Archives de la liste
Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
Chronologique Discussions
- To: Cyril Roelandt <cyril.roelandt@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
- Date: Fri, 24 Feb 2012 08:14:33 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
I'll try to right a simpler example.
XL.
Le 23 févr. 2012 à 15:42, Cyril Roelandt a écrit :
> On 02/21/2012 03:57 PM, Xavier Lacoste wrote:
>> I have made few modification on the source code since I noticed the bug
>> but I hope it is still there.
> Indeed, the bug is still there.
> I can confirm that your code works with r5691, but not with r5692.
> I applied the following patch :
> --- starpu_submit_tasks.c.bak 2012-02-22 17:39:19.000000000 +0100
> +++ sopalin/src/starpu_submit_tasks.c 2012-02-23 15:02:50.000000000 +0100
> @@ -647,7 +647,7 @@
> matrix_child->offset = matrix_father->offset + current_pos*elemsize;
> -#define USE_TASK_DEP
> +//#define USE_TASK_DEP
> static void starpu_partition_data(Sopalin_Data_t * sopalin_data,
> starpu_data_handle_t * L_handle,
> @@ -1237,7 +1237,9 @@
> iterbloc < SYMB_BLOKNUM(itercblk+1);
> iterbloc ++)
> +#ifdef USE_TASK_DEP
> starpu_task_destroy(starpu_tasktab[iterbloc]);
> +#endif
> #ifndef STARPU_BLOCKTAB_GEMM
> #if (defined SPARSE_GEMM && defined CHOL_SOPALIN)
> if (iterbloc > SYMB_BLOKNUM(itercblk))
> @@ -1254,7 +1256,9 @@
> #endif
> #endif
> memFree_null(starpu_tasktab);
> +#endif
> #ifdef STARPU_BLOCKTAB_GEMM
> #ifdef STARPU_BLOCKTAB_SELFCOPY
> in order to run your code without task dependencies. It works this way.
> Since r 5692 changes a lot of code related to task dependencies, I think
> we're getting close to understanding your bug :)
> I would love to reproduce this bug with a simpler test case, but I have a
> hard time figuring out how the dependencies work in starpu_submit_tasks().
> Would you mind writing a simple test case that declares the same kind of
> dependencies and crashes ? It would really help us in the debugging process.
> Regards,
> Cyril Roelandt.
- [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Xavier Lacoste, 20/02/2012
- Re: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Cyril Roelandt, 21/02/2012
- Re: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Xavier Lacoste, 21/02/2012
- Re: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Cyril Roelandt, 23/02/2012
- Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Xavier Lacoste, 24/02/2012
- Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl, Cyril Roelandt, 24/02/2012
