Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Fwd: Informationn de starpu avec hwloc mais sans pkgconfig
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Cedric Castagnede <cedric.castagnede@inria.fr>, Pierre RAMET <ramet@labri.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Fwd: Informationn de starpu avec hwloc mais sans pkgconfig
  • Date: Tue, 25 Sep 2012 00:05:47 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 09/24/2012 11:59 PM, Samuel Thibault wrote:
Samuel Thibault, le Mon 24 Sep 2012 23:57:42 +0200, a écrit :
Cedric Castagnede, le Mon 24 Sep 2012 17:23:37 +0200, a écrit :
export HWLOC_LIBS="-L/Users/ramet/Work/hwloc/lib -lhwloc"
export HWLOC_CFLAGS="-I/Users/ramet/Work/hwloc/include"
puis : ./configure --prefix=/Users/ramet/Work/starpu/install --with-hwloc
WARNING: hwloc was not enabled. If the target machine is hyperthreaded the
performance may be impacted a lot. It is strongly recommended to install
hwloc
I don't have such issue, provided that both HWLOC_LIBS and HWLOC_CFLAGS
are set. Could you also post config.log?
Just in case, could you also try the latest trunk?
Ludovic and I started investigating this issue. It happens when pkg-config is not available on the machine. I think the easiest way to fix this is to make pkg-config mandatory, since it seems quite standard nowadays. Or we could make configure.ac look even worse.
Cyril.
Haut de le page
