Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Scheduling accelerators
Archives de la liste
Chronologique Discussions
  • From: Muhammad Usama Asad <muhammad-usama.asad@s2012.tu-chemnitz.de>
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Scheduling accelerators
  • Date: Tue, 12 Jan 2016 16:51:39 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=muhammad-usama.asad@s2012.tu-chemnitz.de; spf=None smtp.mailfrom=muhammad-usama.asad@s2012.tu-chemnitz.de; spf=None smtp.helo=postmaster@cora.hrz.tu-chemnitz.de
  • Ironport-phdr: 9a23:p26rUhDYsYV6bpN2R8RMUyQJP3N1i/DPJgcQr6AfoPdwSP7zp8bcNUDSrc9gkEXOFd2CrakU1ayG7uu4BCQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTpkbDvsMWOKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDhY60iVaEdADk4PmQd4MzwqQKFQgWI/HQRFGQQiBtBRQbfvz/gWZKklzb6v+940SXSANb/SLl8cC+r4+8/TQLogSICPjJ87Xrej8U2hblSrDq6/UQmmcjIfcSeNPd7eKLBb5UWSDwSDY5qSyVdD9bkPMM0BO0bMLMAog==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Respected Sir,
I hope you are doing well. I am Muhammad, masters student at TU Chemnitz, Germany and writing my MS Thesis at an organization.
My problem is as follows: SoCs include computer vision accelerators, which can be used for implementing computer vision functions for different applications.
I am actually interested to know a software framework (Scheduler or algorithm) which can effectively use computer vision functions based on available HW resources i.e. computer vision accelerators in my case.
Can you propose some optimized scheduling algorithm (SW framework) for vision applications tailored for using computer vision accelerators?
And strategies for partitioning the algorithm and strategies for mapping those partitioned algorithms into hardware resources available on chipset?
I will appreciate your precious input and will be grateful if you elaborate StarPU a bit more in this regard.
Thanks & regards,
Muhammad Leghari
Haut de le page
