Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Assert fail with 8659
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Assert fail with 8659
  • Date: Thu, 14 Feb 2013 17:00:37 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello again,
I updated my repository and did :
Révision : 8671
svn st | grep "?" | awk '{print $2}'|xargs rm -r
svn st return nothing
./autogen.sh
./configure --prefix=/home/lacoste/starpu-trunk-cuda
--with-fxt=/opt/cluster/plafrim-dev/fxt/0.2.13 --enable-maxcpus=160
--enable-max-sched-ctxs=30 CC=gcc CXX=g++ F77=gfortran
make install
and the make install failed with :
/home/lacoste/starpu/trunk/socl/examples/basicsplit/basicsplit.c:112:
undefined reference to `clEnqueueMarkerWithWaitList'
must be doing something wrong...
my modules :
1) git/1.8.1.2 3) mpi/openmpi/1.4.4 5) lib/hwloc/latest
7) lib/plasma/2.5.0b1 9) gpu/cuda/latest 11) starpu/trunk
2) compiler/gcc/4.3.2 4) meta/gnu-openmpi 6) lib/mkl/latest
8) tools/cmake/2.8.9 10) fxt/latest 12) scotch/int32/5.1.12b
XL.
Le 14 févr. 2013 à 16:27, Xavier Lacoste a écrit :
> I didn't built it directly, it's the module built by Mathieu on plafrim.
> If I look into the script he used there is a make clean and make distclean,
> is it sufficient ?
> XL.
> Le 14 févr. 2013 à 16:10, Nathalie Furmento a écrit :
>> Xavier,
>> With the removal of the gordon driver, a lot of code has been modified,
>> including definition of starpu_task and starpu_codelet. Are you sure you
>> recompiled everything properly?
>> Cheers,
>> Nathalie
>> On 14/02/2013 15:58, Xavier Lacoste wrote:
>>> Hello,
>>> I tried to use the 8659 with 8 core + 1 GPU and obtine an assertion
>>> failure :
>>> simple: drivers/cpu/driver_cpu.c:156: execute_job_on_cpu: Assertion
>>> `func' failed.
>>> #0 0x00007fffec3ab645 in raise () from /lib64/libc.so.6
>>> #1 0x00007fffec3acc33 in abort () from /lib64/libc.so.6
>>> #2 0x00007fffec3a4329 in __assert_fail () from /lib64/libc.so.6
>>> #3 0x00007ffff741db25 in _starpu_cpu_driver_run_once (d=<value optimized
>>> out>) at drivers/cpu/driver_cpu.c:156
>>> #4 0x00007ffff741de08 in _starpu_cpu_worker (arg=<value optimized out>)
>>> at drivers/cpu/driver_cpu.c:343
>>> #5 0x00007fffef415070 in start_thread () from /lib64/libpthread.so.0
>>> #6 0x00007fffec44c10d in clone () from /lib64/libc.so.6
>>> #7 0x0000000000000000 in ?? ()
>>> This didn't occured with previous versions (latest version I tested was
>>> built at this date 2013-01-28 17:01, I don't have the revision number
>>> anymore, sorry (I still have the install directory, is the info inside?)).
>>> XL.
>>> _______________________________________________
>>> Starpu-devel mailing list
>>> Starpu-devel@lists.gforge.inria.fr
>>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
