Archives de la liste
[Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
- Date: Mon, 20 Feb 2012 14:22:53 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
As I'm not sure it was delivered I follow this bug report to the devel list.
The problem appear in revision 5692 and is still there in revision 5705
#0 0x00007fffeb562645 in raise () from /lib64/libc.so.6
#1 0x00007fffeb563c33 in abort () from /lib64/libc.so.6
#2 0x00007fffeb55b329 in __assert_fail () from /lib64/libc.so.6
#3 0x00000000005131b3 in _starpu_release_data_on_node (handle=0x47a6b10, default_wt_mask=<value optimized out>, replicate=0x47a6bb0) at datawizard/coherency.c:547
#4 0x00000000005132ec in _starpu_push_task_output (j=0x7fff6cb2ce40, mask=0) at datawizard/coherency.c:720
#5 0x000000000052f9e5 in _starpu_cpu_worker (arg=0x845cf8) at drivers/cpu/driver_cpu.c:78
#6 0x00007fffee2b1070 in start_thread () from /lib64/libpthread.so.0
#7 0x00007fffeb60310d in clone () from /lib64/libc.so.6
#8 0x0000000000000000 in ?? ()
Début du message réexpédié :
De : Xavier Lacoste <xavier.lacoste@inria.fr>Objet : Rép : [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/openclDate : 17 février 2012 16:05:53 HNECThis commit seems to break something in StarPU, it's OK on 5691 and on 5692 (and 5696) I got this :
step-by-step: datawizard/coherency.c:547: _starpu_release_data_on_node: Assertion `replicate->refcnt >= 0' failed.
[mirage002:18405] *** Process received signal ***
[mirage002:18405] Signal: Aborted (6)
[mirage002:18405] Signal code: (-6)
[mirage002:18405] [ 0] /lib64/libpthread.so.0 [0x7fffee2b8a90]
[mirage002:18405] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x7fffeb562645]
[mirage002:18405] [ 2] /lib64/libc.so.6(abort+0x183) [0x7fffeb563c33]
[mirage002:18405] [ 3] /lib64/libc.so.6(__assert_fail+0xe9) [0x7fffeb55b329]
[mirage002:18405] [ 4] ../example/bin/step-by-step(_starpu_release_data_on_node+0x183) [0x5131b3]
[mirage002:18405] [ 5] ../example/bin/step-by-step(_starpu_push_task_output+0x10c) [0x5132ec]
[mirage002:18405] [ 6] ../example/bin/step-by-step(_starpu_cpu_worker+0x575) [0x52fc25]
[mirage002:18405] [ 7] /lib64/libpthread.so.0 [0x7fffee2b1070]
[mirage002:18405] [ 8] /lib64/libc.so.6(clone+0x6d) [0x7fffeb60310d]
[mirage002:18405] *** End of error message ***
Aborted
- [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Xavier Lacoste, 20/02/2012
- Re: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Cyril Roelandt, 21/02/2012
- Re: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Xavier Lacoste, 21/02/2012
- Re: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Cyril Roelandt, 23/02/2012
- Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Xavier Lacoste, 24/02/2012
- Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Cyril Roelandt, 24/02/2012
