Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Question about MPI usage
- Date: Tue, 25 Feb 2014 15:17:51 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Le 25 févr. 2014 à 15:07, Samuel Thibault <samuel.thibault@ens-lyon.org> a
écrit :
> Xavier Lacoste, le Tue 25 Feb 2014 11:52:21 +0100, a écrit :
>> Thanks, this is due to a read only array that I only register on the node
>> which will execute the task.
> And no other task will need the array?
This data is only defined on proc P because only task executed on proc P can
use it, but there can be multiple task.
Finally, I registered one data_handle per process and which pointed to NULL
buffer when non local, and I choosed the good one using
starpu_get_data_rank() on the written data (which decides on which proc the
task will be executed) .
Thanks
XL.
>> Do I need to register it on every node ?
> No, only on nodes which will actually pass it to starpu_mpi_task_insert.
> You can also pass NULL to starpu_mpi_task_insert, it will just return
> EINVAL.
>> Is there an option to tell StarPU that this buffer is already on the
>> node that will execute the kernel ?
> Well, you at least need to specify an MPI rank for the data, so that
> StarPU knows it is here and doesn't have to transfer anything.
> Samuel
- Re: [Starpu-devel] Question about MPI usage, Nathalie Furmento, 03/02/2014
- Re: [Starpu-devel] Question about MPI usage, Xavier Lacoste, 25/02/2014
- Re: [Starpu-devel] Question about MPI usage, Samuel Thibault, 25/02/2014
- Re: [Starpu-devel] Question about MPI usage, Nathalie Furmento, 25/02/2014
