Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Informationn de starpu avec hwloc mais sans pkgconfig
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: Cedric Castagnede <cedric.castagnede@inria.fr>, Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Informationn de starpu avec hwloc mais sans pkgconfig
  • Date: Tue, 25 Sep 2012 15:31:00 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
It works, and I no longer need to set HWLOC_CFLAGS and HWLOC_LIBS :)
Now I still have a small problem with the "stat" command during the "Make all
in doc" :
Making all in doc
stat: illegal option -- -
usage: stat [-FlLnqrsx] [-f format] [-t timefmt] [file ...]
Thanks,
Pierre.
Le 25 sept. 2012 à 15:22, Nathalie Furmento <nathalie.furmento@labri.fr> a
écrit :
> Pierre,
> I think the problem comes from the fact that configure.ac expects a
> directory with the option --with-hwloc.
> Could you please try again by calling
> ./configure --with-hwloc=<directory where hwloc is installed>
> Thanks,
> Nathalie
> On Sep 25, 15:12, Pierre RAMET wrote:
>> I also try with the last trunk of StarPU, I got the same results…
>> In configure.log, the following line is suspicious :
>> configure:27417: gcc -c -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE
>> -Iyes/include conftest.c >&5
>> Pierre.
>> Le 25 sept. 2012 à 09:23, Nathalie Furmento <nathalie.furmento@labri.fr> a
>> écrit :
>>> configure.ac already has cases for packages which are found with or
>>> without pkg-config. You cannot assume all libraries we are using are
>>> provided with a pc file.
>>> It is clear that if end-users want their packages to be detected
>>> through pkg-config, then they need to make sure pkg-config is
>>> available.
>>> But here, it is requested to have hwloc detected through environment
>>> variables, that needs to be allowed.
>>> Cheers,
>>> Nathalie
>>> On Sep 25, 00:05, Cyril Roelandt wrote:
>>>> On 09/24/2012 11:59 PM, Samuel Thibault wrote:
>>>>> Samuel Thibault, le Mon 24 Sep 2012 23:57:42 +0200, a écrit :
>>>>>> Cedric Castagnede, le Mon 24 Sep 2012 17:23:37 +0200, a écrit :
>>>>>>> export HWLOC_LIBS="-L/Users/ramet/Work/hwloc/lib -lhwloc"
>>>>>>> export HWLOC_CFLAGS="-I/Users/ramet/Work/hwloc/include"
>>>>>>> puis : ./configure --prefix=/Users/ramet/Work/starpu/install
>>>>>>> --with-hwloc
>>>>>>> WARNING: hwloc was not enabled. If the target machine is
>>>>>>> hyperthreaded the
>>>>>>> performance may be impacted a lot. It is strongly recommended to
>>>>>>> install
>>>>>>> hwloc
>>>>>> I don't have such issue, provided that both HWLOC_LIBS and HWLOC_CFLAGS
>>>>>> are set. Could you also post config.log?
>>>>> Just in case, could you also try the latest trunk?
>>>> Ludovic and I started investigating this issue. It happens when
>>>> pkg-config is not available on the machine. I think the easiest way
>>>> to fix this is to make pkg-config mandatory, since it seems quite
>>>> standard nowadays. Or we could make configure.ac look even worse.
>>>> Cyril.
Pierre Ramet LaBRI, INRIA Bordeaux-SO
Email: ramet@labri.fr Universite Bordeaux 1
Fax: +33 5 24 57 40 38 351 cours de la Liberation
Tel: +33 5 24 57 40 39 33405 Talence Cedex, France
Url: http://www.labri.fr/~ramet
Haut de le page
