Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] SOCL and ICD
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] SOCL and ICD
  • Date: Tue, 2 Oct 2012 14:24:27 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
All,
SOCL uses now ICD to enable multiple OpenCL implementations. For
reasons I cannot explain (ask Sylvain if you want more details), it
only works with the ICD implementation developed in Grenoble
(https://forge.imag.fr/projects/ocl-icd/).
The problem is how we make sure that implementation is installed on
the machine when running SOCL. Is there a way to detect the ICD
implementation installed on the machine is that specific one? (and
depending on the result, enable or disable SOCL).
A solution would be to compile OCL when we compile StarPU. OCL's
sources are available from a GIT repository (i do not know it that can
be easily integrated with StarPU's subversion server --- is there a
similar solution to svn:externals for git?). The license is BSD-2.
Any comments are welcomed.
Cheers,
Nathalie
Dr Nathalie Furmento CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Haut de le page
