstarpu_la-vector_interface.lo -MD -MP -MF
.deps/libstarpu_la-vector_interface.Tpo -c -o
libstarpu_la-vector_interface.lo `test -f
'datawizard/interfaces/vector_interface.c' || echo
'./'`datawizard/interfaces/vector_interface.c
datawizard/interfaces/vector_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-vector_interface.o
datawizard/interfaces/vector_interface.c -o libstarpu_la-vector_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-vector_interface.Tpo
.deps/libstarpu_la-vector_interface.Plo
-g3 -MT libstarpu_la-bcsr_filters.lo -MD -MP -MF
.deps/libstarpu_la-bcsr_filters.Tpo -c -o libstarpu_la-bcsr_filters.lo `test
-f 'datawizard/interfaces/bcsr_filters.c' || echo
'./'`datawizard/interfaces/bcsr_filters.c
.deps/libstarpu_la-bcsr_filters.Tpo -c datawizard/interfaces/bcsr_filters.c
-fPIC -DPIC -o .libs/libstarpu_la-bcsr_filters.o
-o libstarpu_la-bcsr_filters.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-bcsr_filters.Tpo .deps/libstarpu_la-bcsr_filters.Plo
-g3 -MT libstarpu_la-csr_filters.lo -MD -MP -MF
.deps/libstarpu_la-csr_filters.Tpo -c -o libstarpu_la-csr_filters.lo `test -f
'datawizard/interfaces/csr_filters.c' || echo
'./'`datawizard/interfaces/csr_filters.c
.deps/libstarpu_la-csr_filters.Tpo -c datawizard/interfaces/csr_filters.c
-fPIC -DPIC -o .libs/libstarpu_la-csr_filters.o
.deps/libstarpu_la-csr_filters.Tpo -c datawizard/interfaces/csr_filters.c -o
libstarpu_la-csr_filters.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-csr_filters.Tpo .deps/libstarpu_la-csr_filters.Plo
-g3 -MT libstarpu_la-vector_filters.lo -MD -MP -MF
.deps/libstarpu_la-vector_filters.Tpo -c -o libstarpu_la-vector_filters.lo
`test -f 'datawizard/interfaces/vector_filters.c' || echo
'./'`datawizard/interfaces/vector_filters.c
datawizard/interfaces/vector_filters.c -fPIC -DPIC -o
.libs/libstarpu_la-vector_filters.o
datawizard/interfaces/vector_filters.c -o libstarpu_la-vector_filters.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-vector_filters.Tpo
.deps/libstarpu_la-vector_filters.Plo
-g3 -MT libstarpu_la-variable_interface.lo -MD -MP -MF
.deps/libstarpu_la-variable_interface.Tpo -c -o
libstarpu_la-variable_interface.lo `test -f
'datawizard/interfaces/variable_interface.c' || echo
'./'`datawizard/interfaces/variable_interface.c
datawizard/interfaces/variable_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-variable_interface.o
datawizard/interfaces/variable_interface.c -o
libstarpu_la-variable_interface.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-variable_interface.Tpo
.deps/libstarpu_la-variable_interface.Plo
-g3 -MT libstarpu_la-void_interface.lo -MD -MP -MF
.deps/libstarpu_la-void_interface.Tpo -c -o libstarpu_la-void_interface.lo
`test -f 'datawizard/interfaces/void_interface.c' || echo
'./'`datawizard/interfaces/void_interface.c
datawizard/interfaces/void_interface.c -fPIC -DPIC -o
.libs/libstarpu_la-void_interface.o
datawizard/interfaces/void_interface.c -o libstarpu_la-void_interface.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-void_interface.Tpo
.deps/libstarpu_la-void_interface.Plo
-g3 -MT libstarpu_la-malloc.lo -MD -MP -MF .deps/libstarpu_la-malloc.Tpo -c
