Archives de la liste
[Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>"
Chronologique Discussions
- From: Keisuke Fukuda <fukuda@matsulab.is.titech.ac.jp>
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>"
- Date: Thu, 28 Jun 2012 14:37:58 +0900
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Dear all,
I've been seeing a strange error,
StarPU function <starpu_task_submit> returned unexpected value: <-19>
My code is calling starpu_task_submit() as the samples do, like
int ret = starpu_task_submit(task_ulist);
STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_submit");
The failing task uses partitioning and combined workers features.
I set STARPU_SCHED=pheft and it seems to be causing the problem,
because everything's fine with STARPU_SCHED=heft .
The error still happens even if I stop using partitioning feature on the task.
Is there something wrong with pheft scheduling or any point that I
should take care?
I searched the StarPU source code but couldn't find what -19 or 19 means.
Please tell me if further information is necessary.
Thank you.
FUKUDA, Keisuke<fukuda@matsulab.is.titech.ac.jp>
Dept. of Math. & Comp. Sciences
Satoshi Matsuoka Lab.,
Tokyo Institute of Technology
福田圭祐 <fukuda@matsulab.is.titech.ac.jp>
東京工業大学 数理・計算科学専攻 松岡研究室
- [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Keisuke Fukuda, 28/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Keisuke Fukuda, 28/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Brice Goglin, 28/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Samuel Thibault, 29/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Keisuke Fukuda, 29/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Cyril Roelandt, 29/06/2012
