Archives de la liste
- To: Xavier Lacoste <xl64100@gmail.com>
- Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build()
- Date: Tue, 11 Mar 2014 16:53:38 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Ok the performances on one node are back (DMDA 88s, EAGER 90s), I accidentaly
removed a
"starpu_data_set_sequential_consistency_flag(blocktab_handles[iter], 0);" on
a read only data used in all GEMM.
Two MPI nodes gives also encouraging results with 52s runtime.
Thanks,
XL.
Le 11 mars 2014 à 16:19, Xavier Lacoste <xl64100@gmail.com> a écrit :
> It was without GPUs but I must have broken something else in my application
> (I have the same performances with old r12012 now...)
> Le 11 mars 2014 à 14:17, Samuel Thibault <samuel.thibault@ens-lyon.org> a
> écrit :
>> Xavier Lacoste, le Tue 11 Mar 2014 12:30:54 +0100, a écrit :
>>> Indeed, the trunk seems to be slower with r13383 than with r12012 (820s
>>> vs 100s
>>> on 12 cores).
>> Is this without GPUs?
>> At any rate, please try trunk r12389, it should fix this kind of
>> performance regression.
>> Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), (suite)
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 10/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 11/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 11/03/2014
