Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Question about MPI usage
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Xavier Lacoste <xl64100@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Question about MPI usage
  • Date: Mon, 3 Feb 2014 16:36:21 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
That means the node has received some data for which no MPI recv has been
posted.
Cheers,
Nathalie
On Jan 31, 17:59, Xavier Lacoste wrote:
> Hello again,
> An other question,
> I have factorized all my panels (counted it by hand on a small case) -- so
> I must have performed all my updates -- and I get this error during the
> starpu_wait_for_all() call :
> [starpu][_starpu_mpi_progress_thread_func][assert failure] Number of copy
> requests left is not zero
> (The other MPI process is just waiting for something)
> Any clue what it can come from ?
> Does that mean that I have received handles that I still need to use ?
> Regards,
> XL.
> Le 31 janv. 2014 à 10:53, Xavier Lacoste <xl64100@gmail.com> a écrit :
> > Nathalie,
> > Thanks for your fast answer, I forgot what was this parameter for when I
> > copy/paste the registering code.
> > Sorry, should have read the manual again ;)
> > XL.
> > Le 31 janv. 2014 à 10:50, Nathalie Furmento <nathalie.furmento@labri.fr>
> > a écrit :
> >> Xavier,
> >> When you want to register a data that will be allocated only when it is
> >> used for the first time, you need to set the "home node", the 2nd
> >> parameter of starpu_xxx_data_register to -1.
> >> Cheers,
> >> Nathalie
> >> On 31/01/2014 10:46, Xavier Lacoste wrote:
> >>> Hi,
> >>> I'm porting PaStiX multicore StarPU code to MPI StarPU.
> >>> I register on each node local data and halo data (data that willl be
> >>> read used to update local data or that will be updated using local
> >>> data).
> >>> halo data is registered using NULL pointer :
> >>> starpu_matrix_data_register(&(Lhalo_handle[itercblk]), 0,
> >>> (uintptr_t)NULL,
> >>> (uint32_t)HCBLK_STRIDE(itercblk),
> >>> HCBLK_COLNBR(itercblk),
> >>> sizeof(PASTIX_FLOAT));
> >>> starpu_data_set_rank(Lhalo_handle[itercblk], HCBLK_OWNER(itercblk));
> >>> starpu_data_set_tag(Lhalo_handle[itercblk], HCBLK_GCBLK(itercblk));
> >>> On the proc that possess the data, the same data is registered with an
> >>> allocated area (same owner/tag) :
> >>> starpu_matrix_data_register(&(L_handle[itercblk]), 0,
> >>> (uintptr_t)SOLV_COEFTAB(itercblk),
> >>> (uint32_t)SOLV_STRIDE(itercblk),
> >>> starpu_data_set_rank(L_handle[itercblk], SOLV_PROCNUM);
> >>> starpu_data_set_tag(L_handle[itercblk], UPDOWN_LOC2GLOB(itercblk));
> >>> When some tasks are submitted i get this error :
> >>> [starpu][_starpu_mpi_irecv_data_func][assert failure] Invalid pointer
> >>> to receive data
> >>> simple: starpu_mpi.c:487: _starpu_mpi_irecv_data_func: Assertion
> >>> `req->ptr' failed.
> >>> When I look into starpu_mpi.c:1422 i found that it is due to
> >>> starpu_data_get_local_ptr() returns a NULL pointer:
> >>> if (found_req->user_datatype ==
> >>> 0)
> >>> found_req->count = 1;
> >>> found_req->ptr =
> >>> starpu_data_get_local_ptr(found_req->data_handle);
> >>> fprintf(stdout, "%s:%d
> >>> found_req->ptr %p\n", __FILE__, __LINE__, found_req->ptr);
> >>> I'm certainly doing an error somewhere, do you have any clue ? Is this
> >>> the NULL pointer i'm giving to starpu_matrix_data_register() ?
> >>> I don't want to allocate this halo data before i need it... It should
> >>> only update my local data and be deleted, I was hopping that StarPU was
> >>> going to do that...
> >>> Any Idea of what I'm doing wrong ?
> >>> Regards,
> >>> XL.
> >>> PS: As we already gave all informations to starpu_mpi_task_build(),
> >>> wouldn't it be possible to only give the task to
> >>> starpu_mpi_task_post_build() ? That would make the code lighter :)
> >>> _______________________________________________
> >>> Starpu-devel mailing list
> >>> Starpu-devel@lists.gforge.inria.fr
> >>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento Ingénieur de recherche CNRS
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Haut de le page