-o libstarpu_la-malloc.lo `test -f 'util/malloc.c' || echo './'`util/malloc.c
util/malloc.c -fPIC -DPIC -o .libs/libstarpu_la-malloc.o
util/malloc.c -o libstarpu_la-malloc.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-malloc.Tpo .deps/libstarpu_la-malloc.Plo
-g3 -MT libstarpu_la-execute_on_all.lo -MD -MP -MF
.deps/libstarpu_la-execute_on_all.Tpo -c -o libstarpu_la-execute_on_all.lo
`test -f 'util/execute_on_all.c' || echo './'`util/execute_on_all.c
.deps/libstarpu_la-execute_on_all.Tpo -c util/execute_on_all.c -fPIC -DPIC
-o .libs/libstarpu_la-execute_on_all.o
.deps/libstarpu_la-execute_on_all.Tpo -c util/execute_on_all.c -o
libstarpu_la-execute_on_all.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-execute_on_all.Tpo
.deps/libstarpu_la-execute_on_all.Plo
-g3 -MT libstarpu_la-starpu_create_sync_task.lo -MD -MP -MF
.deps/libstarpu_la-starpu_create_sync_task.Tpo -c -o
libstarpu_la-starpu_create_sync_task.lo `test -f
'util/starpu_create_sync_task.c' || echo './'`util/starpu_create_sync_task.c
util/starpu_create_sync_task.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_create_sync_task.o
util/starpu_create_sync_task.c -o libstarpu_la-starpu_create_sync_task.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_create_sync_task.Tpo
.deps/libstarpu_la-starpu_create_sync_task.Plo
-g3 -MT libstarpu_la-starpu_cublas.lo -MD -MP -MF
.deps/libstarpu_la-starpu_cublas.Tpo -c -o libstarpu_la-starpu_cublas.lo
`test -f 'util/starpu_cublas.c' || echo './'`util/starpu_cublas.c
.deps/libstarpu_la-starpu_cublas.Tpo -c util/starpu_cublas.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_cublas.o
.deps/libstarpu_la-starpu_cublas.Tpo -c util/starpu_cublas.c -o
libstarpu_la-starpu_cublas.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_cublas.Tpo
.deps/libstarpu_la-starpu_cublas.Plo
-g3 -MT libstarpu_la-file.lo -MD -MP -MF .deps/libstarpu_la-file.Tpo -c -o
libstarpu_la-file.lo `test -f 'util/file.c' || echo './'`util/file.c
util/file.c -fPIC -DPIC -o .libs/libstarpu_la-file.o
util/file.c -o libstarpu_la-file.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-file.Tpo .deps/libstarpu_la-file.Plo
-g3 -MT libstarpu_la-starpu_data_cpy.lo -MD -MP -MF
.deps/libstarpu_la-starpu_data_cpy.Tpo -c -o libstarpu_la-starpu_data_cpy.lo
`test -f 'util/starpu_data_cpy.c' || echo './'`util/starpu_data_cpy.c
.deps/libstarpu_la-starpu_data_cpy.Tpo -c util/starpu_data_cpy.c -fPIC -DPIC
-o .libs/libstarpu_la-starpu_data_cpy.o
.deps/libstarpu_la-starpu_data_cpy.Tpo -c util/starpu_data_cpy.c -o
libstarpu_la-starpu_data_cpy.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_data_cpy.Tpo
.deps/libstarpu_la-starpu_data_cpy.Plo
-g3 -MT libstarpu_la-starpu_insert_task.lo -MD -MP -MF
.deps/libstarpu_la-starpu_insert_task.Tpo -c -o
libstarpu_la-starpu_insert_task.lo `test -f 'util/starpu_insert_task.c' ||
echo './'`util/starpu_insert_task.c
.deps/libstarpu_la-starpu_insert_task.Tpo -c util/starpu_insert_task.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_insert_task.o
.deps/libstarpu_la-starpu_insert_task.Tpo -c util/starpu_insert_task.c -o
libstarpu_la-starpu_insert_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_insert_task.Tpo
.deps/libstarpu_la-starpu_insert_task.Plo
