Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] About StarPU
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Subject: Re: [Starpu-devel] About StarPU
  • Date: Thu, 18 Oct 2012 12:54:39 -0400
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Resent-date: Thu, 18 Oct 2012 19:39:48 +0200
  • Resent-from: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Resent-message-id: <20121018173948.GC4964@labri.fr>
  • Resent-to: starpu-devel@lists.gforge.inria.fr
Hello,
I am trying to run tasks on the CUDA cards on my cluster.  When running the vector_scal example I receive errors about opencl.  I tried taking out the OpenCL code, but this didn't solve the problem.  Here is the error:
oops in _starpu_opencl_init (drivers/opencl/driver_opencl.c:342) (clGetPlatformInfo NAME) ... <Invalid platform> (-32)
jvector_scal: ../include/starpu_opencl.h:43: starpu_opencl_report_error: Assertion `0' failed.
Also, I attached the config.log file.
Thanks so much!
-Jeff D
On Wed, Oct 17, 2012 at 5:44 PM, Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
Hello,
Which version of StarPU are you using? The detection of hwloc -- when
installed in a non-standard directory -- by configure was recently
fixed, and should be working fine when using the release 1.0.4.
Could you also please send us the full contents of the file config.log
Which troubles do you exactly have when trying to use StarPU without
hwloc on your cluster?
Thanks.
Regards,
Nathalie
On Oct 17, 16:52, Jeff DiMarco wrote:
> Hello again,
> I am able to use StarPU with some of the examples on my machine at work,
> but I was hoping to use it on a cluster at my university.  Currently I am
> using it --without-hwloc, and I am running into some troubles.  Am I unable
> to use my CUDA cards this way?
> In terms of using hwloc, I try to install on a cluster with
> ./configure --prefix=/home/dimarco/myhwloc
> make install
> cd ../starpu-1.1.0/
> ./configure --with-hwloc=/home/dimarco/myhwloc
> This may be relevant from the configure output:
> checking for HWLOC... no
> checking hwloc.h usability... yes
> checking hwloc.h presence... yes
> checking for hwloc.h... yes
> checking for main in -lhwloc... yes
> checking whether hwloc should be used... yes
> make
> Gives me the following problems that I can't solve:
> In file included from ../include/starpu.h:50,
>                  from ../mpi/src/starpu_mpi_private.h:21,
>                  from src/starpu_mpi_stats.c:21:
> ../include/starpu_scheduler.h:28:19: error: hwloc.h: No such file or
> directory
> ../include/starpu_scheduler.h:45: error: expected specifier-qualifier-list
> before 'hwloc_topology_t'
> make[2]: *** [starpu_mpi_stats.lo] Error 1
> make[2]: Leaving directory `/home/dimarco/starpu-1.1.0/mpi'
> make[1]: *** [all] Error 2
> make[1]: Leaving directory `/home/dimarco/starpu-1.1.0/mpi'
> make: *** [all-recursive] Error 1
> Any help is appreciated! Thanks in advance.
> -Jeff DiMarco
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento                         CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour                Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE                  Fax: +33 (0)5 24 57 40 41
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by StarPU configure 1.1.0, which was
generated by GNU Autoconf 2.68.  Invocation command line was
  $ ./configure --with-hwloc=/home/dimarco/myhwloc
## Platform. ##
hostname = geronimo.gcl.cis.udel.edu
uname -m = x86_64
uname -r = 2.6.18-194.26.1.el5.552g0001
uname -s = Linux
uname -v = #1 SMP Wed Nov 10 20:55:14 EST 2010
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = x86_64
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /opt/scyld/openmpi/gnu/bin
PATH: /opt/CollabNet_Subversion-client/bin
PATH: /usr/kerberos/bin
PATH: /opt/cula/bin
PATH: /opt/cuda/bin
PATH: /usr/local/bin
PATH: /bin
PATH: /usr/bin
PATH: /usr/share/pvm3/lib
PATH: /home/dimarco/tau-2.21.4/x86_64/bin
PATH: /home/dimarco/bin
PATH: /usr/local/cuda
## Core tests. ##
configure:3178: checking build system type
configure:3192: result: x86_64-unknown-linux-gnu
configure:3212: checking host system type
configure:3225: result: x86_64-unknown-linux-gnu
configure:3245: checking target system type
configure:3258: result: x86_64-unknown-linux-gnu
configure:3302: checking for a BSD-compatible install
configure:3370: result: /usr/bin/install -c
configure:3381: checking whether build environment is sane
configure:3431: result: yes
configure:3572: checking for a thread-safe mkdir -p
configure:3611: result: /bin/mkdir -p
configure:3624: checking for gawk
configure:3640: found /bin/gawk
configure:3651: result: gawk
configure:3662: checking whether make sets $(MAKE)
configure:3684: result: yes
configure:3841: checking for gcc
configure:3857: found /usr/bin/gcc
configure:3868: result: gcc
configure:4097: checking for C compiler version
configure:4106: gcc --version >&5
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-48)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:4117: $? = 0
configure:4106: gcc -v >&5
Using built-in specs.
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-libgcj-multifile --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --enable-plugin --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic --host=x86_64-redhat-linux
Thread model: posix
gcc version 4.1.2 20080704 (Red Hat 4.1.2-48)
configure:4106: gcc -V >&5
gcc: '-V' option must have argument
configure:4117: $? = 1
configure:4106: gcc -qversion >&5
gcc: unrecognized option '-qversion'
gcc: no input files
configure:4137: checking whether the C compiler works
configure:4159: gcc    conftest.c  >&5
configure:4163: $? = 0
configure:4211: result: yes
configure:4214: checking for C compiler default output file name
configure:4216: result: a.out
configure:4222: checking for suffix of executables
configure:4229: gcc -o conftest    conftest.c  >&5
configure:4233: $? = 0
configure:4255: result:
configure:4277: checking whether we are cross compiling
configure:4285: gcc -o conftest    conftest.c  >&5
configure:4289: $? = 0
configure:4296: ./conftest
configure:4300: $? = 0
configure:4315: result: no
configure:4320: checking for suffix of object files
configure:4342: gcc -c   conftest.c >&5
configure:4346: $? = 0
configure:4367: result: o
configure:4371: checking whether we are using the GNU C compiler
configure:4390: gcc -c   conftest.c >&5
configure:4390: $? = 0
configure:4399: result: yes
configure:4408: checking whether gcc accepts -g
configure:4428: gcc -c -g  conftest.c >&5
configure:4428: $? = 0
configure:4469: result: yes
configure:4486: checking for gcc option to accept ISO C89
configure:4550: gcc  -c -g -O2  conftest.c >&5
configure:4550: $? = 0
configure:4563: result: none needed
configure:4594: checking for style of include used by make
configure:4622: result: GNU
configure:4647: checking dependency style of gcc
configure:4757: result: gcc3
configure:4773: checking whether gcc and cc understand -c and -o together
configure:4804: gcc -c conftest.c -o conftest2.o >&5
configure:4808: $? = 0
configure:4814: gcc -c conftest.c -o conftest2.o >&5
configure:4818: $? = 0
configure:4829: cc -c conftest.c >&5
configure:4833: $? = 0
configure:4841: cc -c conftest.c -o conftest2.o >&5
configure:4845: $? = 0
configure:4851: cc -c conftest.c -o conftest2.o >&5
configure:4855: $? = 0
configure:4873: result: yes
configure:4956: checking for g++
configure:4972: found /usr/bin/g++
configure:4983: result: g++
configure:5010: checking for C++ compiler version
configure:5019: g++ --version >&5
g++ (GCC) 4.1.2 20080704 (Red Hat 4.1.2-48)
configure:5030: $? = 0
configure:5019: g++ -v >&5
Thread model: posix
configure:5019: g++ -V >&5
g++: '-V' option must have argument
configure:5030: $? = 1
configure:5019: g++ -qversion >&5
g++: unrecognized option '-qversion'
g++: no input files
configure:5034: checking whether we are using the GNU C++ compiler
configure:5053: g++ -c   conftest.cpp >&5
configure:5053: $? = 0
configure:5062: result: yes
configure:5071: checking whether g++ accepts -g
configure:5091: g++ -c -g  conftest.cpp >&5
configure:5091: $? = 0
configure:5132: result: yes
configure:5157: checking dependency style of g++
configure:5267: result: gcc3
configure:5287: checking how to run the C preprocessor
configure:5318: gcc -E  conftest.c
configure:5318: $? = 0
configure:5332: gcc -E  conftest.c
conftest.c:13:28: error: ac_nonexistent.h: No such file or directory
configure:5332: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.1.0"
| #define PACKAGE_STRING "StarPU 1.1.0"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL ""
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 1
| #define PACKAGE "starpu"
| #define VERSION "1.1.0"
| /* end confdefs.h.  */
| #include <ac_nonexistent.h>
configure:5357: result: gcc -E
configure:5377: gcc -E  conftest.c
configure:5377: $? = 0
configure:5391: gcc -E  conftest.c
configure:5391: $? = 1
| /* confdefs.h */
configure:5419: checking for a sed that does not truncate output
configure:5483: result: /bin/sed
configure:5488: checking whether ln -s works
configure:5492: result: yes
configure:5552: checking for g77
configure:5582: result: no
configure:5552: checking for xlf
configure:5552: checking for f77
configure:5552: checking for frt
configure:5552: checking for pgf77
configure:5552: checking for cf77
configure:5552: checking for fort77
configure:5552: checking for fl32
configure:5552: checking for af77
configure:5552: checking for xlf90
configure:5552: checking for f90
configure:5552: checking for pgf90
configure:5552: checking for pghpf
configure:5552: checking for epcf90
configure:5552: checking for gfortran
configure:5568: found /usr/bin/gfortran
configure:5579: result: gfortran
configure:5605: checking for Fortran 77 compiler version
configure:5614: gfortran --version >&5
GNU Fortran (GCC) 4.1.2 20080704 (Red Hat 4.1.2-48)
Copyright (C) 2007 Free Software Foundation, Inc.
