Archives de la liste
Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>"
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>"
- Date: Thu, 28 Jun 2012 07:53:13 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Le 28/06/2012 07:37, Keisuke Fukuda a écrit :
> Dear all,
> I've been seeing a strange error,
> StarPU function <starpu_task_submit> returned unexpected value: <-19>
> My code is calling starpu_task_submit() as the samples do, like
> int ret = starpu_task_submit(task_ulist);
> STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_submit");
> The failing task uses partitioning and combined workers features.
> I set STARPU_SCHED=pheft and it seems to be causing the problem,
> because everything's fine with STARPU_SCHED=heft .
> The error still happens even if I stop using partitioning feature on the
> task.
> Is there something wrong with pheft scheduling or any point that I
> should take care?
> I searched the StarPU source code but couldn't find what -19 or 19 means.
19 is ENODEV, so some device may be missing/unexisting here.
Brice
- [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Keisuke Fukuda, 28/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Keisuke Fukuda, 28/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Brice Goglin, 28/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Samuel Thibault, 29/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Keisuke Fukuda, 29/06/2012
- Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>", Cyril Roelandt, 29/06/2012
