Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Informationn de starpu avec hwloc mais sans pkgconfig
Archives de la liste
Chronologique Discussions
  • To: Pierre RAMET <ramet@labri.fr>
  • Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr, Cedric Castagnede <cedric.castagnede@inria.fr>
  • Subject: Re: [Starpu-devel] Informationn de starpu avec hwloc mais sans pkgconfig
  • Date: Tue, 25 Sep 2012 15:43:44 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 09/25/2012 03:31 PM, Pierre RAMET wrote:
It works, and I no longer need to set HWLOC_CFLAGS and HWLOC_LIBS :)
Good.
To starpu-devel: should we say that with-hwloc must always be given an argument ?
Now I still have a small problem with the "stat" command during the "Make all in
doc" :
Indeed, the documentation cannot be built on systems other than GNU/Linux. We've started to discuss this issue, and it should probably be fixed in a near future. In the meantime, if you do not really care about building the documentation, you could apply this patch :
$ svn diff Makefile.am
Index: Makefile.am
--- Makefile.am (revision 7441)
+++ Makefile.am (working copy)
@@ -18,7 +18,7 @@
CLEANFILES = *.gcno *.gcda *.linkinfo
SUBDIRS = src
-SUBDIRS += tools tests doc
+SUBDIRS += tools tests
if USE_MPI
SUBDIRS += mpi
Cyril.
Haut de le page
