Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Assert fail with 8659
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Xavier Lacoste <xavier.lacoste@inria.fr>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Assert fail with 8659
  • Date: Thu, 14 Feb 2013 20:44:52 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
I was not able to reproduce it running make check on StarPU on my laptop. If
the problem is still there Xavier, please send us the output of config.log,
and the configuration of your machine (namely which machine you are using on
plafrim).
Cheers,
Nathalie
On Feb 14, 20:29, Samuel Thibault wrote:
> Xavier Lacoste, le Thu 14 Feb 2013 18:07:31 +0100, a écrit :
> > The compilation passed with this configure line :
> > ./configure --prefix=/home/lacoste/starpu-trunk-cuda --with-fxt
> > --enable-maxcpus=160 --enable-max-sched-ctxs=30 CC=gcc CXX=g++
> > F77=gfortran --disable-opencl
> > --with-cuda-dir=/opt/cluster/gpu/cuda/latest
> > --with-cuda-lib-dir=/opt/cluster/gpu/cuda/latest/lib64/
> And is the assertion failure gone away?
> Samuel
Haut de le page