-g3 -MT libstarpu_la-starpu_insert_task_utils.lo -MD -MP -MF
.deps/libstarpu_la-starpu_insert_task_utils.Tpo -c -o
libstarpu_la-starpu_insert_task_utils.lo `test -f
'util/starpu_insert_task_utils.c' || echo './'`util/starpu_insert_task_utils.c
util/starpu_insert_task_utils.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_insert_task_utils.o
util/starpu_insert_task_utils.c -o libstarpu_la-starpu_insert_task_utils.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_insert_task_utils.Tpo
.deps/libstarpu_la-starpu_insert_task_utils.Plo
-g3 -MT libstarpu_la-starpu_task_list.lo -MD -MP -MF
.deps/libstarpu_la-starpu_task_list.Tpo -c -o
libstarpu_la-starpu_task_list.lo `test -f 'util/starpu_task_list.c' || echo
'./'`util/starpu_task_list.c
.deps/libstarpu_la-starpu_task_list.Tpo -c util/starpu_task_list.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_task_list.o
.deps/libstarpu_la-starpu_task_list.Tpo -c util/starpu_task_list.c -o
libstarpu_la-starpu_task_list.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_task_list.Tpo
.deps/libstarpu_la-starpu_task_list.Plo
-g3 -MT libstarpu_la-starpu_fxt.lo -MD -MP -MF
.deps/libstarpu_la-starpu_fxt.Tpo -c -o libstarpu_la-starpu_fxt.lo `test -f
'debug/traces/starpu_fxt.c' || echo './'`debug/traces/starpu_fxt.c
.deps/libstarpu_la-starpu_fxt.Tpo -c debug/traces/starpu_fxt.c -fPIC -DPIC
-o .libs/libstarpu_la-starpu_fxt.o
.deps/libstarpu_la-starpu_fxt.Tpo -c debug/traces/starpu_fxt.c -o
libstarpu_la-starpu_fxt.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt.Tpo .deps/libstarpu_la-starpu_fxt.Plo
-g3 -MT libstarpu_la-starpu_fxt_mpi.lo -MD -MP -MF
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c -o libstarpu_la-starpu_fxt_mpi.lo
`test -f 'debug/traces/starpu_fxt_mpi.c' || echo
'./'`debug/traces/starpu_fxt_mpi.c
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c debug/traces/starpu_fxt_mpi.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_fxt_mpi.o
.deps/libstarpu_la-starpu_fxt_mpi.Tpo -c debug/traces/starpu_fxt_mpi.c -o
libstarpu_la-starpu_fxt_mpi.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt_mpi.Tpo
.deps/libstarpu_la-starpu_fxt_mpi.Plo
-g3 -MT libstarpu_la-starpu_fxt_dag.lo -MD -MP -MF
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c -o libstarpu_la-starpu_fxt_dag.lo
`test -f 'debug/traces/starpu_fxt_dag.c' || echo
'./'`debug/traces/starpu_fxt_dag.c
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c debug/traces/starpu_fxt_dag.c -fPIC
-DPIC -o .libs/libstarpu_la-starpu_fxt_dag.o
.deps/libstarpu_la-starpu_fxt_dag.Tpo -c debug/traces/starpu_fxt_dag.c -o
libstarpu_la-starpu_fxt_dag.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_fxt_dag.Tpo
.deps/libstarpu_la-starpu_fxt_dag.Plo
-g3 -MT libstarpu_la-starpu_paje.lo -MD -MP -MF
.deps/libstarpu_la-starpu_paje.Tpo -c -o libstarpu_la-starpu_paje.lo `test -f
'debug/traces/starpu_paje.c' || echo './'`debug/traces/starpu_paje.c
.deps/libstarpu_la-starpu_paje.Tpo -c debug/traces/starpu_paje.c -fPIC -DPIC
-o .libs/libstarpu_la-starpu_paje.o
.deps/libstarpu_la-starpu_paje.Tpo -c debug/traces/starpu_paje.c -o
libstarpu_la-starpu_paje.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_paje.Tpo .deps/libstarpu_la-starpu_paje.Plo
