Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Assert fail with 8659
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Assert fail with 8659
  • Date: Thu, 14 Feb 2013 16:27:45 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
I didn't built it directly, it's the module built by Mathieu on plafrim.
If I look into the script he used there is a make clean and make distclean,
is it sufficient ?
XL.
Le 14 févr. 2013 à 16:10, Nathalie Furmento a écrit :
> Xavier,
> With the removal of the gordon driver, a lot of code has been modified,
> including definition of starpu_task and starpu_codelet. Are you sure you
> recompiled everything properly?
> Cheers,
> Nathalie
> On 14/02/2013 15:58, Xavier Lacoste wrote:
>> Hello,
>> I tried to use the 8659 with 8 core + 1 GPU and obtine an assertion
>> failure :
>> simple: drivers/cpu/driver_cpu.c:156: execute_job_on_cpu: Assertion `func'
>> failed.
>> #0 0x00007fffec3ab645 in raise () from /lib64/libc.so.6
>> #1 0x00007fffec3acc33 in abort () from /lib64/libc.so.6
>> #2 0x00007fffec3a4329 in __assert_fail () from /lib64/libc.so.6
>> #3 0x00007ffff741db25 in _starpu_cpu_driver_run_once (d=<value optimized
>> out>) at drivers/cpu/driver_cpu.c:156
>> #4 0x00007ffff741de08 in _starpu_cpu_worker (arg=<value optimized out>)
>> at drivers/cpu/driver_cpu.c:343
>> #5 0x00007fffef415070 in start_thread () from /lib64/libpthread.so.0
>> #6 0x00007fffec44c10d in clone () from /lib64/libc.so.6
>> #7 0x0000000000000000 in ?? ()
>> This didn't occured with previous versions (latest version I tested was
>> built at this date 2013-01-28 17:01, I don't have the revision number
>> anymore, sorry (I still have the install directory, is the info inside?)).
>> XL.
>> _______________________________________________
>> Starpu-devel mailing list
>> Starpu-devel@lists.gforge.inria.fr
>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
