Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build()
- Date: Tue, 11 Mar 2014 11:20:03 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Le 11 mars 2014 à 11:14, Samuel Thibault <samuel.thibault@ens-lyon.org> a
écrit :
> Xavier Lacoste, le Tue 11 Mar 2014 11:04:23 +0100, a écrit :
>> Le 11 mars 2014 à 10:57, Samuel Thibault <samuel.thibault@ens-lyon.org> a
>> écrit :
>>> Xavier Lacoste, le Tue 11 Mar 2014 10:51:02 +0100, a écrit :
>>>> I updated my trunk to have the STARPU_COMMUTE ignoring in MPI but now I
>>>> have a lot of this errors :
>>>> [1,0]<stderr>:[starpu][_starpu_update_perfmodel_history] Too big
>>>> deviation for model DGEMM on cpu0_parallel1_impl0: 1212.959000, vs
>>>> average 989.918214 over 42 samples (+22.531234%), flushing the
>>>> performance model. Use the STARPU_HISTORY_MAX_ERROR environement
>>>> variable to control the threshold (currently 10%)
>>>> (Which slows down a lot computation)
>>> Yes, this is a new thing in the trunk, the +-10% error rate may be too
>>> small, perhaps you'd rather set STARPU_HISTORY_MAX_ERROR to 25 or even
>>> more.
>> Ok, I even have 100% error on some cases.... So should I go with
>> STARPU_HISTORY_MAX_ERROR = 100 ?
> Yes.
>>> Are you also deciding which GPU the GEMM should go to? StarPU still
>>> needs to decide between the cost of moving the data and the computation
>>> cost. Do you have a good cost function ?
>> Yes I'm deciding all about GPU mapping,
> How are you deciding it? By prefetching the data or by using
> use_a_specific_worker? If the latter, you could perhaps as well just
> use the eager scheduler, which doesn't need a performance model.
Ok I'll do that (I use STARPU_EXECUTE_ON_WORKER, workerid when building a GPU
task (and let StarPU decide when it's a CPU task) and can activate prefetch
or not).
> Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 10/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 10/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Xavier Lacoste, 11/03/2014
- Re: [Starpu-devel] Using STARPU_COMMUTE with starpu_mpi_task_build(), Samuel Thibault, 11/03/2014
