Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] SOCL and ICD
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Ludovic Courtès <ludovic.courtes@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr, vincent.danjean@imag.fr, brice.videau@imag.fr
  • Subject: Re: [Starpu-devel] SOCL and ICD
  • Date: Tue, 2 Oct 2012 15:29:18 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On Oct 02, 15:07, Ludovic Courtès wrote:
> Hello!
> Nathalie Furmento <nathalie.furmento@labri.fr> skribis:
> > SOCL uses now ICD to enable multiple OpenCL implementations. For
> > reasons I cannot explain (ask Sylvain if you want more details), it
> > only works with the ICD implementation developed in Grenoble
> > (https://forge.imag.fr/projects/ocl-icd/).
> IIUC it’s the environment variable that tells where to look for OpenCL
> implementations that’s only supported by OCL, right?
That's part of the reason. But as the goal of the mail was not to
explain the reasons, that's why i did not give more details.
> > The problem is how we make sure that implementation is installed on
> > the machine when running SOCL. Is there a way to detect the ICD
> > implementation installed on the machine is that specific one? (and
> > depending on the result, enable or disable SOCL).
> If that libraries defines specific macros, or exports specific symbols,
> ‘configure’ could check for them.
That could be a solution.
Nathalie
Haut de le page
