Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] CUDA, StarPU and Visual Studio 2012
- Date: Thu, 21 Nov 2013 12:48:19 -0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello Dr. Nathalie Furmento,
Thanks for your fast answer.
I would be really happy, have a few more questions:
1) StarPU has no support for CUDA on 64 bits version on Windows? Just for 32 bits on Windows?
2) Does StarPU has support to use 2 machines with 2 GPU cards each one without using MPI? I mean, StarPU support this?
3) Did you work with CUDA and StarPU?
4) Is there a way to access the archives of this mail list of the developers? I bet there is a lot of usefull information there.
5) Can you please send me your paper about task programming over clusters? Couldn't get from the university network, Inria website is offline.
Thanks for your precious time,
Gabriel
On Thu, Nov 21, 2013 at 7:49 AM, Nathalie Furmento <nathalie.furmento@labri.fr> wrote:
I forgot to mention you could retrieve a zip file of a compiled version of StarPU on a 64b windows machine from the 2 following URLs:
https://ci.inria.fr/starpu/job/starpu-trunk-windows/
https://ci.inria.fr/starpu/job/starpu-v1-1-windows/
However the CUDA support is not enabled.
Cheers,
Nathalie
On 21/11/2013 10:37, Nathalie Furmento wrote:
Hello Gabriel,
The INSTALL file in the main directory of StarPU explains how to compile StarPU
on a windows machine.
It is then possible to compile a StarPU application with Visual Studio. You can look
in tools/mvsc for a solution file as well as some batch files to compile from the
command line.
Moving to linux might indeed be easier, but that's just my opinion ...
Cheers,
Nathalie
On Nov 21, 00:33, Gabriel Gazolla wrote:
Hello Inria StarPU Team,
I am a PhD Computer Science student from Brazil, Rio de Janeiro.
I'd like to test StarPU using CUDA on VS2012, but didn't find any tutorial
showing how to install StarPU on Windows 8 and integrate with Visual Studio
2012.
Can you help me?
What do you suggest? Move to Linux? Will it be easier? What version?
Thanks,
Gabriel Gazolla
Gabriel Gazolla
Doutorando em Computação - IC/UFF
<http://www.twitter.com/gabrielgazolla>
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] CUDA, StarPU and Visual Studio 2012, Gabriel Gazolla, 21/11/2013
- Re: [Starpu-devel] CUDA, StarPU and Visual Studio 2012, Nathalie Furmento, 21/11/2013
- Re: [Starpu-devel] CUDA, StarPU and Visual Studio 2012, Gabriel Gazolla, 21/11/2013
- Re: [Starpu-devel] CUDA, StarPU and Visual Studio 2012, Samuel Thibault, 21/11/2013