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
configure:5625: $? = 0
configure:5614: gfortran -v >&5
Thread model: posix
configure:5614: gfortran -V >&5
gfortran: '-V' option must have argument
configure:5625: $? = 1
configure:5614: gfortran -qversion >&5
gfortran: unrecognized option '-qversion'
gfortran: no input files
configure:5634: checking whether we are using the GNU Fortran 77 compiler
configure:5647: gfortran -c  conftest.F >&5
configure:5647: $? = 0
configure:5656: result: yes
configure:5662: checking whether gfortran accepts -g
configure:5673: gfortran -c -g conftest.f >&5
configure:5673: $? = 0
configure:5681: result: yes
configure:5758: checking how to print strings
configure:5785: result: printf
configure:5806: checking for a sed that does not truncate output
configure:5870: result: /bin/sed
configure:5888: checking for grep that handles long lines and -e
configure:5946: result: /bin/grep
configure:5951: checking for egrep
configure:6013: result: /bin/grep -E
configure:6018: checking for fgrep
configure:6080: result: /bin/grep -F
configure:6115: checking for ld used by gcc
configure:6182: result: /usr/bin/ld
configure:6189: checking if the linker (/usr/bin/ld) is GNU ld
configure:6204: result: yes
configure:6216: checking for BSD- or MS-compatible name lister (nm)
configure:6265: result: /usr/bin/nm -B
configure:6395: checking the name lister (/usr/bin/nm -B) interface
configure:6402: gcc -c -g -O2  conftest.c >&5
configure:6405: /usr/bin/nm -B "conftest.o"
configure:6408: output
0000000000000000 B some_variable
configure:6415: result: BSD nm
configure:6419: checking the maximum length of command line arguments
configure:6544: result: 98304
configure:6561: checking whether the shell understands some XSI constructs
configure:6571: result: yes
configure:6575: checking whether the shell understands "+="
configure:6581: result: yes
configure:6616: checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format
configure:6656: result: func_convert_file_noop
configure:6663: checking how to convert x86_64-unknown-linux-gnu file names to toolchain format
configure:6683: result: func_convert_file_noop
configure:6690: checking for /usr/bin/ld option to reload object files
configure:6697: result: -r
configure:6771: checking for objdump
configure:6787: found /usr/bin/objdump
configure:6798: result: objdump
configure:6827: checking how to recognize dependent libraries
configure:7029: result: pass_all
configure:7114: checking for dlltool
configure:7144: result: no
configure:7171: checking how to associate runtime and link libraries
configure:7198: result: printf %s\n
configure:7259: checking for ar
configure:7275: found /usr/bin/ar
configure:7286: result: ar
configure:7323: checking for archiver @FILE support
configure:7340: gcc -c -g -O2  conftest.c >&5
configure:7340: $? = 0
configure:7343: ar cru libconftest.a @conftest.lst >&5
configure:7346: $? = 0
configure:7351: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:7354: $? = 1
configure:7366: result: @
configure:7424: checking for strip
configure:7440: found /usr/bin/strip
configure:7451: result: strip
configure:7523: checking for ranlib
configure:7539: found /usr/bin/ranlib
configure:7550: result: ranlib
configure:7652: checking command to parse /usr/bin/nm -B output from gcc object
configure:7771: gcc -c -g -O2  conftest.c >&5
configure:7774: $? = 0
configure:7778: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed '/ __gnu_lto/d' \> conftest.nm
configure:7781: $? = 0
configure:7847: gcc -o conftest -g -O2   conftest.c conftstm.o >&5
configure:7850: $? = 0
configure:7888: result: ok
configure:7925: checking for sysroot
configure:7955: result: no
configure:8032: gcc -c -g -O2  conftest.c >&5
configure:8035: $? = 0
configure:8198: checking for mt
configure:8228: result: no
configure:8248: checking if : is a manifest tool
configure:8254: : '-?'
configure:8262: result: no
configure:8890: checking for ANSI C header files
configure:8910: gcc -c -g -O2  conftest.c >&5
configure:8910: $? = 0
configure:8983: gcc -o conftest -g -O2   conftest.c  >&5
configure:8983: $? = 0
configure:8983: ./conftest
configure:8994: result: yes
configure:9007: checking for sys/types.h
configure:9007: gcc -c -g -O2  conftest.c >&5
configure:9007: $? = 0
configure:9007: result: yes
configure:9007: checking for sys/stat.h
configure:9007: checking for stdlib.h
configure:9007: checking for string.h
configure:9007: checking for memory.h
configure:9007: checking for strings.h
configure:9007: checking for inttypes.h
configure:9007: checking for stdint.h
configure:9007: checking for unistd.h
configure:9021: checking for dlfcn.h
configure:9021: gcc -c -g -O2  conftest.c >&5
configure:9021: $? = 0
configure:9021: result: yes
configure:9518: checking for objdir
configure:9533: result: .libs
configure:9804: checking if gcc supports -fno-rtti -fno-exceptions
configure:9822: gcc -c -g -O2  -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option "-fno-rtti" is valid for C++/ObjC++ but not for C
configure:9826: $? = 0
configure:9839: result: no
configure:10149: checking for gcc option to produce PIC
configure:10156: result: -fPIC -DPIC
configure:10164: checking if gcc PIC flag -fPIC -DPIC works
configure:10182: gcc -c -g -O2  -fPIC -DPIC -DPIC conftest.c >&5
configure:10186: $? = 0
configure:10199: result: yes
configure:10228: checking if gcc static flag -static works
configure:10256: result: yes
configure:10271: checking if gcc supports -c -o file.o
configure:10292: gcc -c -g -O2  -o out/conftest2.o conftest.c >&5
configure:10296: $? = 0
configure:10318: result: yes
configure:10326: checking if gcc supports -c -o file.o
configure:10373: result: yes
configure:10406: checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:11568: result: yes
configure:11605: checking whether -lc should be explicitly linked in
configure:11613: gcc -c -g -O2  conftest.c >&5
configure:11616: $? = 0
configure:11631: gcc -shared  -fPIC -DPIC conftest.o  -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /bin/grep  -lc  \>/dev/null 2\>\&1
configure:11634: $? = 0
configure:11648: result: no
configure:11813: checking dynamic linker characteristics
configure:12328: gcc -o conftest -g -O2   -Wl,-rpath -Wl,/foo conftest.c  >&5
configure:12328: $? = 0
configure:12562: result: GNU/Linux ld.so
configure:12669: checking how to hardcode library paths into programs
configure:12694: result: immediate
configure:13234: checking whether stripping libraries is possible
configure:13239: result: yes
configure:13274: checking if libtool supports shared libraries
configure:13276: result: yes
configure:13279: checking whether to build shared libraries
configure:13300: result: yes
configure:13303: checking whether to build static libraries
configure:13307: result: yes
configure:13330: checking how to run the C++ preprocessor
configure:13357: g++ -E  conftest.cpp
configure:13357: $? = 0
configure:13371: g++ -E  conftest.cpp
conftest.cpp:25:28: error: ac_nonexistent.h: No such file or directory
configure:13371: $? = 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
configure:13396: result: g++ -E
configure:13416: g++ -E  conftest.cpp
configure:13416: $? = 0
configure:13430: g++ -E  conftest.cpp
configure:13430: $? = 1
| /* confdefs.h */
configure:13600: checking for ld used by g++
configure:13667: result: /usr/bin/ld -m elf_x86_64
configure:13674: checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld
configure:13689: result: yes
configure:13744: checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:14748: result: yes
configure:14783: g++ -c -g -O2  conftest.cpp >&5
configure:14786: $? = 0
configure:15306: checking for g++ option to produce PIC
configure:15313: result: -fPIC -DPIC
configure:15321: checking if g++ PIC flag -fPIC -DPIC works
configure:15339: g++ -c -g -O2  -fPIC -DPIC -DPIC conftest.cpp >&5
configure:15343: $? = 0
configure:15356: result: yes
configure:15379: checking if g++ static flag -static works
configure:15407: result: yes
configure:15419: checking if g++ supports -c -o file.o
configure:15440: g++ -c -g -O2  -o out/conftest2.o conftest.cpp >&5
configure:15444: $? = 0
configure:15466: result: yes
configure:15471: checking if g++ supports -c -o file.o
configure:15518: result: yes
configure:15548: checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:15585: result: yes
configure:15728: checking dynamic linker characteristics
configure:16411: result: GNU/Linux ld.so
configure:16464: checking how to hardcode library paths into programs
configure:16489: result: immediate
configure:16638: checking if libtool supports shared libraries
configure:16640: result: yes
configure:16643: checking whether to build shared libraries
configure:16663: result: yes