-g3 -MT libstarpu_la-latency.lo -MD -MP -MF .deps/libstarpu_la-latency.Tpo
-c -o libstarpu_la-latency.lo `test -f 'debug/latency.c' || echo
'./'`debug/latency.c
-g3 -MT libstarpu_la-latency.lo -MD -MP -MF .deps/libstarpu_la-latency.Tpo -c
debug/latency.c -fPIC -DPIC -o .libs/libstarpu_la-latency.o
debug/latency.c -o libstarpu_la-latency.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-latency.Tpo .deps/libstarpu_la-latency.Plo
-g3 -MT libstarpu_la-structures_size.lo -MD -MP -MF
.deps/libstarpu_la-structures_size.Tpo -c -o libstarpu_la-structures_size.lo
`test -f 'debug/structures_size.c' || echo './'`debug/structures_size.c
.deps/libstarpu_la-structures_size.Tpo -c debug/structures_size.c -fPIC
-DPIC -o .libs/libstarpu_la-structures_size.o
.deps/libstarpu_la-structures_size.Tpo -c debug/structures_size.c -o
libstarpu_la-structures_size.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-structures_size.Tpo
.deps/libstarpu_la-structures_size.Plo
-g3 -MT libstarpu_la-profiling.lo -MD -MP -MF
.deps/libstarpu_la-profiling.Tpo -c -o libstarpu_la-profiling.lo `test -f
'profiling/profiling.c' || echo './'`profiling/profiling.c
.deps/libstarpu_la-profiling.Tpo -c profiling/profiling.c -fPIC -DPIC -o
.libs/libstarpu_la-profiling.o
.deps/libstarpu_la-profiling.Tpo -c profiling/profiling.c -o
libstarpu_la-profiling.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-profiling.Tpo .deps/libstarpu_la-profiling.Plo
-g3 -MT libstarpu_la-bound.lo -MD -MP -MF .deps/libstarpu_la-bound.Tpo -c -o
libstarpu_la-bound.lo `test -f 'profiling/bound.c' || echo
'./'`profiling/bound.c
profiling/bound.c -fPIC -DPIC -o .libs/libstarpu_la-bound.o
profiling/bound.c -o libstarpu_la-bound.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-bound.Tpo .deps/libstarpu_la-bound.Plo
-g3 -MT libstarpu_la-profiling_helpers.lo -MD -MP -MF
.deps/libstarpu_la-profiling_helpers.Tpo -c -o
libstarpu_la-profiling_helpers.lo `test -f 'profiling/profiling_helpers.c' ||
echo './'`profiling/profiling_helpers.c
.deps/libstarpu_la-profiling_helpers.Tpo -c profiling/profiling_helpers.c
-fPIC -DPIC -o .libs/libstarpu_la-profiling_helpers.o
.deps/libstarpu_la-profiling_helpers.Tpo -c profiling/profiling_helpers.c -o
libstarpu_la-profiling_helpers.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-profiling_helpers.Tpo
.deps/libstarpu_la-profiling_helpers.Plo
-g3 -MT libstarpu_la-starpu_top.lo -MD -MP -MF
.deps/libstarpu_la-starpu_top.Tpo -c -o libstarpu_la-starpu_top.lo `test -f
'top/starpu_top.c' || echo './'`top/starpu_top.c
.deps/libstarpu_la-starpu_top.Tpo -c top/starpu_top.c -fPIC -DPIC -o
.libs/libstarpu_la-starpu_top.o
.deps/libstarpu_la-starpu_top.Tpo -c top/starpu_top.c -o
libstarpu_la-starpu_top.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starpu_top.Tpo .deps/libstarpu_la-starpu_top.Plo
-g3 -MT libstarpu_la-starputop_task.lo -MD -MP -MF
.deps/libstarpu_la-starputop_task.Tpo -c -o libstarpu_la-starputop_task.lo
`test -f 'top/starputop_task.c' || echo './'`top/starputop_task.c
.deps/libstarpu_la-starputop_task.Tpo -c top/starputop_task.c -fPIC -DPIC -o
.libs/libstarpu_la-starputop_task.o
.deps/libstarpu_la-starputop_task.Tpo -c top/starputop_task.c -o
