Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, ASD D <ajitsdeshpande@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Error while building StarpU library
- Date: Fri, 28 Oct 2011 18:20:36 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Thanks for promt reply. It works fine now when I remove STARPU_NPCPUS=0. My bad. I did not think about it.
So it seems to be some problem with the opencl configuration/library we have.
BTW - This same example(Vector_scale) works fine under Windows+MingW setup, when configured to use openCL.
So something to do with the Linux version shared library of openCL or moviSim may be.
Need to dig more. Any pointers.
thanks,
On Fri, Oct 28, 2011 at 6:09 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
ASD D, le Fri 28 Oct 2011 17:55:12 +0100, a écrit :
> Query - If I ./configure --disable-opencl --disable-cuda , and then make andErrr, just do not set STARPU_NCPUS to 0...
> then execute vector_scale using STARPU_NCPUS=0 ./examples/basic_examples/
> vector_scal,
> it says gives error:
> Segmentation fault:
> [starpu][_starpu_init_machine_config] No worker found, aborting ...
> How to get it running one CPU alone.
Samuel
- [Starpu-devel] Error while building StarpU library, ASD D, 27/10/2011
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Error while building StarpU library, Samuel Thibault, 27/10/2011
- Re: [Starpu-devel] Error while building StarpU library, ASD D, 27/10/2011
- Re: [Starpu-devel] Error while building StarpU library, Samuel Thibault, 28/10/2011
- Re: [Starpu-devel] Error while building StarpU library, ASD D, 28/10/2011
