Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>"
Archives de la liste
Chronologique Discussions
  • From: Keisuke Fukuda <fukuda@matsulab.is.titech.ac.jp>
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Strange error " <starpu_task_submit> returned unexpected value: <-19>"
  • Date: Thu, 28 Jun 2012 14:40:29 +0900
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
I fogot to say that currently I'm using
StarPU-1.0 branch revision 6659.
Keisuke Fukuda
On Thu, Jun 28, 2012 at 2:37 PM, Keisuke Fukuda
<fukuda@matsulab.is.titech.ac.jp> wrote:
> Dear all,
> I've been seeing a strange error,
> StarPU function <starpu_task_submit> returned unexpected value: <-19>
> My code is calling starpu_task_submit() as the samples do, like
> int ret = starpu_task_submit(task_ulist);
> STARPU_CHECK_RETURN_VALUE(ret, "starpu_task_submit");
> The failing task uses partitioning and combined workers features.
> I set STARPU_SCHED=pheft and it seems to be causing the problem,
> because everything's fine with STARPU_SCHED=heft .
> The error still happens even if I stop using partitioning feature on the
> task.
> Is there something wrong with pheft scheduling or any point that I
> should take care?
> I searched the StarPU source code but couldn't find what -19 or 19 means.
> Please tell me if further information is necessary.
> Thank you.
> FUKUDA, Keisuke<fukuda@matsulab.is.titech.ac.jp>
> Dept. of Math. & Comp. Sciences
> Satoshi Matsuoka Lab.,
> Tokyo Institute of Technology
> 福田圭祐 <fukuda@matsulab.is.titech.ac.jp>
> 東京工業大学 数理・計算科学専攻 松岡研究室
Haut de le page