libstarpu_la-starputop_task.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_task.Tpo
.deps/libstarpu_la-starputop_task.Plo
-g3 -MT libstarpu_la-starputop_message_queue.lo -MD -MP -MF
.deps/libstarpu_la-starputop_message_queue.Tpo -c -o
libstarpu_la-starputop_message_queue.lo `test -f
'top/starputop_message_queue.c' || echo './'`top/starputop_message_queue.c
top/starputop_message_queue.c -fPIC -DPIC -o
.libs/libstarpu_la-starputop_message_queue.o
top/starputop_message_queue.c -o libstarpu_la-starputop_message_queue.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_message_queue.Tpo
.deps/libstarpu_la-starputop_message_queue.Plo
-g3 -MT libstarpu_la-starputop_connection.lo -MD -MP -MF
.deps/libstarpu_la-starputop_connection.Tpo -c -o
libstarpu_la-starputop_connection.lo `test -f 'top/starputop_connection.c' ||
echo './'`top/starputop_connection.c
.deps/libstarpu_la-starputop_connection.Tpo -c top/starputop_connection.c
-fPIC -DPIC -o .libs/libstarpu_la-starputop_connection.o
.deps/libstarpu_la-starputop_connection.Tpo -c top/starputop_connection.c -o
libstarpu_la-starputop_connection.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-starputop_connection.Tpo
.deps/libstarpu_la-starputop_connection.Plo
-g3 -MT libstarpu_la-driver_cpu.lo -MD -MP -MF
.deps/libstarpu_la-driver_cpu.Tpo -c -o libstarpu_la-driver_cpu.lo `test -f
'drivers/cpu/driver_cpu.c' || echo './'`drivers/cpu/driver_cpu.c
.deps/libstarpu_la-driver_cpu.Tpo -c drivers/cpu/driver_cpu.c -fPIC -DPIC -o
.libs/libstarpu_la-driver_cpu.o
.deps/libstarpu_la-driver_cpu.Tpo -c drivers/cpu/driver_cpu.c -o
libstarpu_la-driver_cpu.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_cpu.Tpo .deps/libstarpu_la-driver_cpu.Plo
-g3 -MT libstarpu_la-driver_opencl.lo -MD -MP -MF
.deps/libstarpu_la-driver_opencl.Tpo -c -o libstarpu_la-driver_opencl.lo
`test -f 'drivers/opencl/driver_opencl.c' || echo
'./'`drivers/opencl/driver_opencl.c
.deps/libstarpu_la-driver_opencl.Tpo -c drivers/opencl/driver_opencl.c -fPIC
-DPIC -o .libs/libstarpu_la-driver_opencl.o
.deps/libstarpu_la-driver_opencl.Tpo -c drivers/opencl/driver_opencl.c -o
libstarpu_la-driver_opencl.o >/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_opencl.Tpo
.deps/libstarpu_la-driver_opencl.Plo
-g3 -MT libstarpu_la-driver_opencl_utils.lo -MD -MP -MF
.deps/libstarpu_la-driver_opencl_utils.Tpo -c -o
libstarpu_la-driver_opencl_utils.lo `test -f
'drivers/opencl/driver_opencl_utils.c' || echo
'./'`drivers/opencl/driver_opencl_utils.c
drivers/opencl/driver_opencl_utils.c -fPIC -DPIC -o
.libs/libstarpu_la-driver_opencl_utils.o
drivers/opencl/driver_opencl_utils.c -o libstarpu_la-driver_opencl_utils.o
>/dev/null 2>&1
mv -f .deps/libstarpu_la-driver_opencl_utils.Tpo
.deps/libstarpu_la-driver_opencl_utils.Plo
/bin/bash ../libtool --tag=CC --mode=link gcc -W -Wall -Wextra
-g3 -version-number 0:0:0 -no-undefined -o libstarpu.la -rpath
/usr/local/lib libstarpu_la-barrier.lo libstarpu_la-hash.lo
libstarpu_la-htable32.lo libstarpu_la-rwlock.lo
libstarpu_la-starpu_spinlock.lo libstarpu_la-timing.lo libstarpu_la-fxt.lo
libstarpu_la-utils.lo libstarpu_la-jobs.lo libstarpu_la-task.lo
libstarpu_la-task_bundle.lo libstarpu_la-workers.lo
