Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
Archives de la liste
Chronologique Discussions
  • To: Xavier Lacoste <xavier.lacoste@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Fwd: [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
  • Date: Thu, 23 Feb 2012 15:42:43 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 02/21/2012 03:57 PM, Xavier Lacoste wrote:
I have made few modification on the source code since I noticed the bug but I
hope it is still there.
Indeed, the bug is still there.
I can confirm that your code works with r5691, but not with r5692.
I applied the following patch :
--- starpu_submit_tasks.c.bak 2012-02-22 17:39:19.000000000 +0100
+++ sopalin/src/starpu_submit_tasks.c 2012-02-23 15:02:50.000000000 +0100
@@ -647,7 +647,7 @@
matrix_child->offset = matrix_father->offset + current_pos*elemsize;
-#define USE_TASK_DEP
+//#define USE_TASK_DEP
static void starpu_partition_data(Sopalin_Data_t * sopalin_data,
starpu_data_handle_t * L_handle,
@@ -1237,7 +1237,9 @@
iterbloc < SYMB_BLOKNUM(itercblk+1);
iterbloc ++)
+#ifdef USE_TASK_DEP
starpu_task_destroy(starpu_tasktab[iterbloc]);
+#endif
#ifndef STARPU_BLOCKTAB_GEMM
#if (defined SPARSE_GEMM && defined CHOL_SOPALIN)
if (iterbloc > SYMB_BLOKNUM(itercblk))
@@ -1254,7 +1256,9 @@
#endif
#endif
memFree_null(starpu_tasktab);
+#endif
#ifdef STARPU_BLOCKTAB_GEMM
#ifdef STARPU_BLOCKTAB_SELFCOPY
in order to run your code without task dependencies. It works this way. Since r 5692 changes a lot of code related to task dependencies, I think we're getting close to understanding your bug :)
I would love to reproduce this bug with a simpler test case, but I have a hard time figuring out how the dependencies work in starpu_submit_tasks(). Would you mind writing a simple test case that declares the same kind of dependencies and crashes ? It would really help us in the debugging process.
Regards,
Cyril Roelandt.
Haut de le page
