Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Question about MPI usage
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Question about MPI usage
  • Date: Tue, 25 Feb 2014 11:52:21 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Thanks, this is due to a read only array that I only register on the node
which will execute the task.
Do I need to register it on every node ? Is there an option to tell StarPU
that this buffer is already on the node that will execute the kernel ?
Thanks,
XL.
Le 3 févr. 2014 à 16:36, Nathalie Furmento <nathalie.furmento@labri.fr> a
écrit :
> Hello,
> That means the node has received some data for which no MPI recv has been
> posted.
> Cheers,
> Nathalie
> On Jan 31, 17:59, Xavier Lacoste wrote:
>> Hello again,
>> An other question,
>> I have factorized all my panels (counted it by hand on a small case) -- so
>> I must have performed all my updates -- and I get this error during the
>> starpu_wait_for_all() call :
>> [starpu][_starpu_mpi_progress_thread_func][assert failure] Number of copy
>> requests left is not zero
>> (The other MPI process is just waiting for something)
>> Any clue what it can come from ?
>> Does that mean that I have received handles that I still need to use ?
>> Regards,
>> XL.
>> Le 31 janv. 2014 à 10:53, Xavier Lacoste <xl64100@gmail.com> a écrit :
>>> Nathalie,
>>> Thanks for your fast answer, I forgot what was this parameter for when I
>>> copy/paste the registering code.
>>> Sorry, should have read the manual again ;)
>>> XL.
>>> Le 31 janv. 2014 à 10:50, Nathalie Furmento <nathalie.furmento@labri.fr>
>>> a écrit :
>>>> Xavier,
>>>> When you want to register a data that will be allocated only when it is
>>>> used for the first time, you need to set the "home node", the 2nd
>>>> parameter of starpu_xxx_data_register to -1.
>>>> Cheers,
>>>> Nathalie
>>>> On 31/01/2014 10:46, Xavier Lacoste wrote:
>>>>> Hi,
>>>>> I'm porting PaStiX multicore StarPU code to MPI StarPU.
>>>>> I register on each node local data and halo data (data that willl be
>>>>> read used to update local data or that will be updated using local
>>>>> data).
>>>>> halo data is registered using NULL pointer :
>>>>> starpu_matrix_data_register(&(Lhalo_handle[itercblk]), 0,
>>>>> (uintptr_t)NULL,
>>>>> (uint32_t)HCBLK_STRIDE(itercblk),
>>>>> HCBLK_COLNBR(itercblk),
>>>>> sizeof(PASTIX_FLOAT));
>>>>> starpu_data_set_rank(Lhalo_handle[itercblk], HCBLK_OWNER(itercblk));
>>>>> starpu_data_set_tag(Lhalo_handle[itercblk], HCBLK_GCBLK(itercblk));
>>>>> On the proc that possess the data, the same data is registered with an
>>>>> allocated area (same owner/tag) :
>>>>> starpu_matrix_data_register(&(L_handle[itercblk]), 0,
>>>>> (uintptr_t)SOLV_COEFTAB(itercblk),
>>>>> (uint32_t)SOLV_STRIDE(itercblk),
>>>>> starpu_data_set_rank(L_handle[itercblk], SOLV_PROCNUM);
>>>>> starpu_data_set_tag(L_handle[itercblk], UPDOWN_LOC2GLOB(itercblk));
>>>>> When some tasks are submitted i get this error :
>>>>> [starpu][_starpu_mpi_irecv_data_func][assert failure] Invalid pointer
>>>>> to receive data
>>>>> simple: starpu_mpi.c:487: _starpu_mpi_irecv_data_func: Assertion
>>>>> `req->ptr' failed.
>>>>> When I look into starpu_mpi.c:1422 i found that it is due to
>>>>> starpu_data_get_local_ptr() returns a NULL pointer:
>>>>> if (found_req->user_datatype == 0)
>>>>> found_req->count = 1;
>>>>> found_req->ptr =
>>>>> starpu_data_get_local_ptr(found_req->data_handle);
>>>>> fprintf(stdout, "%s:%d
>>>>> found_req->ptr %p\n", __FILE__, __LINE__, found_req->ptr);
>>>>> I'm certainly doing an error somewhere, do you have any clue ? Is this
>>>>> the NULL pointer i'm giving to starpu_matrix_data_register() ?
>>>>> I don't want to allocate this halo data before i need it... It should
>>>>> only update my local data and be deleted, I was hopping that StarPU was
>>>>> going to do that...
>>>>> Any Idea of what I'm doing wrong ?
>>>>> Regards,
>>>>> XL.
>>>>> PS: As we already gave all informations to starpu_mpi_task_build(),
>>>>> wouldn't it be possible to only give the task to
>>>>> starpu_mpi_task_post_build() ? That would make the code lighter :)
>>>>> _______________________________________________
>>>>> Starpu-devel mailing list
>>>>> Starpu-devel@lists.gforge.inria.fr
>>>>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
> Dr Nathalie Furmento Ingénieur de recherche CNRS
> Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
> 200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
> 33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Haut de le page