libstarpu_la-combined_workers.lo libstarpu_la-topology.lo
libstarpu_la-debug.lo libstarpu_la-errorcheck.lo
libstarpu_la-progress_hook.lo libstarpu_la-cg.lo libstarpu_la-dependencies.lo
libstarpu_la-implicit_data_deps.lo libstarpu_la-tags.lo
libstarpu_la-task_deps.lo libstarpu_la-htable.lo
libstarpu_la-data_concurrency.lo libstarpu_la-perfmodel_history.lo
libstarpu_la-perfmodel_bus.lo libstarpu_la-perfmodel.lo
libstarpu_la-regression.lo libstarpu_la-sched_policy.lo
libstarpu_la-priorities.lo libstarpu_la-parallel_task.lo
libstarpu_la-deque_modeling_policy_data_aware.lo libstarpu_la-heft.lo
libstarpu_la-random_policy.lo libstarpu_la-stack_queues.lo
libstarpu_la-deque_queues.lo libstarpu_la-fifo_queues.lo
libstarpu_la-detect_combined_workers.lo libstarpu_la-parallel_heft.lo
libstarpu_la-parallel_greedy.lo libstarpu_la-driver_common.lo
libstarpu_la-memory_nodes.lo libstarpu_la-write_back.lo
libstarpu_la-coherency.lo libstarpu_la-data_request.lo
libstarpu_la-progress.lo libstarpu_la-copy_driver.lo libstarpu_la-filters.lo
libstarpu_la-sort_data_handles.lo libstarpu_la-memalloc.lo
libstarpu_la-footprint.lo libstarpu_la-datastats.lo
libstarpu_la-user_interactions.lo libstarpu_la-reduction.lo
libstarpu_la-data_interface.lo libstarpu_la-bcsr_interface.lo
libstarpu_la-csr_interface.lo libstarpu_la-matrix_filters.lo
libstarpu_la-matrix_interface.lo libstarpu_la-block_filters.lo
libstarpu_la-block_interface.lo libstarpu_la-vector_interface.lo
libstarpu_la-bcsr_filters.lo libstarpu_la-csr_filters.lo
libstarpu_la-vector_filters.lo libstarpu_la-variable_interface.lo
libstarpu_la-void_interface.lo libstarpu_la-malloc.lo
libstarpu_la-execute_on_all.lo libstarpu_la-starpu_create_sync_task.lo
libstarpu_la-starpu_cublas.lo libstarpu_la-file.lo
libstarpu_la-starpu_data_cpy.lo libstarpu_la-starpu_insert_task.lo
libstarpu_la-starpu_insert_task_utils.lo libstarpu_la-starpu_task_list.lo
libstarpu_la-starpu_fxt.lo libstarpu_la-starpu_fxt_mpi.lo
libstarpu_la-starpu_fxt_dag.lo libstarpu_la-starpu_paje.lo
libstarpu_la-latency.lo libstarpu_la-structures_size.lo
libstarpu_la-profiling.lo libstarpu_la-bound.lo
libstarpu_la-profiling_helpers.lo libstarpu_la-starpu_top.lo
libstarpu_la-starputop_task.lo libstarpu_la-starputop_message_queue.lo
libstarpu_la-starputop_connection.lo libstarpu_la-driver_cpu.lo
libstarpu_la-driver_opencl.lo libstarpu_la-driver_opencl_utils.lo -lm
-L/home/movidius/code/moviSimStarPU/trunk/moviSim -lOpenCL -lrt -lm
-lpthread
libtool: link: gcc -shared .libs/libstarpu_la-barrier.o
.libs/libstarpu_la-hash.o .libs/libstarpu_la-htable32.o
.libs/libstarpu_la-rwlock.o .libs/libstarpu_la-starpu_spinlock.o
.libs/libstarpu_la-timing.o .libs/libstarpu_la-fxt.o
.libs/libstarpu_la-utils.o .libs/libstarpu_la-jobs.o
.libs/libstarpu_la-task.o .libs/libstarpu_la-task_bundle.o
.libs/libstarpu_la-workers.o .libs/libstarpu_la-combined_workers.o
.libs/libstarpu_la-topology.o .libs/libstarpu_la-debug.o
.libs/libstarpu_la-errorcheck.o .libs/libstarpu_la-progress_hook.o
.libs/libstarpu_la-cg.o .libs/libstarpu_la-dependencies.o
.libs/libstarpu_la-implicit_data_deps.o .libs/libstarpu_la-tags.o
.libs/libstarpu_la-task_deps.o .libs/libstarpu_la-htable.o
