Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] About StarPU
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] About StarPU
  • Date: Fri, 19 Oct 2012 00:02:14 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
You have to link with OpenCL library before linking with CUDA library. The latter only provides a few OpenCL symbols (especially clGetPlatformInfo) but does not provide most other symbols (clGetPlatformIDs in particular). Using CUDA's clGetPlatformInfo on platform IDs returned by another library makes libcuda fail.
It has been fixed in trunk yesterday if you use pkg-config. Otherwise, you have to be sure to use -lOpenCL before -lcuda.
Cheers
Sylvain
Le 18/10/2012 18:54, Jeff DiMarco a écrit :
Hello,
I am trying to run tasks on the CUDA cards on my cluster.  When running the vector_scal example I receive errors about opencl.  I tried taking out the OpenCL code, but this didn't solve the problem.  Here is the error:
oops in _starpu_opencl_init (drivers/opencl/driver_opencl.c:342) (clGetPlatformInfo NAME) ... <Invalid platform> (-32)
jvector_scal: ../include/starpu_opencl.h:43: starpu_opencl_report_error: Assertion `0' failed.
Also, I attached the config.log file.
Thanks so much!
-Jeff D
On Wed, Oct 17, 2012 at 5:44 PM, Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
Hello,
Which version of StarPU are you using? The detection of hwloc -- when
installed in a non-standard directory -- by configure was recently
fixed, and should be working fine when using the release 1.0.4.
Could you also please send us the full contents of the file config.log
Which troubles do you exactly have when trying to use StarPU without
hwloc on your cluster?
Thanks.
Regards,
Nathalie
On Oct 17, 16:52, Jeff DiMarco wrote:
> Hello again,
> I am able to use StarPU with some of the examples on my machine at work,
> but I was hoping to use it on a cluster at my university.  Currently I am
> using it --without-hwloc, and I am running into some troubles.  Am I unable
> to use my CUDA cards this way?
> In terms of using hwloc, I try to install on a cluster with
> ./configure --prefix=/home/dimarco/myhwloc
> make install
> cd ../starpu-1.1.0/
> ./configure --with-hwloc=/home/dimarco/myhwloc
> This may be relevant from the configure output:
> checking for HWLOC... no
> checking hwloc.h usability... yes
> checking hwloc.h presence... yes
> checking for hwloc.h... yes
> checking for main in -lhwloc... yes
> checking whether hwloc should be used... yes
> make
> Gives me the following problems that I can't solve:
> In file included from ../include/starpu.h:50,
>                  from ../mpi/src/starpu_mpi_private.h:21,
>                  from src/starpu_mpi_stats.c:21:
> ../include/starpu_scheduler.h:28:19: error: hwloc.h: No such file or
> directory
> ../include/starpu_scheduler.h:45: error: expected specifier-qualifier-list
> before 'hwloc_topology_t'
> make[2]: *** [starpu_mpi_stats.lo] Error 1
> make[2]: Leaving directory `/home/dimarco/starpu-1.1.0/mpi'
> make[1]: *** [all] Error 2
> make[1]: Leaving directory `/home/dimarco/starpu-1.1.0/mpi'
> make: *** [all-recursive] Error 1
> Any help is appreciated! Thanks in advance.
> -Jeff DiMarco
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento                         CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour                Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE                  Fax: +33 (0)5 24 57 40 41
Sylvain Henry
CS PhD Student at INRIA/LaBRI
University of Bordeaux (France)
sylvain.henry@inria.fr
Haut de le page