configure:16666: checking whether to build static libraries
configure:16670: result: yes
configure:16974: checking for gfortran option to produce PIC
configure:16981: result: -fPIC
configure:16989: checking if gfortran PIC flag -fPIC works
configure:17007: gfortran -c -g -O2 -fPIC conftest.f >&5
configure:17011: $? = 0
configure:17024: result: yes
configure:17047: checking if gfortran static flag -static works
configure:17075: result: yes
configure:17087: checking if gfortran supports -c -o file.o
configure:17108: gfortran -c -g -O2 -o out/conftest2.o conftest.f >&5
configure:17112: $? = 0
configure:17134: result: yes
configure:17139: checking if gfortran supports -c -o file.o
configure:17186: result: yes
configure:17216: checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries
configure:18328: result: yes
configure:18471: checking dynamic linker characteristics
configure:19148: result: GNU/Linux ld.so
configure:19201: checking how to hardcode library paths into programs
configure:19226: result: immediate
configure:19279: checking whether ln -s works
configure:19283: result: yes
configure:19291: checking for ANSI C header files
configure:19395: result: yes
configure:19404: checking for C/C++ restrict keyword
configure:19429: gcc -c -g -O2  conftest.c >&5
configure:19429: $? = 0
configure:19437: result: __restrict
configure:19455: checking for lib
configure:19488: result: no
configure:19528: checking size of void *
configure:19533: gcc -o conftest -g -O2   conftest.c  >&5
configure:19533: $? = 0
configure:19533: ./conftest
configure:19547: result: 8
configure:19613: checking for pthread_create in -lpthread
configure:19638: gcc -o conftest -g -O2   conftest.c -lpthread   >&5
configure:19638: $? = 0
configure:19647: result: yes
configure:19673: gcc -c -g -O2  conftest.c >&5
configure:19673: $? = 0
configure:19679: checking for library containing sqrt
configure:19710: gcc -o conftest -g -O2   conftest.c -lpthread  >&5
conftest.c:38: warning: conflicting types for built-in function 'sqrt'
/tmp/cc2wWTVN.o: In function `main':
/home/dimarco/starpu-1.1.0/conftest.c:42: undefined reference to `sqrt'
collect2: ld returned 1 exit status
configure:19710: $? = 1
| /* confdefs.h */
| #define restrict __restrict
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/home/dimarco/starpu-1.1.0"
| #define STARPU_SRC_DIR "/home/dimarco/starpu-1.1.0/."
| #define HAVE_LIBPTHREAD 1
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqrt ();
| int
| main ()
| return sqrt ();
|   return 0;
configure:19710: gcc -o conftest -g -O2   conftest.c -lm  -lpthread  >&5
configure:19710: $? = 0
configure:19727: result: -lm
configure:19737: checking for main in -lws2_32
configure:19756: gcc -o conftest -g -O2   conftest.c -lws2_32  -lm -lpthread  >&5
/usr/bin/ld: cannot find -lws2_32
configure:19756: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:19765: result: no
configure:19779: checking for sysconf
configure:19779: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19779: $? = 0
configure:19779: result: yes
configure:19789: checking for pthread_spin_lock
configure:19789: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19789: $? = 0
configure:19789: result: yes
configure:19805: checking for pthread_setaffinity_np
configure:19805: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19805: $? = 0
configure:19805: result: yes
configure:19818: checking for posix_memalign
configure:19818: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19818: $? = 0
configure:19818: result: yes
configure:19831: checking for memalign
configure:19831: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19831: $? = 0
configure:19831: result: yes
configure:19844: checking for drand48
configure:19844: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19844: $? = 0
configure:19844: result: yes
configure:19851: checking for erand48_r
configure:19851: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19851: $? = 0
configure:19851: result: yes
configure:19878: checking for strerror_r
configure:19878: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19878: $? = 0
configure:19878: result: yes
configure:19887: checking for setenv
configure:19887: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19887: $? = 0
configure:19887: result: yes
configure:19896: checking for unsetenv
configure:19896: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19896: $? = 0
configure:19896: result: yes
configure:19905: checking for nearbyintf
configure:19905: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
conftest.c:66: warning: conflicting types for built-in function 'nearbyintf'
configure:19905: $? = 0
configure:19905: result: yes
configure:19914: checking for rintf
configure:19914: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
conftest.c:67: warning: conflicting types for built-in function 'rintf'
configure:19914: $? = 0
configure:19914: result: yes
configure:19938: checking malloc.h usability
configure:19938: gcc -c -g -O2  conftest.c >&5
configure:19938: $? = 0
configure:19938: result: yes
configure:19938: checking malloc.h presence
configure:19938: gcc -E  conftest.c
configure:19938: checking for malloc.h
configure:19953: checking valgrind/valgrind.h usability
configure:19953: gcc -c -g -O2  conftest.c >&5
conftest.c:80:31: error: valgrind/valgrind.h: No such file or directory
configure:19953: $? = 1
| /* confdefs.h */
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| #  include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <valgrind/valgrind.h>
configure:19953: result: no
configure:19953: checking valgrind/valgrind.h presence
configure:19953: gcc -E  conftest.c
conftest.c:47:31: error: valgrind/valgrind.h: No such file or directory
| /* confdefs.h */
configure:19953: checking for valgrind/valgrind.h
configure:19968: checking whether the target supports __sync_val_compare_and_swap
configure:19985: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:19985: $? = 0
configure:19993: result: yes
configure:20003: checking whether the target supports __sync_bool_compare_and_swap
configure:20020: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:20020: $? = 0
configure:20028: result: yes
configure:20038: checking whether the target supports __sync_fetch_and_add
configure:20055: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:20055: $? = 0
configure:20063: result: yes
configure:20073: checking whether the target supports __sync_fetch_and_or
configure:20090: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:20090: $? = 0
configure:20098: result: yes
configure:20108: checking whether the target supports __sync_lock_test_and_set
configure:20125: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:20125: $? = 0
configure:20133: result: yes
configure:20143: checking whether the target supports __sync_synchronize
configure:20160: gcc -o conftest -g -O2   conftest.c -lm -lpthread  >&5
configure:20160: $? = 0
configure:20168: result: yes
configure:20180: checking for library containing set_mempolicy
configure:20211: gcc -o conftest -g -O2  -D_GNU_SOURCE   conftest.c  >&5
/tmp/cc6MvmA0.o: In function `main':
/home/dimarco/starpu-1.1.0/conftest.c:64: undefined reference to `set_mempolicy'
configure:20211: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char set_mempolicy ();
| int
| main ()
| return set_mempolicy ();
|   return 0;
configure:20211: gcc -o conftest -g -O2  -D_GNU_SOURCE   conftest.c -lnuma   >&5
configure:20211: $? = 0
configure:20228: result: -lnuma
configure:20242: checking whether libnuma is available
configure:20244: result: yes
configure:20258: checking maximum number of CPUs
configure:20267: result: 64
configure:20275: checking whether CPUs should be used
configure:20284: result: yes
configure:20317: checking maximum number of CUDA devices
configure:20326: result: 4
configure:20405: checking whether CUDA is available
configure:20408: result:
configure:20422: checking cuda.h usability
configure:20422: gcc -c -g -O2  -D_GNU_SOURCE  conftest.c >&5
conftest.c:91:18: error: cuda.h: No such file or directory
configure:20422: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_LIBNUMA /**/
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_NMAX_COMBINEDWORKERS 128
| #define STARPU_MAXCUDADEVS 4
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <cuda.h>
configure:20422: result: no
configure:20422: checking cuda.h presence
configure:20422: gcc -E  -D_GNU_SOURCE  conftest.c
conftest.c:58:18: error: cuda.h: No such file or directory
| /* confdefs.h */
| #include <cuda.h>
configure:20422: checking for cuda.h
configure:20881: checking whether CUDA is available
configure:20884: result:
configure:20898: checking cuda.h usability
configure:20898: gcc -c -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c >&5
configure:20898: $? = 0
