Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Sylvain HENRY <sylvain.henry@inria.fr>, Jeff DiMarco <jdimarco218@gmail.com>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] About StarPU
- Date: Tue, 23 Oct 2012 14:00:50 -0400
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Thanks for the help, I can reference A from within the cuda kernel. Why am I able to reference it from the cpu_func as opposed to cuda_func that calls the kernel? Does GET_PTR just work that way then?
Thanks so much,
Jeff
On Mon, Oct 22, 2012 at 7:25 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Sylvain HENRY, le Tue 23 Oct 2012 01:22:02 +0200, a écrit :
> I think you should use STARPU_VECTOR_GET_DEV_HANDLE instead ofWell, these are the same for CUDA, actually. GET_PTR is actually
> STARPU_MATRIX_GET_PTR.
preferred in this case, because it's really supposed to be a (CUDA)
pointer.
When executing the CUDA codelet, the pointer returned by GET_PTR is a
Jeff DiMarco wrote:
> float * A = (float *)STARPU_MATRIX_GET_PTR(buffers[0]);
> Doing this then referencing A[0] produces a Segmentation fault. Am I doing
> something blatantly wrong that I cannot see?
*CUDA* pointer, so you can not dereference it from the host.
Samuel
- Re: [Starpu-devel] About StarPU, Samuel Thibault, 15/10/2012
- Re: [Starpu-devel] About StarPU, Jeff DiMarco, 15/10/2012
- Re: [Starpu-devel] About StarPU, Jeff DiMarco, 17/10/2012
- Re: [Starpu-devel] About StarPU, Nathalie Furmento, 17/10/2012
- Re: [Starpu-devel] About StarPU, Jeff DiMarco, 18/10/2012
- Re: [Starpu-devel] About StarPU, Sylvain HENRY, 19/10/2012
- Message indisponible
- Re: [Starpu-devel] About StarPU, Sylvain HENRY, 23/10/2012
- Re: [Starpu-devel] About StarPU, Samuel Thibault, 23/10/2012
- Re: [Starpu-devel] About StarPU, Jeff DiMarco, 23/10/2012