.libs/libstarpu_la-data_concurrency.o .libs/libstarpu_la-perfmodel_history.o
.libs/libstarpu_la-perfmodel_bus.o .libs/libstarpu_la-perfmodel.o
.libs/libstarpu_la-regression.o .libs/libstarpu_la-sched_policy.o
.libs/libstarpu_la-priorities.o .libs/libstarpu_la-parallel_task.o
.libs/libstarpu_la-heft.o .libs/libstarpu_la-random_policy.o
.libs/libstarpu_la-stack_queues.o .libs/libstarpu_la-deque_queues.o
.libs/libstarpu_la-fifo_queues.o .libs/libstarpu_la-detect_combined_workers.o
.libs/libstarpu_la-parallel_heft.o .libs/libstarpu_la-parallel_greedy.o
.libs/libstarpu_la-driver_common.o .libs/libstarpu_la-memory_nodes.o
.libs/libstarpu_la-write_back.o .libs/libstarpu_la-coherency.o
.libs/libstarpu_la-data_request.o .libs/libstarpu_la-progress.o
.libs/libstarpu_la-copy_driver.o .libs/libstarpu_la-filters.o
.libs/libstarpu_la-sort_data_handles.o .libs/libstarpu_la-memalloc.o
.libs/libstarpu_la-footprint.o .libs/libstarpu_la-datastats.o
.libs/libstarpu_la-user_interactions.o .libs/libstarpu_la-reduction.o
.libs/libstarpu_la-data_interface.o .libs/libstarpu_la-bcsr_interface.o
.libs/libstarpu_la-csr_interface.o .libs/libstarpu_la-matrix_filters.o
.libs/libstarpu_la-matrix_interface.o .libs/libstarpu_la-block_filters.o
.libs/libstarpu_la-block_interface.o .libs/libstarpu_la-vector_interface.o
.libs/libstarpu_la-bcsr_filters.o .libs/libstarpu_la-csr_filters.o
.libs/libstarpu_la-vector_filters.o .libs/libstarpu_la-variable_interface.o
.libs/libstarpu_la-void_interface.o .libs/libstarpu_la-malloc.o
.libs/libstarpu_la-starpu_cublas.o .libs/libstarpu_la-file.o
.libs/libstarpu_la-starpu_data_cpy.o .libs/libstarpu_la-starpu_insert_task.o
.libs/libstarpu_la-starpu_task_list.o .libs/libstarpu_la-starpu_fxt.o
.libs/libstarpu_la-starpu_fxt_mpi.o .libs/libstarpu_la-starpu_fxt_dag.o
.libs/libstarpu_la-starpu_paje.o .libs/libstarpu_la-latency.o
.libs/libstarpu_la-structures_size.o .libs/libstarpu_la-profiling.o
.libs/libstarpu_la-bound.o .libs/libstarpu_la-profiling_helpers.o
.libs/libstarpu_la-starpu_top.o .libs/libstarpu_la-starputop_task.o
.libs/libstarpu_la-starputop_connection.o .libs/libstarpu_la-driver_cpu.o
.libs/libstarpu_la-driver_opencl.o .libs/libstarpu_la-driver_opencl_utils.o
-L/home/movidius/code/moviSimStarPU/trunk/moviSim -lOpenCL -lrt -lm -lpthread
-Wl,-soname -Wl,libstarpu.so.0 -o .libs/libstarpu.so.0.0.0
libtool: link: (cd ".libs" && rm -f "libstarpu.so.0" && ln -s
"libstarpu.so.0.0.0" "libstarpu.so.0")
libtool: link: (cd ".libs" && rm -f "libstarpu.so" && ln -s
"libstarpu.so.0.0.0" "libstarpu.so")
libtool: link: ar cru .libs/libstarpu.a libstarpu_la-barrier.o
libstarpu_la-hash.o libstarpu_la-htable32.o libstarpu_la-rwlock.o
libstarpu_la-starpu_spinlock.o libstarpu_la-timing.o libstarpu_la-fxt.o
libstarpu_la-utils.o libstarpu_la-jobs.o libstarpu_la-task.o
libstarpu_la-task_bundle.o libstarpu_la-workers.o
libstarpu_la-combined_workers.o libstarpu_la-topology.o libstarpu_la-debug.o
libstarpu_la-errorcheck.o libstarpu_la-progress_hook.o libstarpu_la-cg.o
libstarpu_la-dependencies.o libstarpu_la-implicit_data_deps.o
libstarpu_la-tags.o libstarpu_la-task_deps.o libstarpu_la-htable.o
libstarpu_la-data_concurrency.o libstarpu_la-perfmodel_history.o