configure:20898: result: yes
configure:20898: checking cuda.h presence
configure:20898: gcc -E  -D_GNU_SOURCE  -I/opt/cuda/include conftest.c
configure:20898: checking for cuda.h
configure:21192: checking whether CUDA is available with:
configure:21194: result:
configure:21197: checking for main in -lcuda
configure:21216: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include   conftest.c -lcuda  -lm -lpthread  >&5
configure:21216: $? = 0
configure:21225: result: yes
configure:21236: checking for main in -lcudart
configure:21255: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/opt/cuda/include   conftest.c -lcudart  -lm -lpthread  >&5
/usr/bin/ld: cannot find -lcudart
configure:21255: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:21264: result: no
configure:21357: checking whether CUDA is available in /usr/local/cuda
configure:21363: result:
configure:21377: checking cuda.h usability
configure:21377: gcc -c -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c >&5
configure:21377: $? = 0
configure:21377: result: yes
configure:21377: checking cuda.h presence
configure:21377: gcc -E  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c
configure:21377: checking for cuda.h
configure:21531: checking whether CUDA is available with: -L/usr/local/cuda/lib64
configure:21533: result:
configure:21536: checking for main in -lcuda
configure:21555: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  -L/usr/local/cuda/lib64 conftest.c -lcuda  -lm -lpthread  >&5
configure:21555: $? = 0
configure:21564: result: yes
configure:21575: checking for main in -lcudart
configure:21594: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  -L/usr/local/cuda/lib64 conftest.c -lcudart  -lm -lpthread  >&5
configure:21594: $? = 0
configure:21603: result: yes
configure:21617: checking for main in -lcublas
configure:21636: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  -L/usr/local/cuda/lib64 -lcudart conftest.c -lcublas  -lm -lpthread  >&5
configure:21636: $? = 0
configure:21645: result: yes
configure:21824: checking whether CUDA is working
configure:21843: gcc -c -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include -I/usr/local/cuda/include conftest.c >&5
configure:21843: $? = 0
configure:21863: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include -I/usr/local/cuda/include  -L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda conftest.c -lm -lpthread  >&5
configure:21863: $? = 0
configure:21863: ./conftest
configure:21888: result: yes
configure:21902: checking for nvcc
configure:21921: found /opt/cuda/bin/nvcc
configure:21934: result: /opt/cuda/bin/nvcc
configure:21949: checking whether CUDA should be used
configure:21951: result: yes
configure:21989: checking cuda_gl_interop.h usability
configure:21989: gcc -c -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c >&5
configure:21989: $? = 0
configure:21989: result: yes
configure:21989: checking cuda_gl_interop.h presence
configure:21989: gcc -E  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c
configure:21989: checking for cuda_gl_interop.h
configure:22052: checking for pkg-config
configure:22070: found /usr/bin/pkg-config
configure:22082: result: /usr/bin/pkg-config
configure:22107: checking pkg-config is at least version 0.9.0
configure:22110: result: yes
configure:22121: checking for MAGMA
configure:22129: $PKG_CONFIG --exists --print-errors "magma"
Package magma was not found in the pkg-config search path.
Perhaps you should add the directory containing `magma.pc'
to the PKG_CONFIG_PATH environment variable
No package 'magma' found
configure:22132: $? = 1
configure:22147: $PKG_CONFIG --exists --print-errors "magma"
configure:22150: $? = 1
configure:22178: result: no
configure:22206: checking whether MAGMA should be used
configure:22208: result: no
configure:22212: checking for cufftDoubleComplex
configure:22212: gcc -c -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c >&5
configure:22212: $? = 0
conftest.c: In function 'main':
conftest.c:65: error: expected expression before ')' token
configure:22212: $? = 1
| /* confdefs.h */
| #define STARPU_USE_CUDA 1
| #define HAVE_CUDA_GL_INTEROP_H 1
| #include <cufft.h>
| int
| main ()
| if (sizeof ((cufftDoubleComplex)))
| 	    return 0;
|   return 0;
configure:22212: result: yes
configure:22239: checking for main in -lcurand
configure:22258: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  -L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda conftest.c -lcurand  -lm -lpthread  >&5
configure:22258: $? = 0
configure:22267: result: yes
configure:22278: checking whether CURAND is available
configure:22280: result: yes
configure:22303: checking for cudaMemcpyPeer
configure:22303: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  -L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda conftest.c -lm -lpthread  >&5
configure:22303: $? = 0
configure:22303: result: yes
configure:22333: checking maximum number of OpenCL devices
configure:22342: result: 8
configure:22413: checking whether OpenCL is available
configure:22416: result:
configure:22429: checking CL/cl.h usability
configure:22429: gcc -c -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c >&5
configure:22429: $? = 0
configure:22429: result: yes
configure:22429: checking CL/cl.h presence
configure:22429: gcc -E  -D_GNU_SOURCE  -I/usr/local/cuda/include conftest.c
configure:22429: checking for CL/cl.h
configure:22481: checking whether OpenCL is available in no
configure:22483: result:
configure:22485: checking for main in -lOpenCL
configure:22504: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c -lOpenCL  -lm -lpthread  >&5
configure:22504: $? = 0
configure:22513: result: yes
configure:22575: checking for main in -lOpenCL
configure:22594: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c -lOpenCL  -lm -lpthread  >&5
configure:22594: $? = 0
configure:22603: result: yes
configure:22905: checking whether OpenCL should be used
configure:22907: result: yes
configure:22935: checking whether asynchronous copy should be disabled
configure:22948: result: no
configure:22956: checking whether asynchronous CUDA copy should be disabled
configure:22969: result: no
configure:22977: checking whether asynchronous OpenCL copy should be disabled
configure:22990: result: no
configure:23032: checking for elf_memory in -lelf
configure:23057: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c -lelf  -lm -lpthread  >&5
configure:23057: $? = 0
configure:23066: result: yes
configure:23080: checking for spe_context_create in -lspe2
configure:23105: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c -lspe2  -lelf -lm -lpthread  >&5
/usr/bin/ld: cannot find -lspe2
configure:23105: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_CUFFTDOUBLECOMPLEX 1
| #define STARPU_HAVE_CURAND 1
| #define HAVE_CUDA_MEMCPY_PEER /**/
| #define STARPU_MAXOPENCLDEVS 8
| #define STARPU_USE_OPENCL 1
| #define HAVE_LIBELF 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char spe_context_create ();
| int
| main ()
| return spe_context_create ();
|   return 0;
configure:23114: result: no
configure:23127: checking for spe_in_mbox_write
configure:23127: gcc -o conftest -g -O2  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c -lelf -lm -lpthread  >&5
/tmp/cckmpjzx.o: In function `main':
/home/dimarco/starpu-1.1.0/conftest.c:100: undefined reference to `spe_in_mbox_write'
configure:23127: $? = 1
| /* confdefs.h */
| /* Define spe_in_mbox_write to an innocuous variant, in case <limits.h> declares spe_in_mbox_write.
|    For example, HP-UX 11i <limits.h> declares gettimeofday.  */
| #define spe_in_mbox_write innocuous_spe_in_mbox_write
| /* System header to define __stub macros and hopefully few prototypes,
|     which can conflict with char spe_in_mbox_write (); below.
|     Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
|     <limits.h> exists even on freestanding compilers.  */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
| #undef spe_in_mbox_write
| #ifdef __cplusplus
| extern "C"
| #endif
| /* The GNU C library defines this for functions which it implements
|     to always fail with ENOSYS.  Some functions are actually named
|     something starting with __ and the normal name is an alias.  */
| #if defined __stub_spe_in_mbox_write || defined __stub___spe_in_mbox_write
| choke me
| #endif
| int
| main ()
| return spe_in_mbox_write ();
|   return 0;
configure:23127: result: no
configure:23184: checking for pkg-config
configure:23214: result: /usr/bin/pkg-config
configure:23239: checking pkg-config is at least version 0.9.0
configure:23242: result: yes
configure:23257: checking for GORDON
configure:23265: $PKG_CONFIG --exists --print-errors "libgordon"
Package libgordon was not found in the pkg-config search path.
