Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: gabrielgazolla@gmail.com
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] CUDA, StarPU and Visual Studio 2012
- Date: Thu, 21 Nov 2013 15:54:35 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
On 21/11/2013 15:48, Gabriel Gazolla
wrote:
Hello Dr. Nathalie Furmento,
Thanks for your fast answer.
I would be really happy, have a few more questions:
1) StarPU has no support for CUDA on 64 bits version on
Windows? Just for 32 bits on Windows?
StarPU supports both 32 and 64 bits machine. Actually all our machines are 64 bits, but we kept a 32 bits machine to make sure it is working fine. 2) Does StarPU has support to use 2 machines with 2 GPU
cards each one without using MPI? I mean, StarPU support this?
You cannot use StarPU on 2 machines without MPI. 3) Did you work with CUDA and StarPU?
CUDA is fully supported within StarPU and there is a lot of tests and examples using codelets with CUDA implementations. 4) Is there a way to access the archives of this mail list
of the developers? I bet there is a lot of usefull information
there.
http://lists.gforge.inria.fr/pipermail/starpu-devel/ 5) Can you please send me your paper about task programming
over clusters? Couldn't get from the university network, Inria
website is offline.
it is available here: http://hal.inria.fr/hal-00725477 I just checked, it should be available. Cheers, Nathalie On Thu, Nov 21, 2013 at 7:49 AM,
wrote:
I forgot to mention you could retrieve a zip file of a compiled version of StarPU on a 64b windows machine from the 2 following URLs: https://ci.inria.fr/starpu/job/starpu-trunk-windows/ https://ci.inria.fr/starpu/job/starpu-v1-1-windows/ However the CUDA support is not enabled. Cheers, Nathalie On 21/11/2013 10:37, Nathalie Furmento wrote: Hello Gabriel, The INSTALL file in the main directory of StarPU explains how to compile StarPU on a windows machine. It is then possible to compile a StarPU application with Visual Studio. You can look in tools/mvsc for a solution file as well as some batch files to compile from the command line. Moving to linux might indeed be easier, but that's just my opinion ... Cheers, Nathalie On Nov 21, 00:33, Gabriel Gazolla wrote: Hello Inria StarPU Team, I am a PhD Computer Science student from Brazil, Rio de Janeiro. I'd like to test StarPU using CUDA on VS2012, but didn't find any tutorial showing how to install StarPU on Windows 8 and integrate with Visual Studio 2012. Can you help me? What do you suggest? Move to Linux? Will it be easier? What version? Thanks, Gabriel Gazolla -- Gabriel Gazolla Doutorando em Computação - IC/UFF <http://www.twitter.com/gabrielgazolla> _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Gabriel
Gazolla
Doutorando em Computação - IC/UFF |
- [Starpu-devel] CUDA, StarPU and Visual Studio 2012, Gabriel Gazolla, 21/11/2013
- Re: [Starpu-devel] CUDA, StarPU and Visual Studio 2012, Nathalie Furmento, 21/11/2013
- Re: [Starpu-devel] CUDA, StarPU and Visual Studio 2012, Gabriel Gazolla, 21/11/2013
- Re: [Starpu-devel] CUDA, StarPU and Visual Studio 2012, Samuel Thibault, 21/11/2013