libstarpu_la-perfmodel_bus.o libstarpu_la-perfmodel.o
libstarpu_la-regression.o libstarpu_la-sched_policy.o
libstarpu_la-priorities.o libstarpu_la-parallel_task.o
libstarpu_la-deque_modeling_policy_data_aware.o libstarpu_la-heft.o
libstarpu_la-random_policy.o libstarpu_la-stack_queues.o
libstarpu_la-deque_queues.o libstarpu_la-fifo_queues.o
libstarpu_la-detect_combined_workers.o libstarpu_la-parallel_heft.o
libstarpu_la-parallel_greedy.o libstarpu_la-driver_common.o
libstarpu_la-memory_nodes.o libstarpu_la-write_back.o
libstarpu_la-coherency.o libstarpu_la-data_request.o libstarpu_la-progress.o
libstarpu_la-copy_driver.o libstarpu_la-filters.o
libstarpu_la-sort_data_handles.o libstarpu_la-memalloc.o
libstarpu_la-footprint.o libstarpu_la-datastats.o
libstarpu_la-user_interactions.o libstarpu_la-reduction.o
libstarpu_la-data_interface.o libstarpu_la-bcsr_interface.o
libstarpu_la-csr_interface.o libstarpu_la-matrix_filters.o
libstarpu_la-matrix_interface.o libstarpu_la-block_filters.o
libstarpu_la-block_interface.o libstarpu_la-vector_interface.o
libstarpu_la-bcsr_filters.o libstarpu_la-csr_filters.o
libstarpu_la-vector_filters.o libstarpu_la-variable_interface.o
libstarpu_la-void_interface.o libstarpu_la-malloc.o
libstarpu_la-execute_on_all.o libstarpu_la-starpu_create_sync_task.o
libstarpu_la-starpu_cublas.o libstarpu_la-file.o
libstarpu_la-starpu_data_cpy.o libstarpu_la-starpu_insert_task.o
libstarpu_la-starpu_insert_task_utils.o libstarpu_la-starpu_task_list.o
libstarpu_la-starpu_fxt.o libstarpu_la-starpu_fxt_mpi.o
libstarpu_la-starpu_fxt_dag.o libstarpu_la-starpu_paje.o
libstarpu_la-latency.o libstarpu_la-structures_size.o
libstarpu_la-profiling.o libstarpu_la-bound.o
libstarpu_la-profiling_helpers.o libstarpu_la-starpu_top.o
libstarpu_la-starputop_task.o libstarpu_la-starputop_message_queue.o
libstarpu_la-starputop_connection.o libstarpu_la-driver_cpu.o
libstarpu_la-driver_opencl.o libstarpu_la-driver_opencl_utils.o
libtool: link: ranlib .libs/libstarpu.a
libtool: link: ( cd ".libs" && rm -f "libstarpu.la" && ln -s
"../libstarpu.la" "libstarpu.la" )
make[2]: Leaving directory `/home/movidius/code/moviSimStarPU/trunk/src'
make[1]: Leaving directory `/home/movidius/code/moviSimStarPU/trunk/src'
Making all in tools
make[1]: Entering directory `/home/movidius/code/moviSimStarPU/trunk/tools'
make[2]: Entering directory `/home/movidius/code/moviSimStarPU/trunk/tools'
gcc -DHAVE_CONFIG_H -I. -I../src/common -I../include -I../gcc-plugin/src
-I../include/ -I../tools/ -I../mpi/ -I../src -I../src -D_GNU_SOURCE
-g3 -MT starpu_calibrate_bus.o -MD -MP -MF .deps/starpu_calibrate_bus.Tpo -c
-o starpu_calibrate_bus.o starpu_calibrate_bus.c
mv -f .deps/starpu_calibrate_bus.Tpo .deps/starpu_calibrate_bus.Po
-g3 -o starpu_calibrate_bus starpu_calibrate_bus.o ../src/libstarpu.la
-lrt -lm -lpthread
libtool: link: gcc -I/home/movidius/code/moviSimStarPU/trunk/moviSim
-g3 -o .libs/starpu_calibrate_bus starpu_calibrate_bus.o
../src/.libs/libstarpu.so -lrt -lm -lpthread
make[2]: Leaving directory `/home/movidius/code/moviSimStarPU/trunk/tools'
make[1]: Leaving directory `/home/movidius/code/moviSimStarPU/trunk/tools'
Haut de le page