Perhaps you should add the directory containing `libgordon.pc'
No package 'libgordon' found
configure:23268: $? = 1
configure:23283: $PKG_CONFIG --exists --print-errors "libgordon"
configure:23286: $? = 1
configure:23314: result: no
configure:23345: checking whether GORDON should be used
configure:23347: result: no
configure:23368: checking whether blocking drivers should be disabled
configure:23377: result: no
configure:23393: checking whether debug mode should be enabled
configure:23402: result: no
configure:23415: checking whether extra checks should be performed
configure:23424: result: no
configure:23432: checking whether memory status should be displayed
configure:23441: result: no
configure:23450: checking whether debug messages should be displayed
configure:23459: result: no
configure:23468: checking whether coverage testing should be enabled
configure:23477: result: no
configure:23496: checking whether FxT traces should be generated
configure:23527: result: no
configure:23703: checking whether performance debugging should be enabled
configure:23712: result: no
configure:23724: checking whether performance model debugging should be enabled
configure:23733: result: no
configure:23741: checking whether statistics should be generated
configure:23750: result: no
configure:23765: checking glpk.h usability
configure:23765: gcc -c -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c >&5
conftest.c:101:18: error: glpk.h: No such file or directory
configure:23765: $? = 1
| /* confdefs.h */
| #define STARPU_MAXGORDONDEVS 1
| #define STARPU_NON_BLOCKING_DRIVERS 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <glpk.h>
configure:23765: result: no
configure:23765: checking glpk.h presence
configure:23765: gcc -E  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c
conftest.c:68:18: error: glpk.h: No such file or directory
| /* confdefs.h */
| #include <glpk.h>
configure:23765: checking for glpk.h
configure:23777: checking for main in -lglpk
configure:23796: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lglpk   >&5
/usr/bin/ld: cannot find -lglpk
configure:23796: $? = 1
| /* confdefs.h */
| int
| main ()
| return main ();
|   return 0;
configure:23805: result: no
configure:23828: checking how many buffers can be manipulated per task
configure:23837: result: 8
configure:23860: checking maximum number of memory nodes
configure:23862: result: 13
configure:23871: checking whether allocation cache should be used
configure:23880: result: no
configure:23914: checking using explicit performance model location
configure:23916: result: no
configure:23919: checking performance models location
configure:23921: result: $HOME/.starpu/sampling/
configure:23925: checking for clock_gettime in -lrt
configure:23950: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lrt  -lelf -lm -lpthread   >&5
configure:23950: $? = 0
configure:23959: result: yes
configure:23972: checking for clock_gettime
configure:23972: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lrt -lelf -lm -lpthread   >&5
configure:23972: $? = 0
configure:23972: result: yes
configure:23985: checking Maximum number of workers
configure:23987: result: 80
configure:23996: checking maximum number of implementations
configure:24005: result: 8
configure:24034: checking for mpicc
configure:24052: found /opt/scyld/openmpi/gnu/bin/mpicc
configure:24065: result: /opt/scyld/openmpi/gnu/bin/mpicc
configure:24087: checking mpicc path
configure:24089: result: /opt/scyld/openmpi/gnu/bin/mpicc
configure:24141: checking for mpiexec
configure:24160: found /opt/scyld/openmpi/gnu/bin/mpiexec
configure:24173: result: /opt/scyld/openmpi/gnu/bin/mpiexec
configure:24185: checking whether mpiexec is available
configure:24187: result: /opt/scyld/openmpi/gnu/bin/mpiexec
configure:24208: checking whether MPI tests should be run
configure:24210: result: no
configure:24216: checking whether the StarPU MPI library should be generated
configure:24218: result: yes
configure:24236: checking whether communication statistics should be generated
configure:24245: result: no
configure:24273: checking for StarPU-Top
configure:24282: checking for qmake-qt4
configure:24315: result: no
configure:24405: checking whether compiler support -W
configure:24427: gcc -c -W  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c >&5
configure:24427: $? = 0
configure:24430: result: yes
configure:24444: checking whether compiler support -Wall
configure:24466: gcc -c -Wall  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c >&5
conftest.c:81: warning: unused variable 'hello'
configure:24466: $? = 0
configure:24469: result: yes
configure:24483: checking whether compiler support -Wextra
configure:24505: gcc -c -Wextra  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c >&5
configure:24505: $? = 0
configure:24508: result: yes
configure:24549: checking whether GCC supports plug-ins
configure:24604: gcc -c -O3 -g -O2 -gdwarf-2 -g3  -Iplugin/include conftest.c >&5
conftest.c:75:24: error: gcc-plugin.h: No such file or directory
conftest.c:76:25: error: tree.h: No such file or directory
conftest.c:77:27: error: gimple.h: No such file or directory
conftest.c:83: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fndecl'
conftest.c:83: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'call'
conftest.c:89: error: 'tree' undeclared (first use in this function)
conftest.c:89: error: (Each undeclared identifier is reported only once
conftest.c:89: error: for each function it appears in.)
conftest.c:89: error: expected ';' before 'foo'
conftest.c:94: error: 'call' undeclared (first use in this function)
conftest.c:94: error: 'fndecl' undeclared (first use in this function)
configure:24604: $? = 1
| /* confdefs.h */
| #define STARPU_NMAXBUFS 8
| #define STARPU_MAXNODES 13
| #define HAVE_LIBRT 1
| #define HAVE_CLOCK_GETTIME 1
| #define STARPU_NMAXWORKERS 80
| #define STARPU_MAXIMPLEMENTATIONS 8
| #define STARPU_USE_MPI /**/
| #include <gcc-plugin.h>
| 	      #include <tree.h>
| 	      #include <gimple.h>
| 	      #if defined __INTEL_COMPILER || defined __ICC
| 	      Beware, this compiler is a fake.  Don't use it.
| 	      #endif
| 	      tree fndecl; gimple call;
| int
| main ()
| /* Clang 3.1 doesn't support nested functions, so try to
| 	         discriminate it this way.  */
| 	      tree foo (void)
| 	        return lookup_name (get_identifier ("puts"));
| 	      fndecl = foo ();
| 	      call = gimple_build_call (fndecl, 0);
|   return 0;
configure:24620: result: no
configure:24884: WARNING: GCC plug-ins not supported; StarPU's GCC plug-in will not be built
configure:25014: checking for SOCL
configure:25528: result: yes
configure:25555: checking for gdb
configure:25573: found /usr/bin/gdb
configure:25586: result: /usr/bin/gdb
configure:25798: checking whether OpenGL rendering is enabled
configure:25802: result: no
configure:25813: checking for X
configure:25952: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lX11 -lrt -lelf -lm -lpthread   >&5
configure:25952: $? = 0
configure:26002: result: libraries , headers
configure:26101: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lrt -lelf -lm -lpthread    -lX11 >&5
configure:26101: $? = 0
configure:26199: checking for gethostbyname
configure:26199: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lrt -lelf -lm -lpthread   >&5
configure:26199: $? = 0
configure:26199: result: yes
configure:26296: checking for connect
configure:26296: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lrt -lelf -lm -lpthread   >&5
configure:26296: $? = 0
configure:26296: result: yes
configure:26345: checking for remove
configure:26345: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lrt -lelf -lm -lpthread   >&5
configure:26345: $? = 0
configure:26345: result: yes
configure:26394: checking for shmat
configure:26394: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lrt -lelf -lm -lpthread   >&5
configure:26394: $? = 0
configure:26394: result: yes
configure:26452: checking for IceConnectionNumber in -lICE
configure:26477: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lICE  -lrt -lelf -lm -lpthread   >&5
configure:26477: $? = 0
configure:26486: result: yes
configure:26892: checking for library containing sgemm_
configure:26923: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c  >&5
/tmp/ccis83Sc.o: In function `main':
/home/dimarco/starpu-1.1.0/conftest.c:88: undefined reference to `sgemm_'
configure:26923: $? = 1
| /* confdefs.h */
| #define STARPU_GDB_PATH "/usr/bin/gdb"
| #define STARPU_HAVE_X11 1
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
|   return 0;
configure:26923: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include   conftest.c -lblas   >&5
/usr/bin/ld: cannot find -lblas
| /* confdefs.h */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
|   return 0;
configure:26940: result: no
configure:27011: checking which BLAS lib should be used
configure:27013: result: none
configure:27037: checking for FFTW
configure:27045: $PKG_CONFIG --exists --print-errors "fftw3"
Package fftw3 was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3.pc'
No package 'fftw3' found
configure:27048: $? = 1
configure:27063: $PKG_CONFIG --exists --print-errors "fftw3"
configure:27066: $? = 1
configure:27094: result: no
configure:27124: checking for FFTWF
configure:27132: $PKG_CONFIG --exists --print-errors "fftw3f"
Package fftw3f was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3f.pc'
No package 'fftw3f' found
configure:27135: $? = 1
configure:27150: $PKG_CONFIG --exists --print-errors "fftw3f"
configure:27153: $? = 1
configure:27181: result: no
configure:27211: checking for FFTWL
configure:27219: $PKG_CONFIG --exists --print-errors "fftw3l"
Package fftw3l was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3l.pc'
No package 'fftw3l' found
configure:27222: $? = 1
configure:27237: $PKG_CONFIG --exists --print-errors "fftw3l"
configure:27240: $? = 1
configure:27268: result: no
configure:27324: checking for HWLOC
configure:27332: $PKG_CONFIG --exists --print-errors "hwloc"
Package hwloc was not found in the pkg-config search path.
