Archives de la liste
- To: Xavier Lacoste <xl64100@gmail.com>
- Cc: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build()
- Date: Tue, 11 Mar 2014 12:30:54 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Indeed, the trunk seems to be slower with r13383 than with r12012 (820s vs 100s on 12 cores).
I had to set STARPU_HISTORY_MAX_ERROR=2000 to have no error displayed (200 was not enough).
eager seems to be slower than dmda also.... Still waiting for completion...
XL.
Le 11 mars 2014 à 11:20, Xavier Lacoste <xl64100@gmail.com> a écrit :
Le 11 mars 2014 à 11:14, Samuel Thibault <samuel.thibault@ens-lyon.org> a écrit :Xavier Lacoste, le Tue 11 Mar 2014 11:04:23 +0100, a écrit :Le 11 mars 2014 à 10:57, Samuel Thibault <samuel.thibault@ens-lyon.org> a écrit :Xavier Lacoste, le Tue 11 Mar 2014 10:51:02 +0100, a écrit :Ok, I even have 100% error on some cases.... So should I go with STARPU_HISTORY_MAX_ERROR = 100 ?I updated my trunk to have the STARPU_COMMUTE ignoring in MPI but now I have a lot of this errors :
[1,0]<stderr>:[starpu][_starpu_update_perfmodel_history] Too big deviation for model DGEMM on cpu0_parallel1_impl0: 1212.959000, vs average 989.918214 over 42 samples (+22.531234%), flushing the performance model. Use the STARPU_HISTORY_MAX_ERROR environement variable to control the threshold (currently 10%)
(Which slows down a lot computation)
Yes, this is a new thing in the trunk, the +-10% error rate may be too
small, perhaps you'd rather set STARPU_HISTORY_MAX_ERROR to 25 or even
more.
Yes.Are you also deciding which GPU the GEMM should go to? StarPU still
needs to decide between the cost of moving the data and the computation
cost. Do you have a good cost function ?
Yes I'm deciding all about GPU mapping,
How are you deciding it? By prefetching the data or by using
use_a_specific_worker? If the latter, you could perhaps as well just
use the eager scheduler, which doesn't need a performance model.
Ok I'll do that (I use STARPU_EXECUTE_ON_WORKER, workerid when building a GPU task (and let StarPU decide when it's a CPU task) and can activate prefetch or not).
Samuel
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 10/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 10/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 11/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 11/03/2014
