Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Fwd: Informationn de starpu avec hwloc mais sans pkgconfig
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Cyril Roelandt <cyril.roelandt@inria.fr>
  • Cc: Cedric Castagnede <cedric.castagnede@inria.fr>, Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr, Pierre RAMET <ramet@labri.fr>
  • Subject: Re: [Starpu-devel] Fwd: Informationn de starpu avec hwloc mais sans pkgconfig
  • Date: Tue, 25 Sep 2012 09:23:05 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
configure.ac already has cases for packages which are found with or
without pkg-config. You cannot assume all libraries we are using are
provided with a pc file.
It is clear that if end-users want their packages to be detected
through pkg-config, then they need to make sure pkg-config is
available.
But here, it is requested to have hwloc detected through environment
variables, that needs to be allowed.
Cheers,
Nathalie
On Sep 25, 00:05, Cyril Roelandt wrote:
> On 09/24/2012 11:59 PM, Samuel Thibault wrote:
> >Samuel Thibault, le Mon 24 Sep 2012 23:57:42 +0200, a écrit :
> >>Cedric Castagnede, le Mon 24 Sep 2012 17:23:37 +0200, a écrit :
> >>> export HWLOC_LIBS="-L/Users/ramet/Work/hwloc/lib -lhwloc"
> >>> export HWLOC_CFLAGS="-I/Users/ramet/Work/hwloc/include"
> >>> puis : ./configure --prefix=/Users/ramet/Work/starpu/install
> >>> --with-hwloc
> >>>WARNING: hwloc was not enabled. If the target machine is hyperthreaded
> >>>the
> >>>performance may be impacted a lot. It is strongly recommended to install
> >>>hwloc
> >>I don't have such issue, provided that both HWLOC_LIBS and HWLOC_CFLAGS
> >>are set. Could you also post config.log?
> >Just in case, could you also try the latest trunk?
> Ludovic and I started investigating this issue. It happens when
> pkg-config is not available on the machine. I think the easiest way
> to fix this is to make pkg-config mandatory, since it seems quite
> standard nowadays. Or we could make configure.ac look even worse.
> Cyril.
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento Ingénieur de recherche CNRS
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Haut de le page
