Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Assert fail with 8659
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Assert fail with 8659
  • Date: Thu, 14 Feb 2013 15:58:53 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I tried to use the 8659 with 8 core + 1 GPU and obtine an assertion failure :
simple: drivers/cpu/driver_cpu.c:156: execute_job_on_cpu: Assertion `func'
failed.
#0 0x00007fffec3ab645 in raise () from /lib64/libc.so.6
#1 0x00007fffec3acc33 in abort () from /lib64/libc.so.6
#2 0x00007fffec3a4329 in __assert_fail () from /lib64/libc.so.6
#3 0x00007ffff741db25 in _starpu_cpu_driver_run_once (d=<value optimized
out>) at drivers/cpu/driver_cpu.c:156
#4 0x00007ffff741de08 in _starpu_cpu_worker (arg=<value optimized out>) at
drivers/cpu/driver_cpu.c:343
#5 0x00007fffef415070 in start_thread () from /lib64/libpthread.so.0
#6 0x00007fffec44c10d in clone () from /lib64/libc.so.6
#7 0x0000000000000000 in ?? ()
This didn't occured with previous versions (latest version I tested was built
at this date 2013-01-28 17:01, I don't have the revision number anymore,
sorry (I still have the install directory, is the info inside?)).
XL.
Haut de le page
