Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
Archives de la liste
Chronologique Discussions
  • To: Cyril Roelandt <cyril.roelandt@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
  • Date: Fri, 24 Feb 2012 11:01:05 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello again,
I did a smaller example creating an empty sparse matrix and doing a fake
factorization using StarPU.
The problem is that for the moment it doesn't reproduce the bug.
Can you remember me the define I gave you in config.in file in STARPU section
XL.
Le 24 févr. 2012 à 08:14, Xavier Lacoste a écrit :
> Hello,
> I'll try to right a simpler example.
> XL.
> Le 23 févr. 2012 à 15:42, Cyril Roelandt a écrit :
>> On 02/21/2012 03:57 PM, Xavier Lacoste wrote:
>>> I have made few modification on the source code since I noticed the bug
>>> but I hope it is still there.
>> Indeed, the bug is still there.
>> I can confirm that your code works with r5691, but not with r5692.
>> I applied the following patch :
>> --- starpu_submit_tasks.c.bak 2012-02-22 17:39:19.000000000 +0100
>> +++ sopalin/src/starpu_submit_tasks.c 2012-02-23 15:02:50.000000000 +0100
>> @@ -647,7 +647,7 @@
>> matrix_child->offset = matrix_father->offset + current_pos*elemsize;
>> -#define USE_TASK_DEP
>> +//#define USE_TASK_DEP
>> static void starpu_partition_data(Sopalin_Data_t * sopalin_data,
>> starpu_data_handle_t * L_handle,
>> @@ -1237,7 +1237,9 @@
>> iterbloc < SYMB_BLOKNUM(itercblk+1);
>> iterbloc ++)
>> +#ifdef USE_TASK_DEP
>> starpu_task_destroy(starpu_tasktab[iterbloc]);
>> +#endif
>> #ifndef STARPU_BLOCKTAB_GEMM
>> #if (defined SPARSE_GEMM && defined CHOL_SOPALIN)
>> if (iterbloc > SYMB_BLOKNUM(itercblk))
>> @@ -1254,7 +1256,9 @@
>> #endif
>> #endif
>> memFree_null(starpu_tasktab);
>> +#endif
>> #ifdef STARPU_BLOCKTAB_GEMM
>> #ifdef STARPU_BLOCKTAB_SELFCOPY
>> in order to run your code without task dependencies. It works this way.
>> Since r 5692 changes a lot of code related to task dependencies, I think
>> we're getting close to understanding your bug :)
>> I would love to reproduce this bug with a simpler test case, but I have a
>> hard time figuring out how the dependencies work in starpu_submit_tasks().
>> Would you mind writing a simple test case that declares the same kind of
>> dependencies and crashes ? It would really help us in the debugging
>> process.
>> Regards,
>> Cyril Roelandt.
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
