Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>"
Archives de la liste
Chronologique Discussions
  • From: Keisuke Fukuda <fukuda@matsulab.is.titech.ac.jp>
  • To: Brice Goglin <Brice.Goglin@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>"
  • Date: Thu, 28 Jun 2012 15:03:21 +0900
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Brice,
Hmm, wired. But I 'll check the code and the environment .
Thank you very much for the comment.
On Thu, Jun 28, 2012 at 2:53 PM, Brice Goglin <Brice.Goglin@inria.fr> wrote:
> Le 28/06/2012 07:37, Keisuke Fukuda a écrit :
>> Dear all,
>> I've been seeing a strange error,
>> StarPU function <starpu_task_submit> returned unexpected value: <-19>
>> My code is calling starpu_task_submit() as the samples do,  like
>> int ret = starpu_task_submit(task_ulist);
>> STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_submit");
>> The failing task uses partitioning and combined workers features.
>> I set STARPU_SCHED=pheft and it seems to be causing the problem,
>> because everything's fine with STARPU_SCHED=heft .
>> The error still happens even if I stop using partitioning feature on the
>> task.
>> Is there something wrong with pheft scheduling or any point that I
>> should take care?
>> I searched the StarPU source code but couldn't find what -19 or 19 means.
> 19 is ENODEV, so some device may be missing/unexisting here.
> Brice
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
FUKUDA, Keisuke<fukuda@matsulab.is.titech.ac.jp>
Dept. of Math. & Comp. Sciences
Satoshi Matsuoka Lab.,
Tokyo Institute of Technology
福田圭祐 <fukuda@matsulab.is.titech.ac.jp>
東京工業大学 数理・計算科学専攻 松岡研究室
Haut de le page