Perhaps you should add the directory containing `hwloc.pc'
No package 'hwloc' found
configure:27335: $? = 1
configure:27350: $PKG_CONFIG --exists --print-errors "hwloc"
configure:27353: $? = 1
configure:27381: result: no
configure:27402: checking hwloc.h usability
configure:27402: gcc -c -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include  -I/home/dimarco/myhwloc/include conftest.c >&5
configure:27402: $? = 0
configure:27402: result: yes
configure:27402: checking hwloc.h presence
configure:27402: gcc -E  -D_GNU_SOURCE  -I/usr/local/cuda/include  -I/home/dimarco/myhwloc/include conftest.c
configure:27402: checking for hwloc.h
configure:27411: checking for main in -lhwloc
configure:27430: gcc -o conftest -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include  -I/home/dimarco/myhwloc/include  -L/home/dimarco/myhwloc/lib conftest.c -lhwloc  -lrt -lelf -lm -lpthread   >&5
configure:27430: $? = 0
configure:27439: result: yes
configure:27475: checking whether hwloc should be used
configure:27477: result: yes
configure:27483: checking f77.h usability
configure:27483: gcc -c -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c >&5
conftest.c:111:17: error: f77.h: No such file or directory
configure:27483: $? = 1
| /* confdefs.h */
| #define STARPU_HAVE_HWLOC 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <f77.h>
configure:27483: result: no
configure:27483: checking f77.h presence
configure:27483: gcc -E  -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c
conftest.c:78:17: error: f77.h: No such file or directory
| /* confdefs.h */
| #include <f77.h>
configure:27483: checking for f77.h
configure:27491: checking whether header file f77.h is available
configure:27493: result: no
configure:27516: checking for icc
configure:27546: result: no
configure:27613: checking for help2man
configure:27643: result: no
configure:27664: checking for struct cudaDeviceProp.pciDomainID
configure:27664: gcc -c -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c >&5
configure:27664: $? = 0
configure:27664: result: yes
configure:27673: checking for struct cudaDeviceProp.pciBusID
configure:27673: gcc -c -O3 -g -O2 -gdwarf-2 -g3   -D_GNU_SOURCE  -I/usr/local/cuda/include  conftest.c >&5
configure:27673: $? = 0
configure:27673: result: yes
configure:27978: creating ./config.status
## Running config.status. ##
This file was extended by StarPU config.status 1.1.0, which was
  CONFIG_FILES    =
  CONFIG_HEADERS  =
  CONFIG_LINKS    =
  CONFIG_COMMANDS =
  $ ./config.status
on geronimo.gcl.cis.udel.edu
config.status:1478: creating tests/regression/regression.sh
config.status:1478: creating tests/regression/profiles
config.status:1478: creating tests/regression/profiles.build.only
config.status:1478: creating Makefile
config.status:1478: creating src/Makefile
config.status:1478: creating tools/Makefile
config.status:1478: creating tools/starpu_workers_activity
config.status:1478: creating socl/Makefile
config.status:1478: creating socl/src/Makefile
config.status:1478: creating socl/examples/Makefile
config.status:1478: creating socl/socl-1.0.pc
config.status:1478: creating libstarpu.pc
config.status:1478: creating starpu-1.0.pc
config.status:1478: creating mpi/libstarpumpi.pc
config.status:1478: creating mpi/starpumpi-1.0.pc
config.status:1478: creating starpufft/Makefile
config.status:1478: creating starpufft/libstarpufft.pc
config.status:1478: creating starpufft/starpufft-1.0.pc
config.status:1478: creating examples/Makefile
config.status:1478: creating examples/stencil/Makefile
config.status:1478: creating tests/Makefile
config.status:1478: creating doc/Makefile
config.status:1478: creating mpi/Makefile
config.status:1478: creating starpu-top/StarPU-Top.pro
config.status:1478: creating starpu-top/StarPU-Top-qwt-embed.pri
config.status:1478: creating starpu-top/StarPU-Top-qwt-system.pri
config.status:1478: creating gcc-plugin/Makefile
config.status:1478: creating gcc-plugin/src/Makefile
config.status:1478: creating gcc-plugin/tests/Makefile
config.status:1478: creating gcc-plugin/tests/run-test
config.status:1478: creating gcc-plugin/examples/Makefile
config.status:1478: creating src/common/config.h
config.status:1478: creating include/starpu_config.h
config.status:1659: include/starpu_config.h is unchanged
config.status:1478: creating gcc-plugin/src/starpu-gcc-config.h
config.status:1659: gcc-plugin/src/starpu-gcc-config.h is unchanged
config.status:1478: creating starpu-top/config.h
config.status:1659: starpu-top/config.h is unchanged
config.status:1707: executing depfiles commands
config.status:1707: executing libtool commands
config.status:1707: executing executable-scripts commands
configure:30811:
	CPUs   enabled: yes
	CUDA   enabled: yes
	OpenCL enabled: yes
	Cell   enabled: no
	Compile-time limits
	(change these with --enable-maxcpus, --enable-maxcudadev,
	--enable-maxopencldev, --enable-maxbuffers)
	Maximum number of CPUs:           64
	Maximum number of CUDA devices:   4
	Maximum number of OpenCL devices: 8
	Maximum number of memory nodes:   13
	Maximum number of task buffers:   8
	GPU-GPU transfers: yes
	Allocation cache:  no
	Magma enabled: no
	BLAS library:  none
	hwloc:         yes
	FxT trace enabled: no
	StarPU-Top:        no
	StarPU Extensions:
	       MPI enabled:   yes
	       MPI test suite: no
	       FFT Support: yes
	       GCC plug-in: no
	       GCC plug-in test suite (requires GNU Guile): no
	       SOCL enabled:  yes
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_c_restrict=__restrict
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_BLAS_LIBS_set=
ac_cv_env_BLAS_LIBS_value=
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_FFTWF_CFLAGS_set=
ac_cv_env_FFTWF_CFLAGS_value=
ac_cv_env_FFTWF_LIBS_set=
ac_cv_env_FFTWF_LIBS_value=
ac_cv_env_FFTWL_CFLAGS_set=
ac_cv_env_FFTWL_CFLAGS_value=
ac_cv_env_FFTWL_LIBS_set=
ac_cv_env_FFTWL_LIBS_value=
ac_cv_env_FFTW_CFLAGS_set=
ac_cv_env_FFTW_CFLAGS_value=
ac_cv_env_FFTW_LIBS_set=
ac_cv_env_FFTW_LIBS_value=
ac_cv_env_FXT_CFLAGS_set=
ac_cv_env_FXT_CFLAGS_value=
ac_cv_env_FXT_LDFLAGS_set=
ac_cv_env_FXT_LDFLAGS_value=
ac_cv_env_FXT_LIBS_set=
ac_cv_env_FXT_LIBS_value=
ac_cv_env_GORDON_CFLAGS_set=
ac_cv_env_GORDON_CFLAGS_value=
ac_cv_env_GORDON_LIBS_set=
