starpu-devel@inria.fr
Archives de la liste
- To: Jeff DiMarco <jdimarco218@gmail.com>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] About StarPU
- Date: Tue, 23 Oct 2012 01:21:53 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
Hello,I think you should use STARPU_VECTOR_GET_DEV_HANDLE instead of STARPU_MATRIX_GET_PTR. Then you should pass A as a parameter of a CUDA kernel invocation. Only in the kernel could A be dereferenced with A[0]. Cheers Sylvain Le 22/10/2012 23:26, Jeff DiMarco a écrit : I have another quick question. I cannot use a registered data vector from inside a CUDA task execution. I simply added a cuda_func to the hello_world example and and tried to use a buffer. float * A = (float *)STARPU_MATRIX_GET_PTR(buffers[0]); Doing this then referencing A[0] produces a Segmentation fault. Am I doing something blatantly wrong that I cannot see? Thanks in advance! -Jeff D On Mon, Oct 22, 2012 at 3:53 PM, Jeff
wrote:
Hi, Thank you very much for the help! I appreciate it. -Jeff On Thu, Oct 18, 2012 at 6:02 PM,
Sylvain HENRY <sylvain.henry@inria.fr>
wrote:
Hi,
You have to link with OpenCL library before linking with CUDA library. The latter only provides a few OpenCL symbols (especially clGetPlatformInfo) but does not provide most other symbols (clGetPlatformIDs in particular). Using CUDA's clGetPlatformInfo on platform IDs returned by another library makes libcuda fail. It has been fixed in trunk yesterday if you use pkg-config. Otherwise, you have to be sure to use -lOpenCL before -lcuda. Cheers Sylvain Le 18/10/2012 18:54, Jeff DiMarco a écrit :
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel -- Sylvain Henry CS PhD Student at INRIA/LaBRI University of Bordeaux (France) sylvain.henry@inria.fr _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel -- Sylvain Henry CS PhD Student at INRIA/LaBRI University of Bordeaux (France) sylvain.henry@inria.fr |
- Re: [Starpu-devel] About StarPU, Samuel Thibault, 15/10/2012
- Re: [Starpu-devel] About StarPU, Jeff DiMarco, 15/10/2012
- Re: [Starpu-devel] About StarPU, Jeff DiMarco, 17/10/2012
- Re: [Starpu-devel] About StarPU, Nathalie Furmento, 17/10/2012
- Re: [Starpu-devel] About StarPU, Jeff DiMarco, 18/10/2012
- Re: [Starpu-devel] About StarPU, Sylvain HENRY, 19/10/2012
- Message indisponible
- Re: [Starpu-devel] About StarPU, Sylvain HENRY, 23/10/2012
- Re: [Starpu-devel] About StarPU, Samuel Thibault, 23/10/2012
- Re: [Starpu-devel] About StarPU, Jeff DiMarco, 23/10/2012
