Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] SOCL and ICD
- Date: Tue, 02 Oct 2012 15:19:22 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
Note that SOCL should work with any ICD loader (at least it works with NVidia's one). The ICD specification says that ICD clients have to be referenced in /etc/OpenCL/vendors. Consequently, SOCL and StarPU have to be installed by an admin to be used through the ICD.
The problem is that we would like users to test SOCL without having to make a system-wide installation. The ICD loader developed in Grenoble support an environment variable OCL_ICD_VENDORS that can be set to override the /etc/OpenCL/vendors path. It can be used to test a SOCL without being root.
A custom test session would look like:
> export OCL_ICD_VENDORS=/path/to/my/own/icds/
> export LD_PRELOAD=/path/to/ocl-icd/libOpenCL.so
> ./soclProgramToTest
There must be a file /path/to/my/own/icds/socl.icd containing /path/to/socl/libsocl-1.0.so. StarPU library you want to use must be in the LD_LIBRARY_PATH.
We don't want to disable SOCL if the ICD Loader installed is not the OCL's one. libsocl would work fine with it once installed.
Sylvain
Le 02/10/2012 14:24, Nathalie Furmento a écrit :
All,
SOCL uses now ICD to enable multiple OpenCL implementations. For
reasons I cannot explain (ask Sylvain if you want more details), it
only works with the ICD implementation developed in Grenoble
(https://forge.imag.fr/projects/ocl-icd/).
The problem is how we make sure that implementation is installed on
the machine when running SOCL. Is there a way to detect the ICD
implementation installed on the machine is that specific one? (and
depending on the result, enable or disable SOCL).
A solution would be to compile OCL when we compile StarPU. OCL's
sources are available from a GIT repository (i do not know it that can
be easily integrated with StarPU's subversion server --- is there a
similar solution to svn:externals for git?). The license is BSD-2.
Any comments are welcomed.
Cheers,
Nathalie
Dr Nathalie Furmento CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Sylvain Henry
CS PhD Student at INRIA/LaBRI
University of Bordeaux (France)
sylvain.henry@inria.fr
- [Starpu-devel] SOCL and ICD, Nathalie Furmento, 02/10/2012
- Re: [Starpu-devel] SOCL and ICD, Ludovic Courtès, 02/10/2012
- Re: [Starpu-devel] SOCL and ICD, Nathalie Furmento, 02/10/2012
- Re: [Starpu-devel] SOCL and ICD, Vincent Danjean, 02/10/2012
- Re: [Starpu-devel] SOCL and ICD, Sylvain HENRY, 02/10/2012
- Re: [Starpu-devel] SOCL and ICD, Sylvain HENRY, 03/10/2012