ac_cv_env_GORDON_LIBS_value=
ac_cv_env_HWLOC_CFLAGS_set=
ac_cv_env_HWLOC_CFLAGS_value=
ac_cv_env_HWLOC_LIBS_set=
ac_cv_env_HWLOC_LIBS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_MAGMA_CFLAGS_set=
ac_cv_env_MAGMA_CFLAGS_value=
ac_cv_env_MAGMA_LIBS_set=
ac_cv_env_MAGMA_LIBS_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_STARPU_MS_LIB_set=
ac_cv_env_STARPU_MS_LIB_value=
ac_cv_env_XMKMF_set=
ac_cv_env_XMKMF_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_f77_compiler_gnu=yes
ac_cv_func_clock_gettime=yes
ac_cv_func_connect=yes
ac_cv_func_cudaMemcpyPeer=yes
ac_cv_func_drand48=yes
ac_cv_func_erand48_r=yes
ac_cv_func_gethostbyname=yes
ac_cv_func_memalign=yes
ac_cv_func_nearbyintf=yes
ac_cv_func_posix_memalign=yes
ac_cv_func_pthread_setaffinity_np=yes
ac_cv_func_pthread_spin_lock=yes
ac_cv_func_remove=yes
ac_cv_func_rintf=yes
ac_cv_func_setenv=yes
ac_cv_func_shmat=yes
ac_cv_func_spe_in_mbox_write=no
ac_cv_func_strerror_r=yes
ac_cv_func_sysconf=yes
ac_cv_func_unsetenv=yes
ac_cv_have_gcc_plugins=no
ac_cv_have_sync_bool_compare_and_swap=yes
ac_cv_have_sync_fetch_and_add=yes
ac_cv_have_sync_fetch_and_or=yes
ac_cv_have_sync_lock_test_and_set=yes
ac_cv_have_sync_synchronize=yes
ac_cv_have_sync_val_compare_and_swap=yes
ac_cv_have_x='have_x=yes	ac_x_includes='\'''\''	ac_x_libraries='\'''\'''
ac_cv_header_cuda_gl_interop_h=yes
ac_cv_header_dlfcn_h=yes
ac_cv_header_f77_h=no
ac_cv_header_glpk_h=no
ac_cv_header_hwloc_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_malloc_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_header_valgrind_valgrind_h=no
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_lib_ICE_IceConnectionNumber=yes
ac_cv_lib_OpenCL=ac_cv_lib_OpenCL_main
ac_cv_lib_cublas=ac_cv_lib_cublas_main
ac_cv_lib_cuda=ac_cv_lib_cuda_main
ac_cv_lib_cudart=ac_cv_lib_cudart_main
ac_cv_lib_curand=ac_cv_lib_curand_main
ac_cv_lib_curand_main=yes
ac_cv_lib_elf_elf_memory=yes
ac_cv_lib_glpk_main=no
ac_cv_lib_hwloc=ac_cv_lib_hwloc_main
ac_cv_lib_hwloc_main=yes
ac_cv_lib_pthread_pthread_create=yes
ac_cv_lib_rt_clock_gettime=yes
ac_cv_lib_spe2_spe_context_create=no
ac_cv_lib_ws2_32=ac_cv_lib_ws2_32_main
ac_cv_lib_ws2_32_main=no
ac_cv_member_struct_cudaDeviceProp_pciBusID=yes
ac_cv_member_struct_cudaDeviceProp_pciDomainID=yes
ac_cv_objext=o
ac_cv_path_EGREP='/bin/grep -E'
ac_cv_path_FGREP='/bin/grep -F'
ac_cv_path_GDB=/usr/bin/gdb
ac_cv_path_GREP=/bin/grep
ac_cv_path_NVCC=/opt/cuda/bin/nvcc
ac_cv_path_SED=/bin/sed
ac_cv_path_ac_pt_PKG_CONFIG=/usr/bin/pkg-config
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/bin/mkdir
ac_cv_path_mpicc_path=/opt/scyld/openmpi/gnu/bin/mpicc
ac_cv_path_mpiexec_path=/opt/scyld/openmpi/gnu/bin/mpiexec
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_CXXCPP='g++ -E'
ac_cv_prog_ac_ct_AR=ar
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_F77=gfortran
ac_cv_prog_ac_ct_OBJDUMP=objdump
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_ac_ct_STRIP=strip
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cc_gcc_c_o=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=yes
ac_cv_prog_make_make_set=yes
ac_cv_search_set_mempolicy=-lnuma
ac_cv_search_sgemm_=no
ac_cv_search_sqrt=-lm
ac_cv_sizeof_void_p=8
ac_cv_target=x86_64-unknown-linux-gnu
ac_cv_type_cufftDoubleComplex=yes
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
lt_cv_ar_at_file=@
lt_cv_archive_cmds_need_lc=no
lt_cv_deplibs_check_method=pass_all
lt_cv_file_magic_cmd='$MAGIC_CMD'
lt_cv_file_magic_test_file=
lt_cv_ld_reload_flag=-r
lt_cv_nm_interface='BSD nm'
lt_cv_objdir=.libs
lt_cv_path_LD=/usr/bin/ld
lt_cv_path_LDCXX='/usr/bin/ld -m elf_x86_64'
lt_cv_path_NM='/usr/bin/nm -B'
lt_cv_path_mainfest_tool=no
lt_cv_prog_compiler_c_o=yes
lt_cv_prog_compiler_c_o_CXX=yes
lt_cv_prog_compiler_c_o_F77=yes
lt_cv_prog_compiler_pic='-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX='-fPIC -DPIC'
lt_cv_prog_compiler_pic_F77=-fPIC
lt_cv_prog_compiler_pic_works=yes
lt_cv_prog_compiler_pic_works_CXX=yes
lt_cv_prog_compiler_pic_works_F77=yes
lt_cv_prog_compiler_rtti_exceptions=no
lt_cv_prog_compiler_static_works=yes
lt_cv_prog_compiler_static_works_CXX=yes
lt_cv_prog_compiler_static_works_F77=yes
lt_cv_prog_gnu_ld=yes
lt_cv_prog_gnu_ldcxx=yes
lt_cv_sharedlib_from_linklib_cmd='printf %s\n'
lt_cv_shlibpath_overrides_runpath=no
lt_cv_sys_global_symbol_pipe='sed -n -e '\''s/^.*[	 ]\([ABCDGIRSTW][ABCDGIRSTW]*\)[	 ][	 ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed '\''/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/  {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/  {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix='sed -n -e '\''s/^: \([^ ]*\)[ ]*$/  {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \(lib[^ ]*\)$/  {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([^ ]*\)$/  {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl='sed -n -e '\''s/^T .* \(.*\)$/extern int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''
lt_cv_sys_max_cmd_len=98304
lt_cv_to_host_file_cmd=func_convert_file_noop
lt_cv_to_tool_file_cmd=func_convert_file_noop
## Output variables. ##
ACLOCAL='${SHELL} /home/dimarco/starpu-1.1.0/build-aux/missing --run aclocal-1.11'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /home/dimarco/starpu-1.1.0/build-aux/missing --run tar'
AM_BACKSLASH='\'
AM_DEFAULT_VERBOSITY='0'
AR='ar'
AS='as'
ATLASDIR=''
ATLAS_BLAS_LIB_FALSE=''
ATLAS_BLAS_LIB_TRUE='#'
AUTOCONF='${SHELL} /home/dimarco/starpu-1.1.0/build-aux/missing --run autoconf'
AUTOHEADER='${SHELL} /home/dimarco/starpu-1.1.0/build-aux/missing --run autoheader'
AUTOMAKE='${SHELL} /home/dimarco/starpu-1.1.0/build-aux/missing --run automake-1.11'
AWK='gawk'
BLAS_LIB='none'
BLAS_LIBS=''
BUILD_EXAMPLES_FALSE='#'
BUILD_EXAMPLES_TRUE=''
BUILD_GCC_PLUGIN_FALSE=''
BUILD_GCC_PLUGIN_TRUE='#'
BUILD_SOCL_FALSE='#'
BUILD_SOCL_TRUE=''
BUILD_STARPUFFT_FALSE='#'
BUILD_STARPUFFT_TRUE=''
BUILD_STARPU_TOP_FALSE=''
BUILD_STARPU_TOP_TRUE='#'
CC='gcc'
CCDEPMODE='depmode=gcc3'
CC_OR_MPICC='/opt/scyld/openmpi/gnu/bin/mpicc'
CFLAGS='-O3 -g -O2 -gdwarf-2 -g3 '
COVERAGE='no'
CPP='gcc -E'
CPPFLAGS=' -D_GNU_SOURCE  -I/usr/local/cuda/include '
CXX='g++'
CXXCPP='g++ -E'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-g -O2'
CYGPATH_W='echo'
