Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build()
- Date: Tue, 11 Mar 2014 10:51:02 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
I updated my trunk to have the STARPU_COMMUTE ignoring in MPI but now I have
a lot of this errors :
[1,0]<stderr>:[starpu][_starpu_update_perfmodel_history] Too big deviation
for model DGEMM on cpu0_parallel1_impl0: 1212.959000, vs average 989.918214
over 42 samples (+22.531234%), flushing the performance model. Use the
STARPU_HISTORY_MAX_ERROR environement variable to control the threshold
(currently 10%)
(Which slows down a lot computation)
As I'm statically deciding which GEMM go on GPUs before computation, should I
use STARPU_COMMON + cost_function instead of STARPU_HISTORY_BASE + size_base
XL.
Le 10 mars 2014 à 12:44, Samuel Thibault <samuel.thibault@ens-lyon.org> a
écrit :
> Xavier Lacoste, le Mon 10 Mar 2014 09:40:23 +0100, a écrit :
>> So, in my algorithm, I have several GEMM tasks unlocking a
>> GETRF+TRSM
>> unlocking an other list of GEMMs etc.
>> Ok, and are all the GEMMs happening on the same MPI node?
>> Yes all GEMMs applying on one column block are performed on the MPI node
>> that
>> owns the column block (it's the only "write access" data of the GEMM task).
> Ok, so there's nothing to optimize at the MPI layer here. For now I
> have made StarPU-MPI simply ignore the flag, it should work just fine
> (it works for Cholesky at least, I believe your use case is just the
> same).
> Samuel
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 10/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 10/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 11/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 11/03/2014
