Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] SOCL and ICD
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Sylvain HENRY <sylvain.henry@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr, vincent.danjean@imag.fr, brice.videau@imag.fr
  • Subject: Re: [Starpu-devel] SOCL and ICD
  • Date: Tue, 2 Oct 2012 15:36:40 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Even if SOCL does not have to be disabled, then we should at least
disable the execution of the examples when running make check.
Hence the question remains to know how to detect the ICD
implementation which is installed.
Cheers,
Nathalie
On Oct 02, 15:19, Sylvain HENRY wrote:
> Hi,
> Note that SOCL should work with any ICD loader (at least it works
> with NVidia's one). The ICD specification says that ICD clients have
> to be referenced in /etc/OpenCL/vendors. Consequently, SOCL and
> StarPU have to be installed by an admin to be used through the ICD.
> The problem is that we would like users to test SOCL without having
> to make a system-wide installation. The ICD loader developed in
> Grenoble support an environment variable OCL_ICD_VENDORS that can be
> set to override the /etc/OpenCL/vendors path. It can be used to test
> a SOCL without being root.
> A custom test session would look like:
> > export OCL_ICD_VENDORS=/path/to/my/own/icds/
> > export LD_PRELOAD=/path/to/ocl-icd/libOpenCL.so
> > ./soclProgramToTest
> There must be a file /path/to/my/own/icds/socl.icd containing
> /path/to/socl/libsocl-1.0.so. StarPU library you want to use must be
> in the LD_LIBRARY_PATH.
> We don't want to disable SOCL if the ICD Loader installed is not the
> OCL's one. libsocl would work fine with it once installed.
> Sylvain
> Le 02/10/2012 14:24, Nathalie Furmento a écrit :
> >All,
> >SOCL uses now ICD to enable multiple OpenCL implementations. For
> >reasons I cannot explain (ask Sylvain if you want more details), it
> >only works with the ICD implementation developed in Grenoble
> >(https://forge.imag.fr/projects/ocl-icd/).
> >The problem is how we make sure that implementation is installed on
> >the machine when running SOCL. Is there a way to detect the ICD
> >implementation installed on the machine is that specific one? (and
> >depending on the result, enable or disable SOCL).
> >A solution would be to compile OCL when we compile StarPU. OCL's
> >sources are available from a GIT repository (i do not know it that can
> >be easily integrated with StarPU's subversion server --- is there a
> >similar solution to svn:externals for git?). The license is BSD-2.
> >Any comments are welcomed.
> >Cheers,
> >Nathalie
Haut de le page