DEFS='-DHAVE_CONFIG_H'
DEPDIR='.deps'
DLLTOOL='false'
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT=''
F77='gfortran'
FFLAGS='-g -O2'
FFTWF_CFLAGS=''
FFTWF_LIBS=''
FFTWL_CFLAGS=''
FFTWL_LIBS=''
FFTW_CFLAGS=''
FFTW_LIBS=''
FXTDIR=''
FXT_CFLAGS=''
FXT_LDFLAGS=''
FXT_LIBS=''
GCC_FOR_PLUGIN=''
GCC_FOR_PLUGIN_LIBTOOL_TAG=''
GCC_PLUGIN_DIR_PKGCONFIG=''
GCC_PLUGIN_INCLUDE_DIR='plugin/include'
GCC_PLUGIN_PKGCONFIG=''
GDB='/usr/bin/gdb'
GLOBAL_AM_CFLAGS=' -W -Wall -Wextra'
GORDON_CFLAGS=''
GORDON_LIBS=''
GORDON_REQUIRES=''
GOTODIR=''
GOTO_BLAS_LIB_FALSE=''
GOTO_BLAS_LIB_TRUE='#'
GREP='/bin/grep'
GUILE=''
HAVE_FFTWFL=''
HAVE_OPENGL_FALSE=''
HAVE_OPENGL_TRUE='#'
HAVE_X11_FALSE='#'
HAVE_X11_TRUE=''
HELP2MAN=''
HWLOC_CFLAGS='-I/home/dimarco/myhwloc/include'
HWLOC_LIBS='-L/home/dimarco/myhwloc/lib -lhwloc'
HWLOC_REQUIRES='hwloc'
ICC=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LD='/usr/bin/ld -m elf_x86_64'
LDFLAGS=''
LIBOBJS=''
LIBS='-lrt -lelf -lm -lpthread  '
LIBSOCL_INTERFACE_AGE='0'
LIBSOCL_INTERFACE_CURRENT='1'
LIBSOCL_INTERFACE_REVISION='0'
LIBSTARPUFFT_INTERFACE_AGE='0'
LIBSTARPUFFT_INTERFACE_CURRENT='1'
LIBSTARPUFFT_INTERFACE_REVISION='0'
LIBSTARPUMPI_INTERFACE_AGE='0'
LIBSTARPUMPI_INTERFACE_CURRENT='1'
LIBSTARPUMPI_INTERFACE_REVISION='0'
LIBSTARPU_INTERFACE_AGE='0'
LIBSTARPU_INTERFACE_CURRENT='1'
LIBSTARPU_INTERFACE_REVISION='0'
LIBTOOL='$(SHELL) $(top_builddir)/libtool'
LIPO=''
LN_S='ln -s'
LTLIBOBJS=''
MAGMA_CFLAGS=''
MAGMA_LIBS=''
MAKEINFO='${SHELL} /home/dimarco/starpu-1.1.0/build-aux/missing --run makeinfo'
MANIFEST_TOOL=':'
MKDIR_P='/bin/mkdir -p'
MKL_BLAS_LIB_FALSE=''
MKL_BLAS_LIB_TRUE='#'
MPICC_LDFLAGS='-pthread -L/opt/scyld/openmpi/gnu/lib -lmpi -libverbs -ldat -ltorque -lnuma -ldl -lnsl -lutil -lm'
MPIEXEC='/opt/scyld/openmpi/gnu/bin/mpiexec'
NM='/usr/bin/nm -B'
NMEDIT=''
NO_BLAS_LIB_FALSE='#'
NO_BLAS_LIB_TRUE=''
NVCC='/opt/cuda/bin/nvcc'
NVCCFLAGS=' -I/usr/local/cuda/include -m64'
OBJDUMP='objdump'
OBJEXT='o'
OTOOL64=''
OTOOL=''
PACKAGE='starpu'
PACKAGE_BUGREPORT='starpu-devel@lists.gforge.inria.fr'
PACKAGE_NAME='StarPU'
PACKAGE_STRING='StarPU 1.1.0'
PACKAGE_TARNAME='starpu'
PACKAGE_URL=''
PACKAGE_VERSION='1.1.0'
PATH_SEPARATOR=':'
PKG_CONFIG='/usr/bin/pkg-config'
PKG_CONFIG_PATH=':/home/dimarco/starpu-1.1.0/:/home/dimarco/mystarpu/lib/pkgconfig:/usr/local/'
QMAKE='not-found'
QWT_PRI=''
RANLIB='ranlib'
RUN_GCC_PLUGIN_TESTS_FALSE=''
RUN_GCC_PLUGIN_TESTS_TRUE='#'
SED='/bin/sed'
SET_MAKE=''
SHELL='/bin/sh'
STARPU_BLAS_LDFLAGS=' '
STARPU_BUILD_DIR='/home/dimarco/starpu-1.1.0'
STARPU_COMM_STATS='no'
STARPU_COVERAGE_ENABLED_FALSE=''
STARPU_COVERAGE_ENABLED_TRUE='#'
STARPU_CUDA_CPPFLAGS='-I/usr/local/cuda/include'
STARPU_CUDA_FORTRAN_LDFLAGS='-lgfortran'
STARPU_CUDA_LDFLAGS='-L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda -lstdc++'
STARPU_CUFFT_LDFLAGS='-lcufft'
STARPU_CURAND_LDFLAGS=' -lcurand'
STARPU_DATA_STATS='no'
STARPU_EFFECTIVE_VERSION='1.0'
STARPU_GCC_VERSION_MAJOR=''
STARPU_GCC_VERSION_MINOR=''
STARPU_GLPK_LDFLAGS=' '
STARPU_HAVE_AM111_FALSE='#'
STARPU_HAVE_AM111_TRUE=''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE='#'
STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE=''
STARPU_HAVE_F77_H='no'
STARPU_HAVE_F77_H_FALSE=''
STARPU_HAVE_F77_H_TRUE='#'
STARPU_HAVE_FFTW=''
STARPU_HAVE_FFTWF=''
STARPU_HAVE_FFTWF_FALSE=''
STARPU_HAVE_FFTWF_TRUE='#'
STARPU_HAVE_FFTWL_FALSE=''
STARPU_HAVE_FFTWL_TRUE='#'
STARPU_HAVE_FFTW_FALSE=''
STARPU_HAVE_FFTW_TRUE='#'
STARPU_HAVE_HELP2MAN_FALSE=''
STARPU_HAVE_HELP2MAN_TRUE='#'
STARPU_HAVE_HWLOC='1'
STARPU_HAVE_ICC_FALSE=''
STARPU_HAVE_ICC_TRUE='#'
STARPU_HAVE_MAGMA=''
STARPU_HAVE_MAGMA_FALSE=''
STARPU_HAVE_MAGMA_TRUE='#'
STARPU_HAVE_MS_LIB_FALSE=''
STARPU_HAVE_MS_LIB_TRUE='#'
STARPU_HAVE_WINDOWS_FALSE=''
STARPU_HAVE_WINDOWS_TRUE='#'
STARPU_LIBNUMA_LDFLAGS=' -lnuma '
STARPU_MAJOR_VERSION='1'
STARPU_MINOR_VERSION='1'
STARPU_MPI_CHECK_FALSE=''
STARPU_MPI_CHECK_TRUE='#'
STARPU_MS_LIB=''
STARPU_MS_LIB_ARCH='X64'
STARPU_OPENCL_CPPFLAGS=' -DSTARPU_OPENCL_DATADIR=${prefix}/share/starpu/opencl'
STARPU_OPENCL_DATAdir='NONE/share/starpu/opencl/examples'
STARPU_OPENCL_LDFLAGS=' -lOpenCL'
STARPU_OPENGL_RENDER='no'
STARPU_OPENGL_RENDER_LDFLAGS=''
STARPU_PERF_DEBUG='no'
STARPU_QWT_INCLUDE=''
STARPU_QWT_LDFLAGS=''
STARPU_SRC_DIR='/home/dimarco/starpu-1.1.0/.'
STARPU_USE_CPU='yes'
STARPU_USE_CPU_FALSE='#'
STARPU_USE_CPU_TRUE=''
STARPU_USE_CUDA='yes'
STARPU_USE_CUDA_FALSE='#'
STARPU_USE_CUDA_TRUE=''
STARPU_USE_FXT='no'
STARPU_USE_FXT_FALSE=''
STARPU_USE_FXT_TRUE='#'
STARPU_USE_GORDON='no'
STARPU_USE_GORDON_FALSE=''
STARPU_USE_GORDON_TRUE='#'
STARPU_USE_OPENCL='yes'
STARPU_USE_OPENCL_FALSE='#'
STARPU_USE_OPENCL_TRUE=''
STARPU_USE_SOCL_FALSE='#'
STARPU_USE_SOCL_TRUE=''
STATS='no'
STRIP='strip'
SYSTEM_BLAS_LIB_FALSE=''
SYSTEM_BLAS_LIB_TRUE='#'
USE_MPI='yes'
USE_MPI_FALSE='#'
USE_MPI_TRUE=''
VERSION='1.1.0'
XMKMF=''
X_CFLAGS=''
X_EXTRA_LIBS=''
X_LIBS=''
X_PRE_LIBS=' -lSM -lICE'
YACC='${SHELL} /home/dimarco/starpu-1.1.0/build-aux/missing --run bison'
ac_ct_AR='ar'
ac_ct_CC='gcc'
ac_ct_CXX='g++'
ac_ct_DUMPBIN=''
ac_ct_F77='gfortran'
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE='#'
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__isrc=''
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='${prefix}'
gccplugindir=''
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /home/dimarco/starpu-1.1.0/build-aux/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='/bin/mkdir -p'
mpicc_path='/opt/scyld/openmpi/gnu/bin/mpicc'
mpiexec_path='/opt/scyld/openmpi/gnu/bin/mpiexec'
oldincludedir='/usr/include'
pdfdir='${docdir}'
pkglibdir='${libdir}/starpu'
prefix='/usr/local'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='x86_64-unknown-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='unknown'
## confdefs.h. ##
/* confdefs.h */
#define PACKAGE_NAME "StarPU"
#define PACKAGE_TARNAME "starpu"
#define PACKAGE_VERSION "1.1.0"
#define PACKAGE_STRING "StarPU 1.1.0"
#define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
#define PACKAGE_URL ""
#define STARPU_MAJOR_VERSION 1
#define STARPU_MINOR_VERSION 1
#define PACKAGE "starpu"
#define VERSION "1.1.0"
#define STARPU_HAVE_DOMAINID 1
#define STARPU_HAVE_BUSID 1
configure: exit 0
Haut de le page
